PGSMAJ5.0A - PGSMAJ100A
Taiwan Semiconductor
400W, 5V - 100V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
Low profile package
Ideal for automated placement
Photo Glass passivated junction
Excellent clamping capability
Typical IR less than 1μA above 10V
400 watts peak pulse power capability with a 10 / 1000 μs
waveform (300W above 78V)
● Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
5 - 100
V
VBR
6.8 - 117
V
TJ MAX
175
°C
Package
DO-214AC (SMA)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
DO-214AC (SMA)
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Part no. with suffix "H" means AEC-Q101 qualified
Packing code with suffix "G" means green compound
(halogen-free)
Moisture sensitivity level: level 1, per J-STD-020
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.06 g (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Peak power dissipation at TA=25°C, td=1ms (Note 1)
Steady state power dissipation
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load
Maximum instantaneous forward voltage at 25 A for
unidirectional only
Operating junction temperature range
Storage temperature range
SYMBOL
VALUE
UNIT
PPPM
400
W
PD
1
W
IFSM
40
A
VF
3.5
V
TJ
-55 to +175
°C
TSTG
-55 to +175
°C
Notes:
1. Non-repetitive Current Pulse Per Fig.3 and derated above TA=25°C Per Fig.2. Rating is 300 W for VWM > 78 V
Devices for Bi-directional Applications
1. For Bi-directional use CA suffix (e.g. PGSMAJ10CA).
2. Electrical Characteristics Apply in Both Directions
1
Version:A1707
THERMAL PERFORMANCE
PARAMETER
SYMBOL
LIMIT
UNIT
RӨJL
RӨJA
RӨJC
29
120
31
°C/W
°C/W
°C/W
Junction-to-lead thermal resistance per diode
Junction-to-ambient thermal resistance per diode
Junction-to-case thermal resistance per diode
Thermal Performance Note: Units mounted on recommended PCB (5.0mm x 5.0mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Part number
Marking
code
PGSMAJ5.0A
PGSMAJ6.0A
PGSMAJ6.5A
PGSMAJ7.0A
PGSMAJ7.5A
PGSMAJ8.0A
PGSMAJ8.5A
PGSMAJ9.0A
PGSMAJ10A
PGSMAJ11A
PGSMAJ12A
PGSMAJ13A
PGSMAJ14A
PGSMAJ15A
PGSMAJ16A
PGSMAJ17A
PGSMAJ18A
PGSMAJ20A
PGSMAJ22A
PGSMAJ24A
PGSMAJ26A
PGSMAJ28A
PGSMAJ30A
PGSMAJ33A
PGSMAJ36A
PGSMAJ40A
PGSMAJ43A
PGSMAJ45A
PGSMAJ48A
PGSMAJ51A
PGSMAJ54A
PGSMAJ58A
PGSMAJ60A
PGSMAJ64A
PGSMAJ70A
PGSMAJ75A
PGSMAJ78A
PGSMAJ85A
PGSMAJ90A
PGSMAJ100A
PAE
PAG
PAK
PAM
PAP
PAR
PAT
PAV
PAX
PAZ
PBE
PBG
PBK
PBM
PBP
PBR
PBT
PBV
PBX
PBZ
PCE
PCG
PCK
PCM
PCP
PCR
PCT
PCV
PCX
PCZ
PRE
PRG
PRK
PRM
PRP
PRR
PRT
PRV
PRX
PRZ
Breakdown
voltage
VBR@IT
(V)
(Note 1)
Min.
6.4
6.67
7.22
7.78
8.33
8.89
9.44
10.0
11.1
12.2
13.3
14.4
15.6
16.7
17.8
18.9
20.0
22.2
24.4
26.7
28.9
31.1
33.3
36.7
40.0
44.4
47.8
50.0
53.3
56.7
60.0
64.4
66.7
71.1
77.8
83.3
86.7
94.4
100
111
Max.
7.00
7.37
7.98
8.60
9.21
9.83
10.40
11.10
12.30
13.50
14.70
15.90
17.20
18.50
19.70
20.90
22.10
24.50
26.90
29.50
31.90
34.40
36.8
40.6
44.2
49.1
52.8
55.3
58.9
62.7
66.3
71.2
73.7
78.6
86
92.1
95.8
104
111
123
Test current
IT
(mA)
Working
stand-off
voltage
VWM
(V)
Maximum reverse
leakage current
IR@VWM
(µA)
(Note 1)
Maximum peak
impulse current
IPPM (A)
tp =10/1000 μs
Maximum clamping
voltage
VC@IPPM (V)
tp =10/1000 μs
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
5
6
6.5
7
7.5
8
8.5
9
10
11
12
13
14
15
16
17
18
24
26
28
30
33
36
40
43
45
48
51
54
58
60
64
70
75
78
85
90
100
800
800
500
200
100
50
10
5
5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
43.5
38.8
35.7
33.3
31.0
29.4
27.8
26.0
23.5
22.0
20.1
18.6
17.2
16.4
15.4
14.5
13.7
12.3
11.3
10.3
9.5
8.8
8.3
7.5
6.9
6.2
5.8
5.5
5.2
4.9
4.6
4.3
4.1
3.9
3.5
3.3
3.2
2.2
2.1
1.9
9.2
10.3
11.2
12.0
12.9
13.6
14.4
15.4
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
96.8
103
113
121
126
137
146
162
Notes:
1. Non-repetitive current pulse, per Fig. 3 and derated above TA=25°C per Fig. 2
2. Mounted on 5 x 5mm copper pads to each terminal
3. Lead temperature at TL=75°C
4. Measure on 8.3ms single half sine-wave duty cycle=4 pulses per minutes maximum
5. Peak pulse power waveform is 10/1000 μs
6. For Bi-directional devices having VR of 10 volts and under, the IR limit is double
2
Version:A1707
ORDERING INFORMATION
PART NO.
PART NO.
SUFFIX(*)
PGSMAJxxxx
(Note 1)
PACKING
PACKING CODE
CODE
SUFFIX
H
PACKAGE
PACKING
R3
SMA
1,800 / 7" Plastic reel
R2
SMA
7,500 / 13" Paper reel
M2
SMA
7,500 / 13" Plastic reel
Folded SMA
Folded SMA
F4
Folded SMA
E3
Clip SMA
E2
Clip SMA
F3
G
F2
Note :
1. "xxxx" defines voltage from 5.0V (PGSMAJ5.0A) to 100V (PGSMAJ100A)
*: Optional available.
EXAMPLE
EXAMPLE P/N
PART NO.
PGSMAJ26AHR3G
PGSMAJ26A
PART NO.
PACKING
PACKING CODE
SUFFIX
CODE
SUFFIX
H
R3
G
3
DESCRIPTION
AEC-Q101 qualified
Green compound
Version:A1707
CHARACTERISTICS CURVES
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
100
PEAK PULSE POWER (PPPM) OR CURRENT(IPP)
DERATING IN PERCENTAGE (%)
PPPM, PEAK PULSE POWER (KW)
100
Non-Repetitive Pulse
Waveform Shown in Fig.3
TA=25°C
10
PGSMAJ5.0A - PGSMAJ78A
1
PGSMAJ85A - PGSMAJ100A
Heat sink
5mm x 5mm
Cu pad test board
0.1
10
100
1000
75
50
25
50
75
100
125
150
175
TJ - INITIAL JUNCTION TEMPERATURE (°C)
td - PULSE WIDTH (μs)
Fig.3 Clamping Power Pulse Waveform
Fig.4 Typical Junction Capacitance
1000
Peak value
IPPM
PEAK PULSE CURRENT (%)
120
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
CAPACITANCE (pF)
140
100
Rise time tr=10μs to 100%
80
Half value-IPPM/2
10/1000μs, waveform
as defined by R.E.A.
60
PGSMAJ10A
100
PGSMAJ40A
10
40
td
f=1.0MHz
Vsig=50mVp-p
1
1
1.5
2
2.5
1
3
10
100
REVERSE VOLTAGE (V)
t, TIME (ms)
4
Version:A1707
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
DIM
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.27
1.58
0.050
0.062
B
4.06
4.60
0.160
0.181
C
2.29
2.83
0.090
0.111
D
1.99
2.50
0.078
0.098
E
0.90
1.41
0.035
0.056
F
4.95
5.33
0.195
0.210
G
0.10
0.20
0.004
0.008
H
0.15
0.31
0.006
0.012
SUGGESTED PAD LAYOUT
Symbol
Unit (mm)
Unit (inch)
A
1.68
0.066
B
1.52
0.060
C
3.93
0.155
D
2.41
0.095
E
5.45
0.215
MARKING DIAGRAM
P/N
G
YW
F
5
= Marking Code
= Green Compound
= Date Code
= Factory Code
Version:A1707
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version:A1707
很抱歉,暂时无法提供与“PGSMAJ5.0CAHE3G”相匹配的价格&库存,您可以联系我们找货
