TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Strong & Slippery UHMW Polyethylene
Tape
423-5
Product Description
This product is a pressure sensitive tape using Ultra High Molecular Weight Polyethylene
(UHMW) film with an aggressive permanent acrylic adhesive. The UHMW film provides an
excellent low friction, non-stick surface in many ways similar to PTFE. The film has a very high
tensile strength and is very tough and abrasion resistant.
Application Information
This tape has two primary applications in automotive and mechanical. The 423 series has passed
a series of automotive tests for use by GM, Ford and Daimler-Chrysler. Mechanical applications
include chute liners, wear pads and guide rails.
Technical Properties
Property
Backing Material
Backing Thickness (in)
Adhesive System
Adhesive Thickness (in)
Adhesion (oz/in)
Tensile Strength (lb/in)
Elongation (%)
Dielectric Strength (volts)
Max Operating Temperature
(F)
Automotive Specification
Test Method
ASTM-D-1000
ASTM-D-3759
ASTM-D-3759
ASTM-D-149
Characteristic
UHMW Film
0.005
Acrylic
0.002
60
30
300
5000
200
Chrysler MS-CH612
Ford ESB-M3G123B
GM 6419M
Pass
Pass
Pass
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as
powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes
B – 01/13/2006
很抱歉,暂时无法提供与“1.875-36-423-5”相匹配的价格&库存,您可以联系我们找货
