1/2-5-SG05-03
1/2-5-SG05-03
    TAPECASE
    SG05-03 BROWN TAPE MADE WITH TEF
1/2-5-SG05-03 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Tape Made with Teflon PTFE SG05-03 Product Description SG05-03 is a fiberglass fabric impregnated with PTFE (polytetraflouroethylene) dispersion and coated with high-temperature, pressure-sensitive silicone adhesive Application Information SG05-03 is frequently used by the packaging industry as a release surface on heat sealers, blister formation and form-fill-seal equipment. The durability and anti-stick properties of SG05-03 make it an ideal material for the lining of guide rails, chutes, and slides. The high temperature capabilities and non-stick properties of SG05-03 allow it to perform as an excellent release surface in the composite aircraft industry. Technical Properties Property Backing Material Characteristic PTFE-Coated Fiberglass Fabric Adhesive Type Super Stick Silicone Total Thickness (in.) 0.0047 Backing Thickness (in) 0.003 Adhesive Thickness (in.) 0.0017 Adhesion to Steel (oz/in) 45 Elongation (% at break)
1/2-5-SG05-03 价格&库存
很抱歉,暂时无法提供与“1/2-5-SG05-03”相匹配的价格&库存,您可以联系我们找货
