TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Semi Conductive Abrasion Resistant
Fiberglass Tape Coated with Teflon PTFE
SG56-03
Product Description
SG56-03 is a fiberglass fabric impregnated with PTFE dispersion and coated with high
temperature, pressure sensitive silicone adhesive.
Application Ideas
SG56-03 is frequently used by the packaging industry as a release surface on heat-sealers, blister
formation and form-fill seal equipment. The durability and anti-stick properties of this tape also
make it an ideal material for the lining of guide rails, chutes, and slides. The high temperature
capabilities and the non stick properties allow it to perform as an excellent release surface in the
composite aircraft industry.
Technical Data
5 mil Version
Property
Backing Material
Backing Thickness
Adhesive System
Adhesive Thickness (in.)
Adhesion (oz/in.)
Color
Elongation
Operating Temperature
Data
PTFE - Coated Fiberglass
Fabric
0.003
Clean Release Silicone
0.002
45
Black
很抱歉,暂时无法提供与“0.625-18-SG56-03”相匹配的价格&库存,您可以联系我们找货
