TapeCase Ltd.
1982 Lunt Ave Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tapecase.com
sales@tapecase.com
Double Coated Vinyl Foam Tape
VF Series
PRODUCT DESCRIPTION:
Tape VF32
Tape VF16
Tape VF08
1/32 in. (0.8 mm) Double Coated Vinyl Foam Tape
1/16 in. (1.6 mm) Double Coated Vinyl Foam Tape
1/8 in. (3.2 mm) Double Coated Vinyl Foam Tape
APPLICATIONS:
General purpose mounting and joining. Surfaces and conditions for removal should be tested by
the user to determine fitness for the user’s particular purpose. The high degree of conformability
of these tapes make them ideal for joining many rough irregular surfaces, and the closed-cell
foam can make good water and air seals in certain applications.
PHYSICAL PROPERTIES:
Adhesive Type
Adhesive Carrier
Density
Temperature Resistance
Tensile Strength
Water and Humidity Resistance
Shelf Life
High Tack Acrylic
Closed Cell Polyvinyl Chloride Foam
20 lb/ft³
up to 150°F
60 psi
Excellent
18 months from DOM
COLORS AVAILABLE: White and Black. Black only in 1/8” thickness
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface
contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on
substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification
purposes.
很抱歉,暂时无法提供与“0.375-5-VF16W”相匹配的价格&库存,您可以联系我们找货
