1.125-18-SG56-05
1.125-18-SG56-05
    TAPECASE
    SG56-05 BLACK SEMI CONDUCTIVE AB
1.125-18-SG56-05 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Semi Conductive Abrasion Resistant Fiberglass Tape Coated with Teflon PTFE SG56-05 Product Description SG56-05 is a fiberglass fabric impregnated with PTFE dispersion and coated with high temperature, pressure sensitive silicone adhesive. Application Ideas SG56-05 is frequently used by the packaging industry as a release surface on heat-sealers, blister formation and form-fill seal equipment. The durability and anti-stick properties of this tape also make it an ideal material for the lining of guide rails, chutes, and slides. The high temperature capabilities and the non stick properties allow it to perform as an excellent release surface in the composite aircraft industry. Technical Data 7 mil Version Property Backing Material Backing Thickness Adhesive System Adhesive Thickness (in.) Adhesion (oz/in.) Color Elongation Operating Temperature Data PTFE - Coated Fiberglass Fabric 0.005 Clean Release Silicone 0.002 50 Black
1.125-18-SG56-05 价格&库存
很抱歉,暂时无法提供与“1.125-18-SG56-05”相匹配的价格&库存,您可以联系我们找货
