1-5-VF32B
1-5-VF32B
    TAPECASE
    1/32 THICK BLACK DOUBLE COATED
1-5-VF32B 数据手册
TapeCase Ltd. 1982 Lunt Ave Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tapecase.com sales@tapecase.com Double Coated Vinyl Foam Tape VF Series PRODUCT DESCRIPTION: Tape VF32 Tape VF16 Tape VF08 1/32 in. (0.8 mm) Double Coated Vinyl Foam Tape 1/16 in. (1.6 mm) Double Coated Vinyl Foam Tape 1/8 in. (3.2 mm) Double Coated Vinyl Foam Tape APPLICATIONS: General purpose mounting and joining. Surfaces and conditions for removal should be tested by the user to determine fitness for the user’s particular purpose. The high degree of conformability of these tapes make them ideal for joining many rough irregular surfaces, and the closed-cell foam can make good water and air seals in certain applications. PHYSICAL PROPERTIES: Adhesive Type Adhesive Carrier Density Temperature Resistance Tensile Strength Water and Humidity Resistance Shelf Life High Tack Acrylic Closed Cell Polyvinyl Chloride Foam 20 lb/ft³ up to 150°F 60 psi Excellent 18 months from DOM COLORS AVAILABLE: White and Black. Black only in 1/8” thickness NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes.
1-5-VF32B 价格&库存
很抱歉,暂时无法提供与“1-5-VF32B”相匹配的价格&库存,您可以联系我们找货
