0.75-5-403-5BNC (PK5)
    TAPECASE
    403-5BNC BLACK ANTISTATIC UHMW P
0.75-5-403-5BNC (PK5) 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Antistatic UHMW Polyethylene Tape 403-5 BNC Product Description This product is a pressure sensitive tape using a black, non-conductive ultra high molecular weight (UHMW) polyethylene film with an aggressive elastomeric adhesive. The UHMW film provides an excellent low friction, non-stick surface, in many ways similar to PTFE. The film has a very high tensile strength and very tough and abrasion resistant. Application Information These tapes are used primarily in mechanical applications such as chute liners, wear pads and guide rails. They are also used as guide surfaces or pads on such items as a computer mouse. Technical Properties Property Backing Material Backing Thickness (in) Adhesive System Adhesive Thickness (in) Adhesion (oz/in) Tensile Strength (lb/in) Elongation (%) Max Operating Temperature (F) Test Method ASTM-D-1000 ASTM-D-3759 ASTM-D-3759 Characteristic Black UHMW Film 0.005 Elastomeric 0.005 90 30 300 200 NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
0.75-5-403-5BNC (PK5) 价格&库存
很抱歉,暂时无法提供与“0.75-5-403-5BNC (PK5)”相匹配的价格&库存,您可以联系我们找货
