2-5-2045-5
    TAPECASE
    2045-5 GRAY SUPER SLICK TAPE MAD
2-5-2045-5 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Super Slick Tape Made with Teflon PTFE 2045-5 Product Description 2045-5 is manufactured from skived PTFE (polytetraflouroethylene) film coated with hightemperature silicone adhesive. Application Information 2045-5 is often used as an excellent release surface on packaging equipment and heat sealing machines, roll coverings on plastic extenders, guide rails, and angle bars in the graphic arts industry. Technical Properties Property Characteristic Backing Material Film-PTFE Adhesive Type Silicone Total Thickness (in.) 0.0065 Backing Thickness (in) 0.005 Adhesive Thickness (in.) 0.0015 Adhesion to Steel (oz/in) 40 Elongation (% at break) 400 Operating Temperature (F) -100 to 500 Color Gray Dielectric Strength (volts) 13000 Features/ Benefits One side of 2045-5 has a silicone pressure sensitive adhesive and the other side offers a low coefficient of friction PTFE film, which is thin and conformable. PTFE backing offers excellent high temperature resistance and is chemically inert. 2042-03’s tape construction is stable and non-toxic. NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
2-5-2045-5 价格&库存
很抱歉,暂时无法提供与“2-5-2045-5”相匹配的价格&库存,您可以联系我们找货
