SPECIFICATION
Part No.
Product Name
Features
WMA.01. 301151
Trinity 3dBi 2.42.5GHz MIMO
Antenna
Wi-fi/ISM Bands/ZigBee/WLAN/Bluetooth
Connectors x 3 RP-SMA (M) –
3M RG-174
Omni-directional
Flexible Mounting
- Desktop
- Wall mount
- Magnet Mount
- Adhesive Mount
IEEE.802.11/IEEE.802.15
IP65 Water Resistant
RoHS Compliant
SPE-12-8-117/B/SS
Page 1 of 16
1. Introduction
The Trinity MIMO antenna is a powerful 3*3 3dBi External 2.4GHz omnidirectional antenna to enable high-speed data throughput. 3 individual highgain elements ensure maximum coverage through diversity. Desk-top
placement, magnet-mounting, wall-mounting, adhesive mounting are all
options. The individual antennas can articulate horizontally and vertically for
best signal reception depending on mounting conditions.
Many module manufacturers specify peak gain limits for any antennas that
are to be connected to that module. Those peak gain limits are based on
free-space conditions. In practice, the peak gain of an antenna tested in freespace can degrade by at least 1 or 2dBi when put inside a device. So ideally
you should go for a slightly higher peak gain antenna than mentioned on the
module specification to compensate for this effect, giving you better
performance.
Upon testing of any of our antennas with your device and a selection of
appropriate layout, integration technique, or cable, Taoglas can make sure
any of our antennas’ peak gain will be below the peak gain limits. Taoglas
can then issue a specification and/or report for the selected antenna in your
device that will clearly show it complying with the peak gain limits, so you
can be assured you are meeting regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have
less than 2dBi peak gain, but you don’t need to select an embedded antenna
that has a peak gain of less than 2dBi in free-space. This will give you a less
optimized solution. It is better to go for a slightly higher free-space peak gain
of 3dBi or more if available. Once that antenna gets integrated into your
device, performance will degrade below this 2dBi peak gain due to the effects
of GND plane, surrounding components, and device housing. If you want to
be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas
antenna with a higher peak gain than what is specified by the module
manufacturer and enlisting our help will ensure you are getting the best
performance possible without exceeding the peak gain limits.
The cables are shipped bonded together for easy cable management. The
standard connector option of RP-SMA plugs into AP router equipment. Other
cable and connector options are available on request.
DESKTOP / MAGNET MOUNT
SPE-12-8-117/B/SS
Page 2 of 16
Standard Desktop and Magnet Mount Configuration
Dipole Elements can be positioned
Magnets on Base
SPE-12-8-117/B/SS
Page 3 of 16
WALL MOUNT
Standard Configuration
Alternative Configuration
Screw-Holes on Base for Easy Wall-Mounting
(3M Adhesive can be supplied as option)
1. Screw - Cross Pan Head
For Plastic Tapping Thread
(ø3.5*16L)
2. Wall Plug - Plastic
SPE-12-8-117/B/SS
Page 4 of 16
2. Electrical Specifications
Parameter
Specification
Frequency Range
2.4~2.5GHz
Impedance
50Ω
VSWR
1.92:1 Max.
Return Loss
-10dB Max
Radiation Pattern
Omni
Gain(Peak)
3dBi (excluding cable loss)
Cable Loss
5.7dB Max.
Polarization
Linear; Vertical
Power Handling
10W
Cable
RG-174 Coaxial cable
Connector
3 x RP-SMA(M)
2.1 Mechanical Specifications
Parameter
Specification
Base Dimensions
93mm Width * 105mm Length * 31mm Height
Antenna Elements
132mm Length
Antenna Body
TPE
Antenna Base
PC
Antenna Base
PBT
Operating Temperature
-40°C to +85°C
Storage Temperature
-40°C to +85°C
Color
Black
SPE-12-8-117/B/SS
Page 5 of 16
3. Technical Drawing
SPE-12-8-117/B/SS
Page 6 of 16
3.1 Connector Drawing
SPE-12-8-117/B/SS
Page 7 of 16
4. Performance
Return Loss and Isolation of Left and Middle Antenna
SPE-12-8-117/B/SS
Page 8 of 16
Return Loss and Isolation of Right and Middle Antenna
SPE-12-8-117/B/SS
Page 9 of 16
Return Loss and Isolation of Left and Right Antenna
SPE-12-8-117/B/SS
Page 10 of 16
Return Loss, Smith Chart and VSWR of Left Antenna
SPE-12-8-117/B/SS
Page 11 of 16
Return Loss, Smith Chart and VSWR of Middle Antenna
SPE-12-8-117/B/SS
Page 12 of 16
Return Loss, Smith Chart and VSWR of Right Antenna
SPE-12-8-117/B/SS
Page 13 of 16
H-Plane Radiation Pattern of Left Antenna
SPE-12-8-117/B/SS
Page 14 of 16
H-Plane Radiation Pattern of Middle Antenna
SPE-12-8-117/B/SS
Page 15 of 16
H-Plane Radiation Pattern of Right Antenna
SPE-12-8-117/B/SS
Page 16 of 16
很抱歉,暂时无法提供与“WMA.01.301151”相匹配的价格&库存,您可以联系我们找货
