TS15P05G-K - TS15P07G-K
Taiwan Semiconductor
15A, 600V - 1000V Glass Passivated Bridge Rectifier
FEATURES
KEY PARAMETERS
Glass passivated junction
Ideal for printed circuit board
High surge current capability
UL Recognized File # E-326243
Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
TV
Monitor
PARAMETER
VALUE
UNIT
IF
15
A
VRRM
600 - 1000
V
IFSM
240
A
TJ MAX
150
°C
Package
TS-6P
Configuration
Quad
MECHANICAL DATA
Case: TS-6P
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: As marked
Mounting torque: 0.92 N⋅m maximum
Weight: 6.5 g (approximately)
TS-6P
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
TS15P
05G-K
TS15P
05G
600
Reverse voltage, total rms value
VR(RMS)
420
PARAMETER
SYMBOL
Marking code on the device
Forward current
Surge peak forward current, 8.3 ms single
half sine-wave superimposed on rated
load per diode
Rating of fusing ( t
很抱歉,暂时无法提供与“TS15P07G-K D2G”相匹配的价格&库存,您可以联系我们找货
