PRODUCT SPECIFICATION
Product Name
1608 SMD POWER INDUCTORS - SHIELDED TYPE
TAMURA Part No.
TS1608-XXX
Page
1
Rev. No.
1. CONFIGURATION & DIMENSIONS :
A
101
MARKING
INDUCTANCE CODE
C
B
F
4.45 MAX
6.60 MAX
2.92 MAX
1.02±0.2
1.27±0.2
4.32±0.3
4.06 REF.
3.56 REF.
1.40 REF.
m/m
m/m
m/m
m/m
m/m
m/m
m/m
m/m
m/m
D
E
H
D
A
B
C
D
E
F
G
H
I
I
G
I
PCB PATTERN
2. SCHEMATIC DIAGRAM :
3. GENERAL SPECIFICATION :
a) TEMP. RISE : 40°C MAX.
b) RATED CURRENT : BASE ON TEMP. RISE &
L / LOA=10% MAX.
c) STORAGE TEMP. :-40°C ----+105°C
d) OPERATING TEMP. : -25°C----+85°C
e) RESISTANCE TO SOLDER HEAT : 260°C FOR 10 SECS.
TAMURA
Product Name
TAMURA Part No.
TS1608-XXX
Page
2
Rev. No.
4. ELECTRICAL CHARACTERISTICS :
TS1608-1R0M
1.0±20%
30
100K
200K
SRF
( MHZ )
TYP.
250
TS1608-1R5M
1.5±20%
30
100K
200K
125
0.045
2.8
TS1608-2R2M
2.2±20%
40
100K
200K
120
0.050
1.8
TS1608-3R3M
3.3±20%
40
100K
200K
120
0.055
1.6
TS1608-4R7M
4.7±20%
40
100K
200K
105
0.060
1.4
TS1608-6R8M
6.8±20%
40
100K
200K
50
0.065
1.2
TS1608-100M
10.0±20%
40
100K
200K
38
0.075
1.0
TS1608-150M
15.0±20%
40
100K
100K
33
0.090
0.80
TS1608-220M
22.0±20%
40
100K
100K
25
0.110
0.70
TS1608-330M
33.0±20%
40
100K
100K
0.60
TS1608-470M
47.0±20%
40
100K
100K
0.50
TS1608-680M
68.0±20%
40
100K
100K
15
0.290
0.40
TS1608-101M
100.0±20%
40
100K
100K
10
0.480
0.30
TS1608-151M
150.0±20%
40
100K
100K
9
0.590
0.26
TS1608-221M
220.0±20%
40
100K
100K
6
0.770
0.22
TS1608-331M
330.0±20%
40
100K
100K
5
1.400
0.20
TS1608-471M
470.0±20%
40
100K
100K
4
1.800
0.19
TS1608-681M
680.0±20%
40
100K
100K
3
2.200
0.18
TS1608-102M
1000.0±20%
40
100K
100K
2
3.400
0.15
TS1608-152M
1500.0±20%
50
100K
100K
2
4.200
0.12
TS1608-222M
2200.0±20%
50
100K
100K
2
8.500
0.10
TS1608-332M
3300.0±20%
50
100K
100K
1
11.000
0.08
TS1608-472M
4700.0±20%
50
100K
100K
1
13.900
0.06
TS1608-682M
6800.0±20%
50
100K
100K
1
25.000
0.04
TS1608-103M
10000.0±20%
50
100K
100K
0.8
32.800
0.02
TAMURA Part No.
INDUCTANCE
Q
( µH )
MIN.
TEST FREQ. ( HZ )
L
Q
TAMURA
RDC
( Ohm )
MAX
0.040
IDC
(A)
MAX
3.0
Product Name
TAMURA Part No.
TS1608-XXX
Page
3
Rev. No.
RECOMMENDED SOLDERING CONDITIONS
REFLOW SOLDERINGS
10 seconds max.
Soldering 230°C
200°C
Preheating Temperature
100 to 150°C
2 minutes min.
30 seconds max.
5. PACKAGING INFORMATION :
D
N
A
B
T
G
P:8 m/m
*CARRIER TAPE WIDTH : D
4 m/m
101
101
101
101
101
101
101
101
( 2 ) DIMENSIONS
Unit:m/m
STYLE
A
B
C
D
G
N
13 - 12
330
21
13
12
12.4
100 MIN
T
18.4
( 3 ) Q'TY & G.W. PER PACKAGE
INNER : REEL
SERIES
TS1608
OUTER : CARTON
Q'TY (PCS)
G.W. (gw)
STYLE
Q'TY (PCS)
G.W. (Kg)
SIZE (cm)
2,500
825
13 - 12
30,000
10.5
40 x 20 x 26
TAMURA
Product Name
TAMURA Part No.
TS1608-XXX
Page
4
Rev. No.
6. Part No. FORMAT :
T
S
1
6
TOLERANCE CODE
INDUCTANCE CODE
SIZE
TYPE CODE
TAMURA PREFIX
TAMURA
Product Name
TAMURA Part No.
TS1608-XXX
Page
5
Rev. No.
7. RELIABILITY TEST :
TEST ITEM
SPECIFICATION
TEST CONDITION
SOLDERABILITY
MORE THAN 90% OF THE
TERMINAL ELECTRODE
SHALL BE COVERED
WITH FRESH SOLDER.
PREHEAT : 125±25°C FOR 60 SECONDS
SOLDER : H63A ( EUTECTIC SOLDER )
SOLDER TEMP. : 230±5°C
FLUX : ROSIN
DIP TIME : 4±1 SECONDS
INDUCTANCE SHALL
NOT CHANGE MORE
THAN ±20%
ROOM TEMP.
15 MINUTES
-25±2°C
30 MINUTES
ROOM TEMP.
15 MINUTES
85±2°C
30 MINUTES
THERMAL SHOCK
TEST
( TEMP. CYCLE )
TOTAL : 50 CYCLES
HUMIDITY
RESISTANCE TEST
TEMPERATURE : 40±2°C
HUMIDITY : 90 ~ 95%
APPLIED CURRENT : PER SPEC.
TIME : 500 HOURS
HIGH TEMP.
RESISTANCE TEST
TEMPERATURE : 85±2°C
TIME : 500 HOURS
TAMURA
很抱歉,暂时无法提供与“TS1608-471M”相匹配的价格&库存,您可以联系我们找货
