CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
CAPACITOR Aluminum Solid Capacitor
URH
Series
2021 Change series code RH → URH
Low ESR at a high frequency range
High ripple current capability
2,000 hours at 125°C
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +125℃
Working Voltage Range
2.5 ~ 35Vdc
Surge Voltage
Rated Voltage x1.15
Capacitance Tolerance
M: ±20%
(at 25℃ and 120Hz)
See the standard ratings table (at 25℃, 100~300KHz)
ESR
Dissipation Factor (Tanδ)
See the standard ratings table (at 25℃, 120Hz)
Leakage Current ※1
See the standard ratings table (Impress the rated voltage for 2 minutes)
Low Temperature Characteristics
Impedance Ratio
Z(-25℃)/Z(+25℃) ≤1.15 at 100KHz
Z(-55℃)/Z(+25℃) ≤1.25 at 100KHz
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 2,000 hours at 125°C
Endurance
Capacitance change
≦ ±20% of the initial value
ESR
≦ 150% of the specified value
Dissipation factor(tanδ)
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 60℃ 90 to 95% RH
Damp Heat
(Steady State)
Capacitance change
ESR
Leakage current
≦ specified value
※1 In case of some problems for measured values, measure after applying rated voltage for 120 minutes at105°C
※2 ESR should be measured at both of the terminal ends closest to the capacitor body
◆DIMENSIONS (mm)
◆Lead
6.3
ФD
PART NUMBER SYSTEM
◆Marking
Фd
0.6
L
α
F
8
0.6
10
0.6
0.6
0.6
0.6
0.6
0.6
8
12
8
11
16
1.5
1
1.5
1.5
1.5
1.5
1.5
2.5
2.5
3.5
3.5
3.5
5
5
5
URH
Series
Standard Ratings
Rated
Voltage
(Vdc)
2.5(0E)
4(0G)
6.3(0J)
10(1A)
16(1C)
20(1D)
25(1E)
35(1V)
Rated
Capacitance
(μF)
Case Size
ФD×L
(mm)
ESR
100~300KHz
(mΩ max)
680
8×11
820
8×11
560
680
1200
470
Rated Ripple Current
(mArms max)
Tan δ
max
Leakage
Current
(μA max)
Part Number
≦105℃
105~125℃
13
4520
1430
0.12
340
URH0E681MNN0811U
13
4520
1430
0.12
410
URH0E821MNN0811U
8×11
13
4520
1430
0.12
448
URH0G561MNN0811U
8×11
13
4520
1430
0.12
544
URH0G681MNN0811U
10×12
12
5440
1720
0.12
960
URH0G122MNN1012U
8×11
13
4520
1430
0.12
592
URH0J471MNN0811U
560
8×11
13
4520
1430
0.12
706
URH0J561MNN0811U
820
6.3×8
13
4520
1430
0.12
1033
URH0J821MNN6308
820
10×12
12
5440
1720
0.12
1033
URH0J821MNN1012U
120
8×8
35
2560
810
0.12
300
URH1A121MNN0808U
330
8×11
16
3950
1250
0.12
660
URH1A331MNN0811U
390
8×11
16
3950
1250
0.12
780
URH1A391MNN0811U
560
10×12
13
5230
1655
0.12
1120
URH1A561MNN1012U
1000
10×12
13
5230
1200
0.12
2000
URH1A102MNN1012U
82
8×8
35
2560
810
0.12
300
URH1C820MNN0808U
150
8×8
35
2560
810
0.12
480
URH1C151MNN0808U
180
8×11
18
3640
1150
0.12
576
URH1C181MNN0811U
220
8×11
18
3640
1150
0.12
704
URH1C221MNN0811U
270
8×11
18
3640
1150
0.12
864
URH1C271MNN0811U
270
10×12
16
4720
1490
0.12
864
URH1C271MNN1012U
330
10×12
16
4720
1490
0.12
1056
URH1C331MNN1012U
390
10×12
16
4720
1490
0.12
1248
URH1C391MNN1012U
470
10×12
16
4720
1490
0.12
1504
URH1C471MNN1012U
470
10×12
9
6100
2240
0.12
1504
URH1C471MNN1012EU
820
8×12
11
5600
1680
0.12
2624
URH1C821MNN0812U
820
10×12
12
5400
1630
0.12
2624
URH1C821MNN1012U
1200
10×12
12
6300
1890
0.12
3840
URH1C122MNN1012SU
1500
8×20
12
6100
2240
0.12
4800
URH1C152MNN0820U
1500
10×12
11
6300
1890
0.12
4800
URH1C152MNN1012U
2200
10×20
15
6100
2250
0.12
3520
URH1C222MNN1020U
330
6.3×12
18
3640
1150
0.12
1320
URH1D331MNN6312
470
8×11
16
4720
1490
0.12
1880
URH1D471MNN0811U
820
10×16
16
4000
1300
0.12
3280
URH1D821MNN1016U
1500
10×20
16
5000
1700
0.12
6000
URH1D152MNN1020U
100
8×8
24
2600
1040
0.12
500
URH1E101MNN0808U
120
8×11
27
2300
890
0.12
600
URH1E121MNN0811U
180
10×12
25
2800
1080
0.12
900
URH1E181MNN1012U
330
8×11
25
2800
1080
0.12
1650
URH1E331MNN0811U
470
10×12
14
4720
1490
0.12
2350
URH1E471MNN1012U
180
10×12
28
3650
1264
0.12
1260
URH1V181MNN1012U
270
10×12
26
2700
800
0.12
1890
URH1V271MNN1012U
PA RT N U M B E R S Y S T E M
RADIAL LEAD TYPE
Series
Rated Voltage
Capacitance
Tolerance
Lead Forming Type
Lead Length
Case Dimension
Special Request
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(1) Series
Series
DIP
UPS
UPR
UUL
UPE
SMD
VSG
VSP
VSU
VSE
URP
URH
UGP
UGS
UGV
UPC
(2) Rated Voltage
Code
0E
0J
6K
7H
1A
1B
AG
1C
1D
1P
1E
1F
1V
1H
1J
2A
WV
2.5
6.3
6.8
7.5
10
12
14
16
25
30
35
50
63
100
(3) Capacitance
Code
6R8
μF
6.8
100
10
180
560
101
181
561
102
182
18
56
100
180
560
1000
1800
(4) Capacitance Tolerance
Code
J
Q
R
K
V
M
H
±5
+30 / -10
+20 / -0
± 10
+20 / -10
± 20
+20 / -5
(5) Lead Type
Code
C
P
Description
Cutting
Taping
Drawing
Fig 1
Fig 2
(6) Lead Length (Cut / Formed lead)
Code
3
4
U
7
D
X
R
B
E
G
2
M
T
N
Length
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
+20mm min
Tolerance
±0.5
±0.2
±0.3
-15mm min
Taping Code
Code
Z
2
3
7
5
S
Lead Pitch:+0.8/-0.2
2.0
2.5
3.5
3.5
5.0
5.0
(7) Case Dimension
DIP Code
0508
6305
6308
6316
0807
0808
0811
0816
0820
1012
1016
1020
10×16
10×20
Size
5×8
6.3×5
6.3×8
6.3×16
8×7
8×8
8×11
8×16
8×20
10×12
SMD Code
5057
6343
6357
6377
6309
0867
0897
08C7
1077
10C4
Size
5×5.7
6.3×4.3
6.3×5.7
6.3×7.7
6.3×9
8×6.7
8×9.7
8×12.7
10×7.7
10×12.4
(8) Special Request
Code
R
F5
L
T
Description
High Rated ripple current
Endurance 5000 hrous
Low Leakage Current
Terminal strength
Code
U
E
X
S
Description
Convex Rubber
Low ESR
Pitch 2.5mm
Limit high
MARKING AND DATE CODE
Trade Mark "CS"
Chinsan Solid Capacitor, Show on Dimension ≧8 Ф
Code (Date Code)
(1)DAY
(1)
(2)
(3)
Code
1
2
3
4
5
1
1
Week
The first week
The second week
The third week
The fourth week
The fifth week
(2)Month
Code
1
2
3
4
5
6
Month
Jan
Feb
Mar
Apr
May
Jun
Code
7
8
9
X
Y
Z
Month
July
Aug
Sep
Oct
Nov
Dec
Code
9
2
3
4
Year
2019
2020
2021
2022
2023
2024
(3)Year
Series (Print Code)
Series
UPS UPR UUL UPE URP URH UGP UGV UGS
Ф 5~ Ф 6.3
R
L
E
Ф 8~ Ф 10
UPS
UL
UPE RP
H
P
V
RH
GP
GV
GS
UPC VSG VSP
C
G
UPC SG
VSU VSE
P
U
E
SP
SU
SE
LEAD FORMING TYPE
Dimensions (Unit: mm)
Part
Number
ΦD
F
ι
3
4
U
7
D
X
R
B
E
G
2
M
T
3.5
4.5
5.5
7
4
2.3
2.5
2.8
3.1
3.3
2.5
3.5
3.8
Cut
2
6.3
2.5
8
3.5
10
5
±0.2
±0.3
D
±0.5
5
(Part number for lead length and pitch for taping)
F
Type
L
C
L
TAPING
Figure 1
Ф8
Фd
±0.05
0.45
0.45/0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
3.85
3.85
3.85
P2
±1.0
6.35
6.35
6.35
5
5
5
PS
P5
0.8
-0.2
H
±0.5
H0
±0.5
17.5
18.5
PS
P5
17.5
16
18.5
PS
P5
17.5
16
18.5
16
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45/0.6
0.6
0.6
P
±0.1
12.7
12.7
12.7
P0
±0.2
12.7
12.7
12.7
P1
±0.5
5.1
4.6
3.85
P2
±1.0
6.35
6.35
6.35
2.5
3.5
5
F
Figure 3
Ф 6.3
Tolerance
F
Figure 2
Ф5
Symbol
+0.8
-0.2
Ф 6.3
P2
H
±0.5
118.5
H0
±0.5
Ф8
P3
18.5
H3
Ф 10
P7
17.5
P5
18.5
H5
W
±0.5
18
18
18
W0
Minimum
12.5
12.5
12.5
D0
±0.2
4
4
4
t
±0.2
0.7
0.7
0.7
Symbol
Tolerance
Фd
±0.05
0.45
P
±0.1
12.7
P0
±0.2
12.7
P1
±0.5
5.35
P2
±1.0
6.35
F
+0.8
-0.2
Ф5
PZ
2.0
H
±0.5
18.5
H0
±0.5
W
±0.5
18
W0
Minimum
12.5
D0
±0.2
4
t
±0.2
0.7
J5
21
很抱歉,暂时无法提供与“URH1V271MNN1012U”相匹配的价格&库存,您可以联系我们找货
