SM1C222MNN1225
SM1C222MNN1225
    CHINSAN(金山)
    Radial, Can
    ALUMINUM ELECTROLYTIC CAPACITORS
SM1C222MNN1225 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 SM Series  Standard size downsized  2,000 hours assured at 85℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range Working Voltage Range -40 ~ +85℃ 6.3 ~ 100Vdc Capacitance Range 0.1 ~ 22,000μF -25 ~ +85℃ 160 ~ 450Vdc 0.47 ~ 470 μF Capacitance Tolerance Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) ±20% (at 25℃ and 120Hz) Rated Voltage (V) 6.3 10 16 25 35 50 63 100 tanδ(Max) 0.26 0.22 0.16 0.14 0.12 0.10 0.09 0.08 160 ~ 250 350 ~ 500 0.15 0.20 550 0.25 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater (6.3 ~ 100V) I=0.03CV + 10μA (160 ~ 550V) I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 6.3 10 16 25 35 50 63 Z(-40℃)/Z(+20℃) 12 10 8 5 4 3 3 3 — — — — Z(-25℃)/Z(+20℃) — — — — — — — — 3 6 6 8 100 160 ~ 250 350 400 ~ 500 550 (at 120Hz) The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 2,000 hours at 85℃. Endurance Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 85℃ without voltage applied. Shelf Life Capacitance change ≦ ±20% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 5 6.3 8 10 ФD 16 18 20 22 ФD +1.0 Max Фd 0.5 0.5 0.6 0.6 0.6 0.8 0.8 1.0 1.0 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 10 10 a  S 12.5 ФD +0.5 Max L+1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max PART NUMBER SYSTEM ( Example : 35V 150µF ) M 1 V 1 5 1 M N N 0 8 B 5 Special Request Size code(08B5 : 8×11.5) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code(150μF) Voltage code(35V) Series code(SM) L+1.5 Max L+2.0 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: FIG-2 FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 85℃ (Hours) Drawing DΦ L a d F No 1 SM1A470MNN0511 / 47 µF ±20% 10 V / -40~+85 / / 100 / / / 2000 5 11 / / 2 FIG-1 2 SM1A470MNN0511 / 47 µF ±20% 10 V / -40~+85 / / 100 / / / 2000 5 11 / / 2 FIG-1 3 SM1A222MNN1020 / 2200 µF ±20% 10 V / -40~+85 / / 1310 / / / 2000 10 20 / / 5 FIG-1 4 SM1C102MNN1016 / 1000 µF ±20% 16 V / -40~+85 / / 800 / / / 2000 10 16 / / 5 FIG-1 5 SM1C152MNN1018 / 1500 µF ±20% 16 V / -40~+85 / / 1000 / / / 2000 10 18 / / 5 FIG-1 6 SM1C222MNN1225 / 2200 µF ±20% 16 V / -40~+85 / / 1420 / / / 2000 12.5 25 / / 5 FIG-1 7 SM1E220MNN0511 / 22 µF ±20% 25 V / -40~+85 / / 80 / / / 2000 5 11 / / 2 FIG-1 8 SM1E332MNN1625R / 3300 µF ±20% 25 V / -40~+85 / / 1980 / / / 2000 16 25 / / 7.5 FIG-1 9 SM1V331MNN1012 / 330 µF ±20% 35 V / -40~+85 / / 550 / / / 2000 10 12 / / 5 FIG-1 10 SM1V222MNN1625 / 2200 µF ±20% 35 V / -40~+85 / / 1880 / / / 2000 16 25 / / 7.5 FIG-1 / 68 µF ±20% 400 V / -25~+85 / / 500 / 4879 / 3000 18 25 / / 7.5 FIG-1 11 SM2G680MNN1825EF3 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 12 SM2S560MNN1330 / 56 µF ±20% 420 V / -25~+85 / / 200 / / / 2000 13 SM2W100MNN1220R / 10 µF ±20% 450 V / -25~+85 / / 130 / / / 2000 14 SM1H332MNN18P1 / 3300 µF ±20% 50 V / -40~+85 / / 2500 / / / 15 SM1H472MNN2040 / 4700 µF ±20% 50 V / -40~+85 / / 2850 / / 16 SM2L100MNN1025 / 10 µF ±20% 550 V / -25~+85 / / 100 / 17 SM1J100MNN0511U / 10 µF ±20% 63 V / -40~+85 / / 70 / 13 30 / / 5 FIG-1 12.5 20 / / 5 FIG-1 2000 18 35.5 / / 7.5 FIG-1 / 2000 20 40 / / 10 FIG-1 / / 2000 10 25 / / 5 FIG-1 / / 2000 5 11 / / 2 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit(mm): Original CHINSAN Part No. Customer Capacitance Part No. (uF) On rated SM1V220MPZ0511U / 22 µF Working Capacitance Voltage (%) 1 P0=12.7±0.2 W =18.0±0.5 W0=12.5MIN P1=3.85±0.5 ΦD0=4.0±0.2 P2=6.35±1.0 F=2.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 FIG-1 Tolerance No. P=12.7±1.0 ±20% (Vdc) 35 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -40~+85 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ / @ 85℃ @ 85℃ 120Hz 100kHz 90 / 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 85℃ (Hours) 2000 Drawing DΦ L 5 11 a d F No / / 2 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit (mm): Original No. Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 W =18.0±0.5 F=2.5+0.8/-0.2 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 FIG-1 Tolerance CHINSAN P=12.7±1.0 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 85℃ (Hours) Drawing DΦ L a d F No 1 SM1C470MP20511U / 47 µF ±20% 16 V / -40~+85 / / 110 / / / 2000 5 11 / / 2.5 FIG-1 2 SM1E100MP20511U / 10 µF ±20% 25 V / -40~+85 / / 55 / / 19900 2000 5 11 / / 2.5 FIG-1 3 SM1H100MP20511U / 10 µF ±20% 50 V / -40~+85 / / 70 / / / 2000 5 11 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8/-0.2 ΦD0=4.0±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated SM1C221MP26311 / 220 µF Working Capacitance Voltage (%) 1 H=18.5±0.5 P1=3.85±0.5 W=18.0±0.5 W0=12.5MIN t=0.7±0.2 ±20% (Vdc) 16 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -40~+85 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ / @ 85℃ @ 85℃ 120Hz 100kHz 270 / 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 85℃ (Hours) 2000 Drawing DΦ L a d F No 6.3 / / 2.5 FIG-1 11 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8 /-0.2 ΦD0=4.0±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated SM1C101MP26311U / 100 µF Working Capacitance Voltage (%) 1 H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 ±20% (Vdc) 16 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -40~+85 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ / @ 85℃ @ 85℃ 120Hz 100kHz 180 / 120Hz) 100kHz) / 1450 Dimensions (mm) Endurance Appearance @ 85℃ (Hours) 2000 Drawing DΦ L a d F No 6.3 / / 2.5 FIG-1 11 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F1=5.0+0.8/-0.2 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated SM1E221MP50812 / 220 µF Working Capacitance Voltage (%) 1 H0=16.0±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 H=18.5±0.5 ±20% (Vdc) 25 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -40~+85 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ / @ 85℃ @ 85℃ 120Hz 100kHz 330 / 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 85℃ (Hours) 2000 Drawing DΦ L 8 12 a d F1 No / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 85℃ (Hours) Drawing DΦ L a d F No 1 SM1E102MP51020 / 1000 µF ±20% 25 V / -40~+85 / / 996 / / / 2000 10 20 / / 5 FIG-1 2 SM2E330MP51020 / 33 µF ±20% 250 V / -25~+85 / / 140 / / / 2000 10 20 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 H=18.5±0.5 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 85℃ (Hours) Drawing DΦ L a d F1 No 1 SM1A101MPN0511 / 100 µF ±20% 10 V / -40~+85 / / 150 / / / 2000 5 11 / / 5 FIG-1 2 SM1H220MPN0511 / 22 µF ±20% 50 V / -40~+85 / / 95 / / / 2000 5 11 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 H=18.5±0.5 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 85℃ (Hours) Drawing DΦ L a d F1 No 1 SM1V470MPN0511U / 47 µF ±20% 35 V / -40~+85 / / 130 / / / 2000 5 11 / / 5 FIG-1 2 SM1H330MPN0511U / 33 µF ±20% 50 V / -40~+85 / / 125 / / / 2000 5 11 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 H=18.5±0.5 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 SM1E101MPN6311U / 100 µF Working ±20% (Vdc) 25 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -40~+85 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ / @ 85℃ @ 85℃ 120Hz 100kHz 190 / 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 85℃ (Hours) 2000 Drawing DΦ L a d F1 No 6.3 / / 5 FIG-1 11 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Dark Blue. Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F1=5.0+0.8/-0.2 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated SM1C471MPN0812 / 470 µF Working Capacitance Voltage (%) 1 H0=16.0±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 H=18.5±0.5 ±20% (Vdc) 16 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) -40~+85 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ / @ 85℃ @ 85℃ 120Hz 100kHz 440 / 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 85℃ (Hours) 2000 Drawing DΦ L 8 12 a d F1 No / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SM NO.: 2022-03-25 PUBLISH DATE Unit (mm) P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0+0.2 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 85℃ (Hours) Drawing DΦ L a d F No 1 SM1E471RPN1013 / 470 µF 0%~20% 25 V / -40~+85 / / 520 / / / 2000 10 13 / / 5 FIG-1 2 SM1E331MPN1012 / 330 µF ±20% 25 V / -40~+85 / / 490 / / / 2000 10 12 / / 5 FIG-1 3 SM1H331MPN1020 / 330 µF ±20% 50 V / -40~+85 / / 600 / / / 2000 10 20 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Dark Blue.
SM1C222MNN1225 价格&库存
很抱歉,暂时无法提供与“SM1C222MNN1225”相匹配的价格&库存,您可以联系我们找货
