TapeCase Ltd.
150 Gaylord St, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Super Slick Tape Made with Teflon PTFE
2045-10
Product Description
2045-10 is manufactured from skived PTFE (polytetraflouroethylene) film coated with hightemperature silicone adhesive.
Application Information
2045-10 is often used as an excellent release surface on packaging equipment and heat sealing
machines, roll coverings on plastic extenders, guide rails, and angle bars in the graphic arts
industry.
Technical Properties
Property
Characteristic
Backing Material
Film-PTFE
Adhesive Type
Silicone
Total Thickness (in.)
0.0115
Backing Thickness (in)
0.0100
Adhesive Thickness (in.)
0.0015
Adhesion to Steel (oz/in)
50
Tensile Strength (lbs/in)
60
Dielectric Strength (volts)
19500
Elongation (% at break)
450
Operating Temperature (F) -100 to 500
Color
Gray
Features/ Benefits
One side of 2045-10 has a silicone pressure sensitive adhesive and the other side offers a low
coefficient of friction PTFE film, which is thin and conformable. PTFE backing offers excellent
high temperature resistance and is chemically inert. 2042-10’s tape construction is stable and
non-toxic.
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as
powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes
9/2/16
很抱歉,暂时无法提供与“10-18-2045-10”相匹配的价格&库存,您可以联系我们找货
