EXTREME TEMPERATURES
Technical Data Sheet
WELDWRAP
E
asy To Install - Cuts With
Scissors
Put-Ups
R
esists Damage from UV,
Gasoline & Engine Chemicals
W
eld Splatter, Hot Slag, &
Welding Spark Protection
S
tays Flexible In Low Temps
Nominal
Size
Part
Wall
Thickness
Velcro
Width
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1”
1 1/2”
2”
2 3/8”
2 3/4”
3”
3 1/4”
3 1/2”
4”
WWN1.00BK
WWN1.50BK
WWN2.00BK
WWN2.38BK
WWN2.75BK
WWN3.00BK
WWN3.25BK
WWN3.50BK
WWN4.00BK
.04”
.04”
.04”
.04”
.04”
.04”
.04”
.04”
.04”
0.84”
0.84”
1.55”
1.55”
1.55”
1.55”
1.55”
1.55”
1.55”
150’
150’
150’
150’
150’
150’
150’
150’
150’
50’
50’
50’
50’
50’
50’
50’
50’
50’
Black
Black
Black
Black
Black
Black
Black
Black
Black
8.4
11.0
13.8
14.8
16.4
18.4
19.2
20.4
21.7
Protects Vulnerable Welding Hoses From
Catastrophic Failure.
Cut Cleanly
Scissors
Material
Fiberglass
Grade
WWN
Techflex WeldWrap (WW) is braided from fiberglass
yarns with high temperature coating and velcro
closure. Commonly used for protecting welding
hoses against flame and abrasion, when dragging
weld slag across the floor. This product will
withstand continuous exposure to temperatures
of 400°F/204.4°C, and intermittent introduction
to temperatures of 750°F/399°C.
The heavy duty hook and loop closure ensures a tight
seal and allows WeldWrap to be installed easily over
existing assemblies. WeldWrap also provides a high
level of abrasion and penetration protection to increase
the useful life of any hoses exposed to rough or
abrasive surfaces.
Wall Thickness
.04”
www.techflex.com
800.323.5140 • 973.300.9242 • fax: 973.300.9409
104 Demarest Road • Sparta, NJ 07871
...bundles and protects hoses and cables
on welding robots and static welding
stations.
Colors Available:
Black (BK)
WELDWRAP
High
Rating_________Non Flammable
Maximum Continuous
Mil-I-23053
Abrasion Test Machine
400°F (204.4°C)
Taber 5150
Minimum Continuous
-40°F (-40°C)
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
77°F
Humidity
70%
Material Destroyed Two Small Holes Worn
Through
1,060 Test Cycles
Pre-Test Weight
7,857.40 mg
Post-Test Weight
6,602.20 mg
Test End Loss Of Mass
Point Of Destruction
1,255.20 mg
1=No Effect 4=More Affected
2=Little Effect 5=Severely Affected
3=Affected
Aromatic Solvents_________________1
Aliphatic Solvents_________________1
Chlorinated Solvents_______________1
Weak Bases_____________________1
Salts___________________________1
Strong Bases____________________1
Salt Water 0-S-1926________________1
Hydraulic Fluid MIL-H-5606__________1
Lube Oil MIL-L-7808________________1
De-Icing Fluid MIL-A-8243___________1
Strong Acids_____________________2
Strong Oxidants__________________2
Esters/Keytones__________________1
UV Light________________________1
Petroleum_______________________1
Fungus ASTM G-21_________________1
Monofilament Diameter__________NA
ASTM D-204
Flammability Rating___________VW-1
FMVSS-302 Approved
Recommended Cutting__Scissor/Shears
Colors_________________________1
Wall Thickness_________________.04
© 2014 Techflex, Inc. - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex, Inc. is strictly forbidden.
Techflex product names and logos are registered trademarks of Techflex, Inc., unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s only obligations are those in standard terms of
sale for these products and Techflex will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06-14
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
Intermitten Exposure
750°F (399°C)
很抱歉,暂时无法提供与“WWN1.50BK150”相匹配的价格&库存,您可以联系我们找货
