TST20L150CW
TST20L150CW
    TAIWANSEMICONDUCTOR(台半)
    TO-220-3
    二极管 150 V 10A 通孔 TO-220AB
TST20L150CW 数据手册
TST20L100CW – TST20L200CW Taiwan Semiconductor 20A, 100V - 200V Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ High efficiency High forward surge capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 20 A VRRM 100 - 200 V IFSM 100 A TJ MAX 150 °C Package TO-220AB Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.88g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage TST20L TST20L TST20L TST20L UNIT 100CW 120CW 150CW 200CW TST20L TST20L TST20L TST20L 100CW 120CW 150CW 200CW 100 120 150 200 V 70 84 105 140 V IF 20 A IFSM 100 A dv/dt 10,000 V/μs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: C2104 TST20L100CW – TST20L200CW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 3.2 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP MAX UNIT 0.62 - V 0.69 - V 0.78 - V TST20L200CW 0.81 - V TST20L100CW - 0.84 V - 0.93 V - 0.96 V - 0.99 V 0.55 - V 0.58 - V 0.64 - V TST20L200CW 0.67 - V TST20L100CW 0.65 0.74 V 0.69 0.78 V 0.72 0.81 V 0.75 0.84 V - 100 µA - 15 mA - 10 mA TST20L100CW TST20L120CW TST20L150CW TST20L120CW TST20L150CW Forward voltage per (1) diode IF = 10A, TJ = 25°C TST20L200CW VF TST20L100CW TST20L120CW TST20L150CW TST20L120CW TST20L150CW Reverse current @ rated (2) VR per diode IF = 5A, TJ = 25°C IF = 5A, TJ = 125°C IF = 10A, TJ = 125°C TST20L200CW TST20L100CW TST20L120CW TJ = 25°C TST20L150CW TST20L200CW TST20L100CW TST20L120CW TJ = 125°C TST20L150CW TST20L200CW IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TST20LxCW TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 100V(TST20L100CW) to 200V(TST20L200CW) 2 Version: C2104 TST20L100CW – TST20L200CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 20 CAPACITANCE (pF) 15 10 TST20L100CW 1000 TST20L120CW 100 TST20L150CW 5 0 50 75 100 125 10 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=150°C 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 100 100 10 TST20L100CW 10 1 1 TJ=25°C 0.01 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=150°C 1 TJ=125°C TJ=100°C 0.01 0.001 TJ=25°C 20 30 40 50 60 70 80 90 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 1.1 1.2 Fig.6 Typical Forward Characteristics TST20L120CW 10 TJ=25°C TJ=100°C FORWARD VOLTAGE (V) 100 0.0001 TJ=150°C 0.1 Fig.5 Typical Reverse Characteristics 0.1 UF1DLW TJ=125°C TJ=125°C PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 100 Fig.4 Typical Forward Characteristics 100 10 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics TST20L100CW TST20L200CW (A) 25 f=1.0MHz Vsig=50mVp-p 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 TST20L120CW 10 1 0.1 1 0.01 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 25 TJ=100°C TJ=25°C Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 FORWARD VOLTAGE (V) 3 Version: C2104 TST20L100CW – TST20L200CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.8 Typical Forward Characteristics TJ=150°C 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 100 100 10 TST20L150CW 10 1 TJ=150°C 0.1 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=150°C 0.1 TJ=100°C 0.001 TJ=25°C 0.00001 10 20 30 40 50 60 70 80 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 0.1 0.001 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2 Fig.10 Typical Forward Characteristics TJ=125°C 0.0001 TJ=25°C FORWARD VOLTAGE (V) 10 0.01 TJ=25°C TJ=100°C 0.01 Fig.9 Typical Reverse Characteristics 1 TJ=125°C TJ=125°C 1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TST20L200CW UF1DLW 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 TST20L200CW 10 1 0.1 1 0.01 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=25°C TJ=100°C TJ=25°C Pulse width 300μs 1% duty cycle Pulse width FORWARD VOLTAGE (V) 4 (A) TST20L150CW (A) 10 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.7 Typical Reverse Characteristics Version: C2104 TST20L100CW – TST20L200CW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: C2104 TST20L100CW – TST20L200CW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: C2104
TST20L150CW 价格&库存
很抱歉,暂时无法提供与“TST20L150CW”相匹配的价格&库存,您可以联系我们找货
