TW164
TW164 1-to-4 Port Smart Power GNSS Signal Splitter
Frequency Coverage: Full GNSS Spectrum
Overview
The Tallysman TW164 is a profe ssional-grade full GNSS band signal splitte r that
connects one ante nna up to four re ce ive rs, and supports GPS/QZSS-L1/L2/L5, QZSS-L6,
GLONASS-G1/G2/G3, Be iDou-B1/B2/B2a/B3, Galile o-E1/E5a/E5b/E6, NavIC-L5, and LBand correction services.
GNSS has be come a critical compone nt in safe ty, se curity, timing, and
infrastructure applications, all of which re quire ve ry high availability. As a re sult,
re silie nt fault-tolerant components are essential to avoid service interruptions.
The design of first-generation GNSS signal splitters suffered from a single point of failure:
only one attache d re ce ive r powe re d the splitte r and the ante nna. If this re ce ive r faile d
or was unplugged, all attached receivers also failed.
Tallysman’s curre nt-ge ne ration TW164 Smart Powe r GNSS signal splitte r provide s
two additional key features:
First, it acce pts powe r from all attache d GNSS re ce ive rs and se le cts powe r from a
receiver using the following protocol. Port #1 is given priority if its voltage is within the
specified range (3.3 - 12.5 VDC). Howe ve r, if port #1’s re ce ive r is disconne cte d or if its
re ce ive r powe r goes below the under-voltage or above the over-voltage specification, the
TW164 will switch to the next port in numerical order, as long as its power and voltage are
within the expected range. The switching and port selection is, therefore, deterministic.
Second, if the antenna fails and does not draw current, the TW164 will provide all
connectors with a current draw lower than 1 mA, indicating an antenna fault.
The TW164 offe rs the be st in-class pe rformance in te rms of noise figure , isolation,
and linearity. In addition, it is packaged in a robust, compact, lightweight, and water-proof
(IP67) corrosion-protected aluminum housing.
The TW164 is available with e ithe r TNC or type -N conne ctors and offe rs standard gain
to compensate for signal-splittingloss.
It is recommended that unused ports should be terminated with a 50 Ohm load.
Applications
Features
Benefits
• GNSS signal distribution
• GNSS receiver testing
• High-availability applications
• Network and infrastructure timing
• Accepts power from all attached receivers
• Automatically switches on power failure of one receiver
• Antenna failure detection/indication
• Rugged military-grade aluminum enclosure
• Amplification to compensate for signal-splitting loss
• Very low noise figure
• IP67-compliant
• Allows up to four GNSS receivers to share a single antenna
• Fits in-line with antenna cable
• Robust package
• Ideal for harsh environments
About Tallysman: With global headquarters and manufacturing in Ottawa, Canada, Tallysman is a leading manufacturer of
high-precision antennas and components for Global Navigation Satellite System (GNSS) applications. Tallysman’s mission
is to support the needs of a new generation of positioning systems by delivering unprecedented antenna precision at
competitive prices. Learn more at www.tallysman.com
Revision:
1.0
Contact us:
info@tallysman.com
T: +1 613 591-3131
Frequency Coverage:
Full GNSS Spectrum
Electrical Specifications - Tested at 25°C unless othwerwise specified
Minimum
Typical
Maximum
Units
Frequency Range
Bandwidth supported
Conditions / Description
1100
1700
MHz
Gain
Measured within range: -40 °C to 85 °C
-1.0
0.0
1.0
dB
Impedance
50.0
Ω
Noise Figure
All Receiver Ports
3.6
4.0
dB
Output Isolation
42.0
dB
Input/Output SWR
1.3:1 | 1.1:1
1.5:1 | 1.2:1
ratio
Input Gain Compression Point (P1dB)
Gain = 0 dB
-20.0
-17.0
-14.0
dBm
3rd Order Intercept (IIP3)
Gain = 0 dB
-10.0
-7.0
-4.0
dBm
RF Input (Damage Threshold)
Maximum RF Input without damage
5.0
dBm
Amplitude Balance
Between Ports
0.1
0.5
dB
Phase Balance
Between Ports
2.0
5.0
degrees (°)
DC In
DC input on any port
3.3
12.5
VDC
Receiver Over-voltage
12.7
14.9
16.9
VDC
Receiver Under-voltage
2.3
2.5
2.8
VDC
Splitter Current
Current consumed by splitter
15.0
25.0
mA
Antenna Through Current
Maximum current provided to the antenna
230.0
mA
Antenna to Ports
1.0
1.4
2.0
ns
Adajcent Ports
0.0
0.3
0.5
ns
Opposite Ports
0.0
0.5
1.0
ns
Parameter
Group Delay Variation
Mechanical Diagram
Mechanicals
Size
117.0 mm (l.) x 111.6 mm (w.) x 38.0 mm (h.)
Weight
405 g (type-N connectors) or 280 g (TNC connectors)
Connectors
5x TNC (female) or 5x type-N (female)
Enclosure
military-grade corrosion-protected aluminum (6061-T6)
Evironmental
Operating Temperature
-40 °C to 85 °C
Storage Temperature
-50 °C to 95 °C
Vibration
Shock
Salt Fog
IEC 60529 - IP Rating
IEC-60529- IP67 (enclosure)
Compliance
RoHS, REACH and WEEE,
EN60950-1, RED / CE Certified
MIL-STD-810, FCC Part 15B and R&TTE equivalent.
Ordering Information
Warranty
Parts and Labour
3-year standard warranty
Part Number
32-0164-xx
where xx = connector: 14 = type-N (female) | 01 = TNC (female)
Please refer to our Ordering Guide to review available radomes and connectors at:
https://www.tallysman.com/resource/tallysman-ordering-guide/
© 2019 Tallysman Inc. All rights reserved. Tallysman, the “When Precision Matters” tag line and the Tallysman logo are trademarks or registered
trademarks of Tallysman Inc. and/or its affiliates in Canada and certain other countries. All other trademarks mentioned in this document are
the property of their respective owners. The information presented is subject to change without notice. Tallysman assumes no responsibility for
any errors or omissions in this document. Tallysman Wireless Inc. hereby disclaims any or all warranties and liabilities of any kind.
Revision:
1.0
www.tallysman.com
很抱歉,暂时无法提供与“32-0164-14”相匹配的价格&库存,您可以联系我们找货
