1/2-0156-49-485
    TAPECASE
    TRANSLUCENT RUBBER RESIN TAPE 0.
1/2-0156-49-485 数据手册
Scapa 0485 Rubber Resin Adhesive Strip DESCRIPTION Scapa 0485 is a solvent free rubber resin based hot melt adhesive. Scapa 0485 is available in amber in a strip format supplied on an easily removable liner. APPLICATIONS Jointing of plastic sheeting, filter membranes, damp proof membranes etc Bonding lightweight insulation panels, kickplates etc Mounting lightweight trim As a temporary ‘Third Hand’ fix Bonding of insulation to walls Joining of plastic sheeting Fixing of edgings, sheeting, signs and tiles Fixing roof bars on commercial vehicles Fixing of carpets, decorative edging and board and trims PRODUCT BENEFITS Clean, easy to use alternative to brush on adhesives Very aggressive pressure sensitive adhesive Non‐hardening and permanently flexible Excellent bond strength No curing time required Solvent free, therefore no fumes Forms a strong waterproof bond Well established product with long term proven success Pre‐formed to a choice of sizes Versatile “instant stick” adhesive on a roll TECHNICAL PROPERTIES Version: 5 www.scapa.com  Date: 07/04/2016 Page: 1 of 2 Technical Property Nominal Value Unit Test Method Tack (Rolling Ball Method) 30 mm 55233* This Technical Data Sheet (TDS) is provided by Scapa for information only. The contents of this TDS are considered to be reliable but accuracy is not guaranteed. The results shown in this TDS may not be relevant to all users of the product and it is the user’s responsibility to determine the suitability of the product for its intended purpose. Scapa expressly disclaims Specific Gravity 0.98 g/cm3 55295* all express or implied warranties including merchantability and fitness for a particular purpose to the fullest extent permitted by law and does not accept responsibility or liability (whether direct, indirect, or consequential) arising from use of the product or reliance on the TDS. Scapa does not exclude liability for death or personal injury arising from its negligence or Softening Point (Ring and Ball) 85 °C 55272* fraud. Scapa refers to Scapa Group plc and its subsidiaries. Service Temperature 0 ‐ 40 °C ‐ Cohesion 0.6 N mm‐² 55270* TECHNICAL PROPERTIES Technical Property Tack (Rolling Ball Method) Specific Gravity Softening Point (Ring and Ball) Service Temperature Cohesion Nominal Value 30 0.98 85 0 ‐ 40 0.6 Unit mm g/cm3 °C °C N mm‐² Test Method 55233* 55295* 55272* ‐ 55270* STANDARD PRESENTATIONS Roll Width: 12mm, 19mm, 25mm, 38mm, 50mm Packaging: Bulk packed Core: 76mm plain Note: Note: Information on stock items, non‐standard sizes, and lead times is available on request RECOMMENDATIONS It is recommended that this product is applied at temperatures over 10º C To aid the cutting of 0485, it is advisable to dip blades or scissors into water immediately prior to use. The rolls should be stored flat on their cut edges in the original packaging, until required for use. The product must be protected from dust, heat, moisture, direct sunlight and solvent fumes. Service life will vary with conditions of use and is affected by climatic environment, but should not be less than one year from date of manufacture, if stored in a moderate climate and good conditions. Version: 5 Date: 07/04/2016 Page: 2 of 2 www.scapa.com  This Technical Data Sheet (TDS) is provided by Scapa for information only. The contents of this TDS are considered to be reliable but accuracy is not guaranteed. The results shown in this TDS may not be relevant to all users of the product and it is the user’s responsibility to determine the suitability of the product for its intended purpose. Scapa expressly disclaims all express or implied warranties including merchantability and fitness for a particular purpose to the fullest extent permitted by law and does not accept responsibility or liability (whether direct, indirect, or consequential) arising from use of the product or reliance on the TDS. Scapa does not exclude liability for death or personal injury arising from its negligence or fraud. Scapa refers to Scapa Group plc and its subsidiaries.
1/2-0156-49-485 价格&库存
很抱歉,暂时无法提供与“1/2-0156-49-485”相匹配的价格&库存,您可以联系我们找货
