TL-4X1-HD2 Technical Specifications v170307
TL-4X1-HD2
Features at a Glance
• EDID management
• Supports 4K 4:4:4 HDMI video
• HDCP 2.2 compliant
• Supports HDR10 and Dolby
Vision
• Controlled via IR and RS232
• Ultra-thin size
The TL-4X1-HD2 is an ultra-thin HDMI switcher with 4 inputs and 1 output. It features autoswitching and manual-switching. The TL-4X1-HD2 supports intelligent EDID management via 4-pin DIP
switch in rear panel, with 5 built-in EDID presets and 10 user-definable EDID settings. Compatible with
HDMI 2.0 & HDCP 2.2, the TL-4X1-HD2 can transmit 4K@60 4:4:4 with HDR and 1080P with or
without 3D.
Specifications
I/O Connections
HDMI Inputs
HDMI Output
IR Input
RS232 Control
EDID Data Selector
Source Select Button (Front Panel)
DC 5V Power/Firmware Update
Four (4) HDMI type A receptacle
One (1) HDMI type A receptacle
One (1) 3.5mm TRS jack
One (1) 3-pin pluggable terminal block
One (1) 4-pin solider switch
One (1) button
One (1) mini USB type B receptacle
Supported Video and Audio
Resolutions
Video Compliance
Bandwidth
Embedded Audio Compatibility
Input DDC Signal
Input Video Signal
IR Carrier Frequency Range
HDMI: 480I, 480p, 576I, 576P, 720p, 1080I, 1080p, 4Kx2K@60Hz 4:4:4
DVI: 640x480@60Hz, 640x480@72Hz, 640x480@75Hz, 800x600@60Hz,
800x600@72Hz, 800x600@75Hz, 1024x768@60Hz,
1024x768@70Hz, 1024x768@75Hz, 1280x1024@60Hz,
1280x1024@75Hz, 1600x1200@60hz, 1920x1080@60Hz,
1920x1200@60Hz
HDMI 1.4/2.0 with HDR, HDCP 1.4/2.2, DVI1.0
18 Gbps
PCM, Dolby Digital, DTS, and DTS-HD.
5.0 volts p-p (TTL)
0.5 ~ 1.0 volts p-p
33-55KHz at 5V
www.tlnetworx.com | +1-608-960-7242
Chassis and Environmental
Enclosure
Dimensions (W x H x D)
Painted aluminum
194mm x 12mm x 80.4mm (6.00in x 0.47in x 2.77in)
Shipping Weight
Operating Temperature
(Environment)
0.73Kg (1.60lbs)
-10° ~ +40° C (+14° ~ +104° F)
Operating Temperature (Chassis)
Operating Humidity (Environment)
Storage Temperature
(Environment)
45° C (113° F)
10% ~ 90% Non-condensing
-15° ~ +70° C (+5° ~ +167° F)
Storage Humidity (Environment)
Power, ESD, Regulatory
Maximum Power Consumption
4.2W
Power Supply
ESD Protection
5V at 1A
15KV
Regulatory
CE, FCC
Other
Standard Warranty
Indicators
Included Items
1 Year
1 Power, 1 switch mode, 4 Input status, 1 Output connection status
Installation guide, Power adaptor, mounting “L” brackets (2 ea), mounting
screws (4 ea), Plastic cushions (4 ea), RS232 cable, IR remote, IR receiver
Dimensional Drawings
很抱歉,暂时无法提供与“TL-4X1-HD2”相匹配的价格&库存,您可以联系我们找货
