TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Optically Clear Tape Made with Teflon FEP
“C” Tape
Product Description
This product is manufactured from clear FEP (fluorinated ethylene propylene) with pressuresensitive, high-temperature silicone adhesive.
Application Information
This tape is often used for coil and transformer insulation. Due to its transparency, this tape is
useful for “see thru” identification on wire harnesses.
Technical Properties
Property
Backing Material
Characteristic
Film-FEP
Adhesive Type
Silicone
Total Thickness (in.)
0.0035
Backing Thickness (in)
0.002
Adhesive Thickness (in.)
0.0015
Adhesion to Steel (oz/in)
Tensile Strength (lb/in)
8
Dielectric Strength (volts)
9000
Dielectric Electrolytic Corr.
1
Elongation (%)
275
Operating Temperature (F)
Color
-100 to 400
Clear
Features/ Benefits
“C” Tape is very durable and versatile. The FEP backing offers excellent high temperature
resistance and it offers the highest electrical strength in volts per mil. FEP backing is chemically
inert, thin and conformable. The tape construction is weather resistant, stable and non-toxic.
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as
powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes
5/15/12
很抱歉,暂时无法提供与“0.875-36-CTAPE”相匹配的价格&库存,您可以联系我们找货
