2PG010DxC11N Datasheet
Gate Driver Unit 2PG010DxC11N
■Overview
2PG010DxC11N is a dual channel gate driver designed for Fuji Electric's IGBT
power module 2MBI1800XXF170-50 .
This gate driver unit contains a built-in isolated DC/DC converter and gate drive circuit.
It is ready to use by mounting it on the IGBT power module.
■Features
・Ideal for drive of IGBT Power module 2MBI1800XXF170-50(Fuji Electric)
・Gate voltage : +15V/-10V
・Gate resistor : +0.22Ω/-1.5Ω(TYP)
・Short circuit detection voltage : 9.5V(TYP)
・ALL-IN-ONE (Built-in isolated DC / DC converter and gate drive circuit)
・Low parasitic capacitance (12pF(TYP)) ; highly resistant to common-mode noise.
・Fast response : About 130nsec(typ)
・The isolation for primary-secondary signal used fast response isolator.
・Dielectric withstand voltage : AC5000V
・Insulation distance (clearance / creepage) : 14mm/16mm (As for Gate driver PCB)
・DC/DC converter input voltage : 13~28V
・Power supply for gate driver input voltage : 13~28V
・Signal input voltage : 3.3V~15V or 15V
・The DC / DC converter has built-in overheat protection and overload protection.
・Desaturation protection (Gate drive circuit)
・Soft turn-off function (Gate drive circuit)
・Fault signal output function (Gate drive circuit)
・Under-voltage lockout(UVLO) (Gate drive circuit)
・Direct mode / Half bridge mode can be switched. (Gate drive circuit)
・Active clamp protection function ( Gate drive circuit)
・Safety standards:UL508(file no.E243511) (DC/DC converter only)
・Reinforced isolation according to IEC 60664-1 (IEC61800-5-1, IEC62477-1, IEC62109-1, etc.)
・UL compliant (UL1741, UL508, etc.)
・Insulating moistureproof coating
■Application
Industrial inverter, power conditioner, etc. …
■Module information
Part number
Part number (Uncoated) Signal input voltage
Active clamp
Status
2PG010DCC11N
2PG010DCN11N
3.3 to 15V
Yes
Active
2PG010DDC11N
2PG010DDN11N
15V
Yes
Active
*Uncoated type is sample only
1 / 7
TAMURA CORPORATION
TMRDM0050EN
Rev.2.01 Nov, 2021
■Circuit Image
Product
Power supply (VIN+, VCC)
Connecter
Power module
9,11
CN101
Pull-up resistor
1,3 VIN(+)
C1 5
2,4 VIN(-)
G1 4
5,7 VCC
6,8 GND
9 ALM1
10 GND
11 INB
12 GND
13 ALM2
14 GND
15 INA
16 GND
17 MOD
18 GND
19 RTC
20 GND
Alarm output (High-side Gate)
Signal input (High-side Gate)
Alarm output (Low-side Gate)
Signal input (Low-side Gate)
Ground (VIN-, GND)
C2E1 3
5
4
3
8
G2 1
E2 2
1
2
6
7
Lead
10,12
■Pin Connection
CN101 : RA-H201SD (JST)
Pin No.
Name
Function
Pin No.
Name
Function
1
VIN(+) Power supply for DC/DC converter(+)
2
VIN(-) Power supply for DC/DC converter(-)
3
4
5
VCC
Power supply for drive circuit
6
GND
Ground for drive circuit
7
VCC
8
GND
Alarm signal output 1 (High side)
10
GND
Control input B (High side)
12
GND
9
ALM1
11
INB
13
ALM2
Alarm signal output 2 (Low side)
14
GND
15
INA
Control input A (Low side)
16
GND
17
MOD
Mode select
18
GND
19
RTC
Recovery time of protection circuit control
GND
※Reference receptacle : RA-S201T (JST)
Connection on the power module
Pin No.
Name
1
G2
2(L) Gate connection, Low side
2
E2
2(L) Emitter connection, Low side
3
C2E1
1(H) Emitter connection, High side
4
G1
1(H) Gate connection, High side
5
C1
1(H) Collector connection, High side
2 / 7
CH
Function
TAMURA CORPORATION
TMRDM0050EN
Rev.2.01 Nov, 2021
■Internal Block Diagram
CN101
VIN+
VINVCC
5 C1
ALM1
Logic
Isolator
INB
MOD
Direct/
Half-bridge
RT C
Timer
Driver
DESAT
VO H
VO L
STO
OUT(H)
ACL
OUT(L)
Rg(ON)
4 G1
Rg(OFF)
Rsto
Cge
3 C2E1
DC/DC
2DDxxxxxxC
OUT(H)
OUT(L)
ALM2
Isolator
INA
DESAT
VO H
VO L
STO
ACL
Rg(ON)
1 G2
Rg(OFF)
Rsto
Cge
2 E2
Driver
GND
■I/O Condition Table
No.
Status
Input
OUT(H)
C1(H) C2(L)
1
VOUTUVLO UVLO
X
X
2
G-E short
Output
MOD INB
INA ALM1 ALM2 G1(H) G2(L)
X
X
X
L
L
L
L
X
X
X
X
X
L
L
SD
SD
3
L
H
L
Hi-Z
L
4
L
H
H
Hi-Z
H
5
L
H
L
Hi-Z
L
L
H
H
Hi-Z
H
L
L
L
L
X
Hi-Z Hi-Z
L
L
8
L
L
L
H
L
Hi-Z Hi-Z
H
L
9
L
L
L
H
H
Hi-Z Hi-Z
L
H
6
7
Normal
operation
10
Short
Hi-Z
H
L
Hi-Z
L
11
circuit
Hi-Z
H
H
L
L
12
detection
Hi-Z
L
H
L
Hi-Z
L
13
(L)
Hi-Z
L
H
H
L
L
14
Short
Hi-Z
H
L
Hi-Z
L
15
circuit
Hi-Z
H
H
L
L
16
detection
Hi-Z
L
H
H
Hi-Z
L
17
(H)
Hi-Z
L
H
L
L
L
G-E short : Gate-Emitter short
○ : OUT(H) > UVLO, X : Don't care
SD: Shut down (Gate-Emitter short)
3 / 7
TAMURA CORPORATION
TMRDM0050EN
Rev.2.01 Nov, 2021
■Absolute Maximum Ratings
Symbol
Min
Max
Unit
Input voltage for DC/DC converter
Item
VIN
-0.3
28
Vdc
Between VIN(+) to VIN(-)
Input voltage for Gate driver
VCC
-0.3
28
Vdc
Between VCC to GND
VSG
-0.3
VMOD
-0.3
28
V
MOD
VRTC
-0.3
5
V
RTC
Excluding gate resistor
Input-side signal voltage
Maximum gate current
VCC+0.3
or 18 *
V
IGPEAK
43
A
Switching frequency
FSW
kHz
Short circuit detection pin voltage
VSD
V
VCC+0.3
Alarm signal output pin maximum voltage
VALM
-0.3
Input-side signal maximum current
IALM
5
mA
VIN=13.5-18V
TOP
-40
85
VIN=18-26.4V
TOP
-40
75
Operating temperature range
or 28 *
V
Operating humidity
RHOP
%RH
Storage temperature range
TSTG
-40
90
RHSTG
5
95
%RH
Storage humidity
Conditions・Note
INA, INB
*Whichever is less
See the permissible frequency curve
ALM1,2
*Whichever is less
ALM1,2
No condensation
No condensation
■Recommended Operating Conditions
Item
Symbol
Min
Max
Unit
Input voltage range for DC/DC converter
VIN
13.5
26.4
Vdc
Input voltage range for gate driver
VCC
13.5
26.4
Vdc
N
2
Maximum gate charge
QG
14000
nC
*1
Switching frequency (Qg=12500nC)
FSW
8.8
kHz
MOD pin high input voltage
VMODH
3.3
26.4
V
MOD pin low input voltage
VMODL
-0.3
0.5
V
Logic high level input voltage
VSGH
3.3
Logic low level input voltage
VSGL
-0.3
0.5
V
ISG
3.2
mA
VSGH
13
VSGL
-0.3
0.5
V
ISG
3.3
mA
VDC-LINK
1100
V
Driver circuit number
Conditions・Note
2PGxxxxCx11N
Source current of control signal
VCC+0.3
or 16 *
V
INA, INB
*Whichever is less
INA, INB
INA, INB VSG=15V
2PGxxxxDx11N
VCC+0.3
or 16 *
V
INA, INB
*Whichever is less
INA, INB
INA, INB VSG=15V
For 2PGxxxDxx11N(Active clamp model)
DC-link voltage
*2
*1 If the gate charge exceeds the allowable value, the gate voltage at turn-on and turn-off will drop, which may affect the switching
performance of the IGBT.
If you are considering using it under conditions other than the recommended conditions, please contact us.
*2 Use below the recommended DC link voltage.
4 / 7
TAMURA CORPORATION
TMRDM0050EN
Rev.2.01 Nov, 2021
■Permissible frequency curve
Internal gate resistor of IGBT = 2.08Ω
*The permissible frequency curve changes with the ratio of the IGBT internal gate resistance to the gate resistance.
Therefore, as the internal resistance of the IGBT decreases, the allowable frequency also decreases.
Total gate charge (Qg) vs permissible frequency curve
Rg: +0.22/-1.5Ω
15
[kHz]
Maximum switching frequency
Ta:-40~+85℃ / VIN = 13.5~18V
10
Ta:-40~+75℃ / VIN = 18~26.4V
5
6000
8000
10000
12000
14000
Gate charge Qg [nC]
Rg: +0.22/-5.1Ω
■Electrical Specification (Vin=Vcc=15V, Ta=25℃,
Unless otherwise specified)
15Item
Symbol
Min
Typ
Max
Unit
VSTART
11.5
12.5
V
0.5
0.5
1.3
Conditions・Note
[kHz]
DC/DC converter
10
Start-up voltage
Input current
IIN
5
Standby power
Logic inputs
for
PSTBY
A
Fsw=8.8kHz, Test load : 2.15Ω/500nF
Fsw=10kHz, Test load : 2.15Ω/440nF
W
No load
2PGxxxxCx11N
4000
6000
Logic pull-down resistance
8000
VSGH
10000
12000
14000
V
INA, INB / Guaranteed by design
VSGL
1
1.2
V
RSGD
4700
Ω
INA, INB
Gate charge Qg [nC]
2.1
2.3
Logic inputs for 2PGxxxxDx11N
VSGH
10.4
11.4
V
VSGL
4.9
5.9
V
RSGD
4500
Ω
INA, INB
Gate driver output
Output pin voltage(High)
VOUTH
14
15
16
V
No load
Output pin voltage(Low)
VOUTL
-11
-10
-9
V
No load
Gate resistor
Auxiliary gate capacitor
Delay time
Dead time
5 / 7
Turn ON time
Turn OFF time
Rg(ON)
0.22
Rg(OFF)
1.5
Cge
OPEN
nF
tPON
130
ns
tPOFF
130
ns
tDEAD
3
us
Ω
TAMURA CORPORATION
Half bridge mode
TMRDM0050EN
Rev.2.01 Nov, 2021
■Protection
Item
Symbol
Min
Typ
Max
Unit
Conditions・Note
Overload protection
10.5
W
Auto recovery
Overheat protection
120
150
Auto recovery, Internal temperature
Output voltage(H) UVLO OFF voltage VUVLOOHH
13.2
13.5
13.8
V
Output voltage(H) UVLO ON voltage VUVLOOHL
12.2
12.5
12.8
V
DC/DC converter
Gate driver
9.5
V
Short circuit detection filter time tSHORTFIL
VSD
4.5
us
Collector open
Alarm signal output L voltage
VALML
0.5
V
IALM=5mA
tALM
0.2
us
Alarm signal output time
Restart time
tRESTART
110
ms
Soft turn-off resistance
RSTO
12
Ω
Soft turn-off duration
tSTO
4
us
■Insulation
Item
Specification
Conditions・Note
Between Input-Output
AC5000V
1min, Cutoff 2mA
Insulation resistance
100MΩ or more
DC500V
Partial discharge extinction voltage
1768Vpeak or more
According to EN50178/IEC 60270
Common-mode transient immunity (CMTI) 70kV/us
Minimum clearance distances
14mm
Minimum creepage distances
16mm
Between CH1-CH2
8mm
12mm
■Storage Conditions
Item
Storage temperature
6 / 7
Min
Max
Unit
-25
60
Conditions・Note
A packing state
TAMURA CORPORATION
TMRDM0050EN
Rev.2.01 Nov, 2021
■Usage Cautions
● Always mount fuse on the plus side of input for ensuring safety because the fuse is not built-in the product.
Please select the fuse considering conditions such as steady current, inrush current, and ambient temperature.
When using a fuse having large rated current or high capacity input electrolytic condenser, by combining
another converter and input line and input electrolytic condenser, fuse may not blow off in the case of abnormality.
Do not combine high voltage line and fuse.
● Make sure the rise/fall time of the input signal is 500ns or less.
Also, keep input wiring as far as possible from noise sources.
To prevent malfunction due to noise, we recommend the highest possible signal voltage within the recommended range.
● Please do not apply excessive stress to this product when attaching to IGBT power module.
Please follow the device manufacturer's instructions on how to install the IGBT power module
(type of screw used, material, tightening torque conditions, etc.).
Also, if the product is exposed to vibration or shock, the PCB should be fixed with spacers as shown in the figure below.
The screw header / washer diameter uses the following.
・M3 (Printed circuit board fixed) : 7mm or less
・M4 (Connection on the power module) : 9mm or less
*To maintain the reliability of parts near the metal terminal pad,
the screw header including the washer must not exceed the available
metal terminal pad of the gate driver.
● This product has DESAT protection for arm short circuit and load short circuit protection.
However, even if this protection works, the IGBT may be damaged if abnormally high current occurs due to IGBT's characteristics
variations or the load short-circuit mode during parallel operation.
To ensure safety, be sure to check the short-circuit current at the unit in which this product is integrated,
and evaluate whether it can protect under the condition that there is no damage to the IGBT.
● The coating material is applied to the product, so it may appear to be partially whitened.
This does not affect the characteristics of the product.
7 / 7
TAMURA CORPORATION
TMRDM0050EN
Rev.2.01 Nov, 2021
2PG Series Outline Drawing
■Outline Dimensional Drawing
Unit: mm
Note: 1. The dimensional tolerance without directions is ± 0.5mm.
■Product Weight
81.0g(typ)
1 / 1
TAMURA CORPORATION
TMRDM0059EN
Rev.1.01 Nov, 2021
Important Notice
■Important Notice
● This information and product are subject to change without prior notice for the purpose of improvements, etc.
Ensure that you are in possession of the most up-to-date information when using this product.
● The operation examples and circuit examples shown in this document are for reference purposes only, and TAMURA Corporation disclaims
all responsibility for any violations of industrial property rights, intellectual property rights and any other rights owned by TAMURA Corporation
or third parties that these may entail.
● The circuit examples and part constants listed in this document are provided as reference for the verification of
characteristics. You are to perform design, verification, and judgment at your own responsibility, taking into account the various conditions.
● TAMURA has evaluated the efficiency and performance of this product in a usage environment determined by us.
Depending on your usage environment or usage method, there is the possibility that this product will not perform sufficiently as shown in
the specifications, or may malfunction.
When applying this product to your devices or systems, please ensure that you conduct evaluations of their state when integrated with
this product. You are responsible for judging its applicability.
TAMURA bears no responsibility whatsoever for any problems with your devices,
systems or this product which are caused by your usage environment or usage method.
● TAMURA Corporation constantly strives to improve quality and reliability, but malfunction or failures are bound to occur with some
probability in power products. To ensure that failures do not cause accidents resulting in injury or death, fire accidents, social damage,
and so on, you are to thoroughly verify the safety of their designs in devices and/or systems, at your own responsibility.
● This product is intended for use in consumer electronics (electric home appliances, business equipment, Information equipment, communication
terminal equipment, measuring devices, and so on.) If considering use of this product in equipment or devices that require high reliability
(medical devices, transportation equipment, traffic signal control equipment, fire and crime prevention equipment, aeronautics and space
devices, nuclear power control, fuel control, in-vehicle equipment, safety devices, and so on), please consult a TAMURA sales representative
in advance. Do not use this product for such applications without written permission from TAMURA Corporation.
● This product is intended for use in environments where consumer electronics are commonly used.
It is not designed for use in special environments such as listed below, and if such use is considered,
you are to perform thorough safety and reliability checks at your own responsibility.
・ Use in liquids such as water, oil, chemical solutions, or organic solvents, and use in locations
where the product will be exposed to such liquids.
・ Use that involves exposure to direct sunlight, outdoor exposure, or dusty conditions.
・ Use in locations where corrosive gases such as salt air, C12, H2S, NH3, SO2, or NO2, are present.
・ Use in environments with strong static electricity or electromagnetic radiation.
・ Use that involves placing inflammable material next to the product.
・ Use of this product either sealed with a resin filling or coated with resin.
・ Use of water or a water soluble detergent for flux cleaning.
・ Use in locations where condensation is liable to occur.
● This product is not designed to resist radiation.
● This product is not designed to be connected in series or parallel.
Do not operate this product in a series, parallel, or N+1 redundant configuration.
● Do not use or otherwise make available the TAMURA products or the technology described in this document for any military purposes,
including without limitation, for the design, development, use, stockpiling or manufacturing of mass destruction weapons
(e.g. nuclear, chemical, or biological weapons or missile technology products).
When exporting and re-exporting the products or technology described in this document, you should comply with the applicable export
control laws and regulations and follow the procedures required by such laws and regulations including, without limitation,
Japan -Foreign Exchange and Foreign Trade Control Law and U.S.- Export Administration Regulations.
The TAMURA products and related technology should not be used for or incorporated into any products or systems whose manufacture,
use, or sale is prohibited under any applicable domestic or foreign laws or regulations.
● Please contact your TAMURA sales office for details as to environmental matters such as the RoHS compatibility of product.
Please use TAMURA products in compliance with all applicable laws and regulations that regulate the inclusion or use of controlled substances,
including without limitation, the EU RoHS Directive.
TAMURA assumes no liability for damages or losses occurring as a result of your noncompliance with applicable laws and regulations.
● TAMURA assumes no liability for damages or losses incurred by you or third parties as a result of unauthorized use of TAMURA products.
● This document and any information herein may not be reproduced in whole or in part without prior written permission from TAMURA.
1 / 1
TAMURA CORPORATION
TMRDM0055EN
Rev.1.01 June, 2021
