Introducing the Media over Fiber Optic™ Series from TechLogix.
TechLogix MOFO™ HDMI, DisplayPort and USB cables leverage a true fiber core to
deliver unparalleled speed, bandwidth and reliability. Pre-terminated connectors
accommodate installations in seconds and the optical construction provides complete
immunity to RF, EM and electrical interference. Plus, MOFO™ cables are built with
four strands of re-terminable multimode fiber allowing cable runs to be upgraded
and re-purposed in the future. Discover more online at www.tlnetworx.com.
HDMI
PART NUMBER
MOFO-HD20-10
MOFO-HD20-15
MOFO-HD20-23
MOFO-HD20-30
MOFO-HD20-50
MOFO-HD21-10
MOFO-HD21-15
MOFO-HD21-23
MOFO-HD21-30
LENGTH
10m / 33ft.
15m / 50ft.
23m / 75ft.
30m / 100ft.
50m / 165ft.
10m / 33ft.
15m / 50ft.
23m / 75ft.
30m / 100ft.
CONNECTOR A
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
CONNECTOR B
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
Male HDMI
BANDWIDTH / FORMAT
18G / HDMI 2.0
18G / HDMI 2.0
18G / HDMI 2.0
18G / HDMI 2.0
18G / HDMI 2.0
48G / HDMI 2.1
48G / HDMI 2.1
48G / HDMI 2.1
48G / HDMI 2.1
MAX RESOLUTION
4K60 4:4:4 HDR
4K60 4:4:4 HDR
4K60 4:4:4 HDR
4K60 4:4:4 HDR
4K60 4:4:4 HDR
8K60
8K60
8K60
8K60
JACKET
4.5mm Plenum
4.5mm Plenum
4.5mm Plenum
4.5mm Plenum
4.5mm Plenum
4.5mm Plenum
4.5mm Plenum
4.5mm Plenum
4.5mm Plenum
LENGTH
10m / 33ft.
15m / 50ft.
23m / 75ft.
30m / 100ft.
50m / 165ft.
CONNECTOR A
Male DisplayPort
Male DisplayPort
Male DisplayPort
Male DisplayPort
Male DisplayPort
CONNECTOR B
Male DisplayPort
Male DisplayPort
Male DisplayPort
Male DisplayPort
Male DisplayPort
BANDWIDTH / FORMAT
32.4G / DP 1.4
32.4G / DP 1.4
32.4G / DP 1.4
32.4G / DP 1.4
32.4G / DP 1.4
MAX RESOLUTION
8K60
8K60
8K60
8K60
8K60
JACKET
4.8mm Plenum
4.8mm Plenum
4.8mm Plenum
4.8mm Plenum
4.8mm Plenum
LENGTH
10m / 33ft.
15m / 50ft.
23m / 75ft.
30m / 100ft.
CONNECTOR A
Male USB A
Male USB A
Male USB A
Male USB A
CONNECTOR B
Female USB A
Female USB A
Female USB A
Female USB A
BANDWIDTH / FORMAT
5G / USB 3.0
5G / USB 3.0
5G / USB 3.0
5G / USB 3.0
COMPATIBLE SPEED
SuperSpeed
SuperSpeed
SuperSpeed
SuperSpeed
JACKET
4.3mm Plenum
4.3mm Plenum
4.3mm Plenum
4.3mm Plenum
DisplayPort
PART NUMBER
MOFO-DP14-10
MOFO-DP14-15
MOFO-DP14-23
MOFO-DP14-30
MOFO-DP14-50
USB
PART NUMBER
MOFO-USB3-10
MOFO-USB3-15
MOFO-USB3-23
MOFO-USB3-30
Media over Fiber Optic™ Cables | Features & Specifications
HDMI 2.0
SPECIFICATIONS
HDMI / HDCP Version
Max Bandwidth / Resolution
Construction
Power
Min Bend Rating
Max Pull-Strength
Environmental
HDMI 2.0 / HDCP 2.0
18G / 4K60 4:4:4 HDR
4 strand multimode OM3 + 8 conductor copper
Plenum rated jacket / black color
4.5mm jacket diameter
Kevlar strength member
250mW max draw / powered by HDMI bus
48mm / 1.8 inches
70 lbs.
0° C to 50° C / 85% humidity (non-condensing)
FEATURES
Fiber-based HDMI cable
No power required (completely powered by HDMI bus)
Supports 18G 4K60 4:4:4 HDR / HDCP 2.0 / 3D / Deep Color
Supports multi-channel audio / Dolby TrueHD / DTS-HD Master Audio / ARC
Supports EDID / CEC / HEC
Directional operation – clearly marked source & display headshells
Interference-free performance
Four strand multimode OM3 construction – supports re-termination in the field
Backwards compatible with HDMI 2.0 & HDMI 1.4 devices
Supports 48G 8K60 HDR / HDCP 2.2 / 3D / Deep Color
Supports VRR / QMS / QFT / ALLM / DSC
Supports multi-channel audio / Dolby TrueHD / DTS-HD Master Audio / ARC / eARC
Fiber-based DisplayPort cable
No power required (completely powered by DisplayPort bus)
Supports 32.4G 8K60 / HBR3 / HDCP 1.4 / HDCP 2.2
Supports EDID / Link Training
Fiber-based USB cable
Male Type A USB connector to Female Type A USB connector
Compatible with USB 3.0 (SuperSpeed) devices
Not compatible with USB 1.1 (full-speed) or USB 2.0 (high-speed) devices
No power required (completely powered by USB bus)
Plug-and-play – no drivers required
HDMI 2.1
SPECIFICATIONS
HDMI / HDCP Version
Construction
Power
Min Bend Rating
Max Pull-Strength
Environmental
HDMI 2.1 / HDCP 2.2
48G / 8K60
48mm / 1.8 inches
70 lbs.
FEATURES
DisplayPort 1.4
SPECIFICATIONS
DisplayPort Version
Video Performance
Construction
Power
Min Bend Rating
Max Pull-Strength
Environmental
DP 1.4
32.4G 8K60
810MHz pixel clock / 48bit color depth
4.8mm jacket diameter
250mW max draw / powered by source device
48mm / 1.8 inches
70 lbs.
FEATURES
USB 3.0
SPECIFICATIONS
USB Version
Max Bandwidth
Construction
Power
Min Bend Rating
Max Pull-Strength
Environmental
USB 3.0 / SuperSpeed
5G
4.3mm jacket diameter
5V (4.75 min – 5.25 max)
48mm / 1.8 inches
70 lbs.
FEATURES
很抱歉,暂时无法提供与“MOFO-DP14-50”相匹配的价格&库存,您可以联系我们找货
