11-5-423-10
    TAPECASE
    423-10 WHITE STRONG & SLIPPERY U
11-5-423-10 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Strong & Slippery UHMW Polyethylene Tape 423-10 Product Description This product is a pressure sensitive tape using Ultra High Molecular Weight Polyethylene (UHMW) film with an aggressive permanent acrylic adhesive. The UHMW film provides an excellent low friction, non-stick surface in many ways similar to PTFE. The film has a very high tensile strength and is very tough and abrasion resistant. Application Information This tape has two primary applications in automotive and mechanical. The 423 series has passed a series of automotive tests for use by GM, Ford and Daimler-Chrysler. Mechanical applications include chute liners, wear pads and guide rails. Technical Properties Property Backing Material Backing Thickness (in) Adhesive System Adhesive Thickness (in) Adhesion (oz/in) Tensile Strength (lb/in) Elongation (%) Dielectric Strength (volts) Max Operating Temperature (F) Automotive Specification Automotive Specification Automotive Specification Test Method ASTM-D-1000 ASTM-D-3759 ASTM-D-3759 ASTM-D-149 Characteristic UHMW Film 0.010 Acrylic 0.0018 50 60 300 7500 200 Chrysler MS-CH612 Ford ESB-M3G123B GM 6419M Pass Pass Pass NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
11-5-423-10 价格&库存
很抱歉,暂时无法提供与“11-5-423-10”相匹配的价格&库存,您可以联系我们找货
