33-HC771-28
33-HC771-28
    TALLYSMANWIRELESS
    螺旋形 RF 天线 28dB
33-HC771-28 数据手册
Antenna Line Card Single Band - Antennas listed in red have pre-filters Bands Mounting Model Element TW1010/TW1012 Single Feed 26/24 9 30 Can be custom tuned TW1015/TW1017 Single Feed 15/12 5 30 Can be custom tuned TW1027 Single Feed 24 1.75 30 Can be custom tuned TW2106/TW2108 Accutenna 28 15 100 Can be custom tuned TW4020/TW4022 Single Feed 28/25 12 73 Can be ordered without magnet TW4027/TW4029 Single Feed 24/21 1.75 73 Can be ordered without magnet TW2010/TW2012 Single Feed 28/25 10 150 Can be ordered without magnet TW2100 Accutenna 27/24 15 150 Can be ordered without magnet TW3010/TW3012 Single Feed 28/26 9 150 Conical or flat radome TW3040/TW3042 Single Feed 40/39 15 150 Conical or flat radome TW3100 Accutenna 27/25 14 150 Conical or flat radome TW3142 Accutenna 40 19 150 Conical or flat radome TW3150/TW3152 Accutenna 49/47 25 150 Conical or flat radome TW1320/TW1322 Single Feed 28/26 9 50 Can be custom tuned TW1421/TW1422 Accutenna 28/26 10 18 Can be custom tuned TW1430 Accutenna 32 10 18 Can be custom tuned TW2406/TW2408 Accutenna 28/25 15 38 Can be custom tuned TW4320/TW4322 Single Feed 28 12 50 Can be ordered without magnet TW4327/TW4329 Single Feed 24/21 1.75 50 Can be ordered without magnet TW4421/TW4422 Accutenna 28/26 10 50 Can be ordered without magnet Magnetic/Screw TW2410/TW2412 Accutenna 28/26 15 110 Can be ordered without magnet TW3320/TW3322 Single Feed 28/26 9 150 Conical or flat radome TW3370/TW3372 Single Feed 41/40 20 150 Conical or flat radome TW3400/TW3402 Accutenna 28/26 13 150 Conical or flat radome TW3440/TW3442 Accutenna 39/37 19 150 Conical or flat radome TW1721/TW1722 Accutenna 28/27 10 18 Can be custom tuned TW2706/TW2708 Accutenna 28/27 15 35 Can be custom tuned TW2926 Accutenna 28 18 45 Can be custom tuned Helical HC771 Quadrafiler 28 12 25 Embedded version available, 3.3CM Magnetic TW4721/TW4722 Accutenna 25/23 10 50 Can be ordered without magnet TW2710/TW2712 GPS L1 / GLONASS G1 / Galileo E1 / BeiDou B1 Magnetic/Screw TW2743 Accutenna 28/26 15 110 Can be ordered without magnet Accutenna 21 14 160 Passive Iridium / Active GNSS TW2920 Accutenna 32 18 100 Also receives L-Band services TW3710/TW3712 Accutenna 28/26 15 150 Conical or flat radome TW3740/TW3742 Accutenna 40/38 19 150 Conical or flat radome TW3752 Accutenna 50 30 150 Conical or flat radome TW9712 Accutenna 28 15 Embedded Magnetic GPS L1 Magnetic/Screw Through Hole Embedded GPSL1/ GLONASS G1 Magnetic Through Hole Embedded Through Hole Gain (db) Current (mA) Weight (g) Note "Button" antenna Antenna Line Card Dual Band - Antennas listed in red have pre-filters Bands Mounting Model Element TW1829 Accutenna 27 12 37 Can be custom tuned TW3867 Accutenna 28/26 24 70 Can be custom tuned TW3872E Accutenna 35 24 185 Can be custom tuned HC871 Quadrafiler 28 12 25 Embedded version available, 3.3CM HC872 Quadrafiler 28/35 12 37 Receives L-Band, Embedded available, 4.5CM Magnetic TW8829 Accutenna 27 12 52 Can be ordered without magnet Magnetic / Screw TW7872 Accutenna 32 24 180 Can be ordered without magnet TW3872 Accutenna 35 24 185 Conical or flat radome TW9829 Accutenna 28 14 TW1889 Accutenna 27 12 37 Can be custom tuned TW3887 Accutenna 35 24 70 Can be custom tuned Helical HC882 Quadrafiler 28/35 12/18 37 Receives L-Band, Embedded available, 4.5CM Magnetic TW8889 Accutenna 27 12 52 Can be ordered without magnet TW3882 Accutenna 35 24 185 Conical or flat radome TW9889 Accutenna 27 12 5/8" x 11tpi VP6200 Crossed Dipole 35/50 35/45 800 Conical or flat radome Embedded TW1825 Accutenna 27 12 37 Can be custom tuned TW8825 Accutenna 27 12 52 Compatible with Navic L5 TW7875 Accutenna 32 24 180 Compatible with Navic L5 Through Hole TW9825 Accutenna 27 12 Magnetic/Screw TW7876 Accutenna 32 24 180 Compatible with Navic L5 Embedded GPS L1/L2, GLONASS G1/G2, Galileo E1, BeiDou B1 Helical Through Hole Embedded GPS L1/L2, GLONASS G1/G2/G3, Galileo E1/ E5b, BeiDou B1/B2 Through Hole GPS L1/L5 GLONASS G1 Galileo E1/E5a BeiDou B1 L1/L6, G1, E6, B1/B3 Magnetic Gain (db) Current (mA) Weight (g) Note "Button" antenna “Button” antenna "Button" antenna Triple Band - Antennas listed in red have pre-filters GPS L1/L2/L5, GLONASS G1/G3, Galileo E1/E5, BeiDou B1/B2 HC975 Quadrafiler 28/35 12/18 37 Receives L-Band, Embedded available, 4.5CM TW3967 Accutenna 28 24 70 Also receives L-Band services TW3972E Accutenna 37 24 75 Also receives L-Band services TW7972 Accutenna 32 24 180 Also receives L-Band services TW3972 Accutenna 37 24 185 Also receives L-Band services VP6300 Crossed Dipole 35/50 35/45 800 Conical or flat radome VP6000 Crossed Dipole 35/50 35/45 800 Also receives L-Band services VC6100 Choke Ring 35/50 35/45 4000 SCIGN Radome optional Helical HC600 Quadrafiler 4.25 12 18 Embedded version available, 3.3CM Magnetic/Screw TW2600 Accutenna 4.25 10 100 Can be ordered without magnet Helical Embedded GPS L1/L2/L5 GLONASS G1/G2/G3 Galileo E1/ Magnetic/Screw E5 BeiDou B1/B2 Through Hole 5/8" x 11tpi All Bands - Antennas listed in red have pre-filters All GNSS Signals 5/8" x 11tpi Iridium Iridium About Tallysman: With global headquarters and manufacturing in Ottawa, Canada, Tallysman is a leading manufacturer of high-precision antennas and components for Global Navigation Satellite System (GNSS) applications. Tallysman’s mission is to support the needs of a new generation of positioning systems by delivering unprecedented antenna precision at competitive prices. Learn more at www.tallysman.com © 2019 Tallysman Inc. All rights reserved. Tallysman, the “When Precision Matters” tag line and the Tallysman logo are trademarks or registered trademarks of Tallysman Inc. and/or its affiliates in Canada and certain other countries. All other trademarks mentioned in this document are the property of their respective owners. The information presented is subject to change without notice. Tallysman assumes no responsibility or any errors or omissions in this document. Tallysman Wireless Inc. hereby disclaims any or all warranties and liabilities of any kind. Tallysman Line Card EN v1.1 Contact us: info@tallysman.com T: +1 613 591-3131 www.tallysman.com
33-HC771-28 价格&库存
很抱歉,暂时无法提供与“33-HC771-28”相匹配的价格&库存,您可以联系我们找货
