MBR2035CT thru MBR20200CT
Taiwan Semiconductor
CREAT BY ART
FEATURES
Dual Common Cathode Schottky Rectifier
- Low power loss, high efficiency
- Guardring for overvoltage protection
- High surge current capability
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21 definition
TO-220AB
MECHANICAL DATA
Case: TO-220AB
Molding compound, UL flammability classification rating 94V-0
Base P/N with suffix "G" on packing code - halogen-free
Base P/N with prefix "H" on packing code - AEC-Q101 qualified
Terminal: Matte tin plated leads, solderable per JESD22-B102
Meet JESD 201 class 1A whisker test,
with prefix "H" on packing code meet JESD 201 class 2 whisker test
Polarity: As marked
Mounting torque: 5 in-lbs maximum
Weight: 1.88 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
SYMBOL
MBR
MBR
MBR
MBR
MBR
MBR
MBR
2035
2045
2050
2060
2090 20100 20150 20200
CT
CT
CT
CT
CT
CT
CT
CT
MBR
UNIT
Maximum repetitive peak reverse voltage
VRRM
35
45
50
60
90
100
150
200
V
Maximum RMS voltage
VRMS
24
31
35
42
63
70
105
140
V
Maximum DC blocking voltage
VDC
35
45
50
60
90
100
150
200
V
Maximum average forward rectified current
IF(AV)
A
Peak repetitive forward current
(Rated VR, Square Wave, 20KHz)
IFRM
A
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load
IFSM
150
A
Peak repetitive reverse surge current (Note 1)
IRRM
Maximum instantaneous forward voltage (Note 2)
IF=10A, TJ=25℃
IF=10A, TJ=125℃
IF=20A, TJ=25℃
IF=20A, TJ=125℃
Maximum reverse current @ rated VR
TJ=25 ℃
TJ=125 ℃
VF
IR
Voltage rate of change (Rated VR)
dV/dt
Typical thermal resistance
RθJC
Operating junction temperature range
Storage temperature range
1
0.5
A
0.80
0.85
0.99
0.57
0.70
0.75
0.87
0.84
0.95
0.95
1.23
0.72
0.85
0.85
1.10
V
0.1
10
15
5
0.15
10000
V/μs
2.0
1.0
mA
O
C/W
TJ
- 55 to +150
O
C
TSTG
- 55 to +150
O
C
Note 1: tp = 2.0 μs, 1.0KHz
Note 2: Pulse test with PW=300μs, 1% duty cycle
Document Number: DS_D1308039
Version: L13
ORDERING INFORMATION
AEC-Q101
PART NO.
QUALIFIED
Prefix "H"
MBR20xxCT
GREEN COMPOUND
PACKING CODE
CODE
Suffix "G"
C0
PACKAGE
PACKING
TO-220AB
50 / Tube
Note 1: "xx" defines voltage from 35V (MBR2035CT) to 200V (MBR20200CT)
EXAMPLE
PREFERRED P/N
PART NO.
MBR2060CT C0
AEC-Q101
PACKING CODE
QUALIFIED
MBR2060CT
C0
MBR2060CT C0G
MBR2060CT
C0
MBR2060CTHC0
MBR2060CT
H
GREEN COMPOUND
CODE
G
DESCRIPTION
Green compound
AEC-Q101 qualified
C0
RATINGS AND CHARACTERISTICS CURVES
24
AVERAGE FORWARD A
CURRENT (A)
12
8
RESISTIVE OR
INDUCTIVELOAD
WITH HEATSINK
4
100
CASE TEMPERATURE
150
PEAK FORWARD SURGE CURRENT (A)
FIG.1- FORWARD CURRENT DERATING CURVE
TJ=25℃
1
MBR2035CT-2045CT
MBR2050CT-2060CT
MBR20100CT
MBR20150CT-200CT
Pulse Width=300μs
1% Duty Cycle
0.01
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9
FORWARD VOLTAGE (V)
100
75
50
25
10
100
FIG. 4- TYPICAL REVERSE CHARACTERISTICS
PER LEG
100
1
1.1 1.2
INSTANTANEOUS REVERSE CURRENT (mA)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125℃
8.3ms Single Half Sine Wave
JEDEC Method
125
NUMBER OF CYCLES AT 60 Hz
100
0.1
150
(oC)
FIG. 3- TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS PER LEG
10
FIG. 2- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT PER LEG
10
TJ=125℃
1
TJ=75℃
0.1
TJ=25℃
0.01
MBR2035CT-2045CT
MBR2050CT-20100CT
MBR20150CT-20200CT
0.001
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Version: L13
FIG. 5- TYPICAL JUNCTION CAPACITANCE
PER LEG
100
f=1.0MHz
Vsig=50mVp-p
TRANSIENT THERMAL
IMPEDANCE (℃/W)
JUNCTION CAPACITANCE (pF) A
10000
FIG. 6- TYPICAL TRANSIENT THERMAL IMPEDANCE
PER LEG
10
1000
MBR2035CT-2045CT
MBR2050CT-20200CT
100
0.1
1
10
100
1
0.1
0.01
0.1
REVERSE VOLTAGE (V)
1
10
100
T-PULSE DURATION. (sec)
PACKAGE OUTLINE DIMENSIONS
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
10.50
0.413
B
2.62
3.44
0.103
0.135
C
2.80
4.20
0.110
0.165
D
0.68
0.94
0.027
0.037
E
3.54
4.00
0.139
0.157
F
14.60
16.00
0.575
0.630
G
13.19
14.79
0.519
0.582
H
2.41
2.67
0.095
0.105
I
4.42
4.76
0.174
0.187
J
1.14
1.40
0.045
0.055
K
5.84
6.86
0.230
0.270
L
2.20
2.80
0.087
0.110
M
0.35
0.64
0.014
0.025
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: L13
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: L13
很抱歉,暂时无法提供与“MBR20100CTC0”相匹配的价格&库存,您可以联系我们找货
