TALLYSMAN - PART NUMBER ORDERING GUIDE
For all Embedded Antennas
Part Number Structure :
Assigned by Tallysman for
custom tuned antennas
Connector
33-aaaa-xx-yyyy-zz
Product
Valid Connectors
00 = SMA straight male (plug)
01 = TNC female
02 = MCX straight male (plug)
03 = MMCX straight male (plug)
04 = SMB straight male (plug)
05 = MCX right angle male (plug)
06 = MMCX right angle male (plug)
cable length in mm
10 = SMA Right Angle **
11 = Reverse polarity SMA**
12 = Waterproof SMA**
13 = SSMA **
20 = SMA Female 35 = MMBX (RG174 cable)**
22 = R/A QMA**
36 = MMBX (RG316 cable)**
23 = SMP**
37 = R/A male SMB**
24 = SMC Male
25 = SMC Straight Female
15 = TNC male (plug)
26 = SMB Straight Female
16 = N-Type Male**
27 = MCX Female Straight
17 = BNC Male**
28 = SSMCX Straight Plug**
08 = H.FL (female)** (micro-coax cable)
18 = FME**
29 = R/A SSMCX Plug **
09 = U.FL (micro-coax cable)
19 = MMCX Female
30 = SMB with Overmold**
33 = MMCX straight male (Cinch Connectivity) **
34x = FAKRA (replace “x” with colour code)**
Cable length tolerances: 5m: ±50mm
Maximum cable lengths: 5m for RG174 , 1450mm for micro-coax
** Premiums apply. Please check with your Distributor
For the TW2000 Family of Products
Connector
33-2aaa-xx-yyyy
Product
cable length in mm
Valid Connectors
Without Cable:
07 = SMA female (jack) bulkhead
With Cable (max length 5m):
01 = TNC female
13 = SSMA **
16 = N-Type Male**
17 = BNC Male**
18 = FME**
19 = MMCX Female
31 = SMC R/A Female **
22 = R/A QMA**
23 = SMP**
37 = R/A male SMB**
24 = SMC Male
33 = MMCX straight male (Cinch Connectivity)**
NOTE: To order any of the TW2000 antennas with NO MAGNETS, add “NM” after the Product (eg. 33-2410NM-00-3000).
To add Adhesive Tape to the bottom of the same, add “AT” after the Product Name (eg. 33-2410AT-07). If you desire both,
then use NMAT, eg. 33-2410NMAT-07.
Cable length tolerances: 5m: ±50mm Maximum cable length = 5m
Page 1 of 6
November 2019
For the TW3000 Family of Products
For TW3865, TW3870E, TW3872E, TW3967 & TW3972E - refer to Page 1 Embedded Antennas
Modifier
cable length in mm 4 digits (if applicable)
Connector
33-3aaabb-xx-yy-zzzz
Product
radome shape and colour
Valid Connectors
Without Cable:
01 = TNC female
14 = N-Type female
01 = TNC female
13 = SSMA **
16 = N-Type Male**
17 = BNC Male**
18 = FME**
19 = MMCX Female
NMO = NMO mount
20 = SMA Female
22 = R/A QMA**
23 = SMP**
24 = SMC Male
37 = R/A male SMB**
Modifiers: ST = short thread
AJ = Anti-Jamming configuration**
Radome Codes:
00 = Dark grey Conical 10 = Dark grey low profile 20 = Red low profile 01 = White Conical 11 = White low profile
For AJ Antennas: W = White G=Grey (For TW3142, TW3442, TW3742, and TW3752 only)
For the TW4000 Family of Products
Connector
33-4aaa-xx-yyyy
Product
Valid Connectors
01 = TNC female
cable length in mm (max length 5000mm)
13 = SSMA **
16 = N-Type Male**
17 = BNC Male**
18 = FME**
19 = MMCX Female
20 = SMA Female
22 = R/A QMA**
23 = SMP**
24 = SMC Male
25 = SMC Straight Female 37 = R/A male SMB**
NOTE: To order any of the TW4000 antennas with NO MAGNETS, add “NM” after the Product (eg.
33-4421NM-00-3000). To add Adhesive Tape to the bottom of the same, add “AT” after the Product Name (eg.
33-4421AT-00-3000). If you desire both, then add them together, eg. 33-4421NMAT-00-3000
Page 2 of 6
November 2019
For the TW5340 / TW5341
radome type and colour
33-534w- x-yy-zz
Product
Cable Length
w = Type 0 = standard 1 = non-magnetic
x = Voltage and interface: 1 = 5V, RS232 2 = 5V, CMOS 3 = 3.3V, CMOS 4 = 5V, RS232 6 = 12-36V, RS232
Radome Codes (yy):
01 = White Conical
11 = White low profileRa-
01 = White Conical
dome Codes (yy):
Cable Length (zz)
For the TW5342 / TW5242
For TW5342 : 33-5342-6-10-05 -ccc (ccc custom configuration to be assigned by Tallysman)
For TW5242: 33-5242-6-10-05 -ccc (ccc custom configuration to be assigned by Tallysman)
6 = 12-36V, RS232, 10 = Dark grey low profile radome 05 = 5m cable
For the VP6000 Family of Products
33-6abbcd-ee-gg
a = Covered Frequencies:
0 = All GNSS frequencies + L-Band (1525 - 1559 MHz)
2 = L1/L2, G1/G2, B1/B2, E1 + L-Band
3= L1/L2/L5, G1/G2/G3, B1/B2, E1/E5a+b
c = Base Type
0 = Standard base
d = Options
bb = LNA Gain
35 = 35dB
50 = 50dB
0 = No options
ee = connector types:
01 = TNC Female
14 = N-Type Female **
** Premiums apply. Please check with your Distributor.
gg = radome:
01 = White Conical
Example:
33-605000-01-11
11 = White Flat top
Is an antenna which covers all GNSS frequencies + L-Band, provides,
50 dB of gain, uses a standard base, with a TNC female connector and
a white flat top radome.
Page 3 of 6
November 2019
For the VC6000 Family of Products
Where x=
33-VC6xyy-zz
1 = All GNSS Signals
yy=
35 = 35dB amplifier
50 = 50dB amplifier
zz=
01 = TNC (f ) connector
14 = N-Type connector
PN for short SCIGN Radome = 24-0053-0
For Housed Helical Family of Products
Part Numbers :
HC600:
33-HC600
HC771:
33-HC771-28 (28dB LNA)
HC871:
33-HC871-28 (28dB LNA)
HC872:
33-HC872-28 ( for 28dB LNA) 33-HC872-35 (for 35dB LNA)
HC882:
33-HC882-28 ( for 28dB LNA) 33-HC882-35 (for 35dB LNA)
HC975:
33-HC975-28 ( for 28dB LNA) 33-HC975-35 (for 35dB LNA)
For Embedded Helical Family of Products
Part Numbers:
HC600E:
33-HC600E-xx-yyyy
HC771E:
33-HC771E-xx-yyyy
HC871E:
33-HC871E-28 -xx-yyyy (28dB LNA)
33-HC871E-35-xx-yyyy (35dB LNA)
HC872E:
33-HC872E-28-xx-yyyy (28dB LNA)
33-HC872E-35-xx-yyyy (35dB LNA)
HC882E:
33-HC882E-28-xx-yyyy (28dB LNA)
33-HC882E-35-xx-yyyy (35dB LNA)
HC975E:
33-HC975E-28-xx-yyyy (28dB LNA)
33-HC975E-35-xx-yyyy (35dB LNA)
Where xx= connector type (refer to Page 1 Embedded section for options)
Where yyyy = cable length in mm (refer to Page 1 Embedded section for options)
Page 4 of 6
November 2019
For the TW7000 Family of Products
Connector
33-7aaa-xx-yyyy
Product
cable length in mm
Valid Connectors
Without Cable:
01 = TNC female
13 = SSMA **
16 = N-Type Male**
17 = BNC Male**
18 = FME**
19 = MMCX Female
20 = SMA Female
22 = R/A QMA**
23 = SMP**
37 = R/A male SMB**
24 = SMC Male
NOTE: To order any of the TW7000 antennas with NO MAGNETS, add “NM” after the Product (eg.
33-7970NM-00-3000). To add Adhesive Tape to the bottom of the same, add “AT” after the Product Name (eg.
33-7970AT-07). If you desire both, then use NMAT, eg. 33-7970NMAT-07.
For the TW8000 Family of Products
Connector
33-8aaa-xx-yyyy
Product
Valid Connectors
01 = TNC female
13 = SSMA **
16 = N-Type Male**
17 = BNC Male**
18 = FME**
19 = MMCX Female
20 = SMA Female
22 = R/A QMA**
23 = SMP**
24 = SMC Male
NOTE: To order any of the TW8000antennas with NO MAGNETS, add “NM” after the Product (eg.
33-8829NM-00-3000). To add Adhesive Tape to the bottom of the same, add “AT” after the Product Name (eg.
33-8829AT-00-3000). If you desire both, then add them together, eg. 33-8829NMAT-00-3000
Page 5 of 6
November 2019
For the VeroStar Family of Products
Connector
33-60aa-xx-yz
Product
radome/base
Valid Connectors
01 = TNC female
Radome Codes (y):
W = White
Basae Codes (z):
R = Red
Page 6 of 6
November 2019
很抱歉,暂时无法提供与“33-2012-00-3000”相匹配的价格&库存,您可以联系我们找货
