1.5-36-SG05-10
1.5-36-SG05-10
    TAPECASE
    SG05-10 BROWN TAPE MADE WITH TEF
1.5-36-SG05-10 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Tape Made with Teflon PTFE SG05-10 Product Description SG05-10 is a fiberglass fabric impregnated with PTFE (polytetraflouroethylene) dispersion and coated with high-temperature, pressure-sensitive silicone adhesive Application Information SG05-10 is frequently used by the packaging industry as a release surface on heat sealers, blister formation and form-fill-seal equipment. The durability and anti-stick properties of SG05-10 make it an ideal material for the lining of guide rails, chutes, and slides. The high temperature capabilities and non-stick properties of SG05-10 allow it to perform as an excellent release surface in the composite aircraft industry. Technical Properties Property Backing Material Characteristic PTFE-Coated Fiberglass Fabric Adhesive Type Super Stick Silicone Total Thickness (in.) 0.0117 Backing Thickness (in) 0.0100 Adhesive Thickness (in.) 0.0017 Adhesion to Steel (oz/in) 60 Elongation (% at break)
1.5-36-SG05-10 价格&库存
很抱歉,暂时无法提供与“1.5-36-SG05-10”相匹配的价格&库存,您可以联系我们找货
