TL-FO2-HDC Technical Specifications v181029
TL-FO2-HDC
Features at a Glance
• Transmit HDMI and IR or RS232
over two fiber optic conductors
• LC connectors for fiber connection
• Single & multimode fiber compatible
• Extend 18G HDMI up to 300m
(984 ft.)
• HDMI 2.0 & HDCP 2.2 compliant
• 4K@60 compliant
• Immune to RF & EM interference
The TL-FO2-HDC is an HDMI 2.0 (18G signal) with HDCP 2.2 support fiber optic extender set that can reach
up to 300 meters (984 ft) over a duplex OM3 cable with common LC terminations. The unit supports HDMI
video resolutions up to 4K@60, HDR video, IR or RS232 pass-through controls and multichannel audio. The
TL-FO2-HDC is also compatible with HDMI 1.3/1.4 content with HDCP 1.3/1.4 content protection.
www.tlnetworx.com | +1-608-960-7242
Specifications
Transmitter Input/Output
HDMI Input
Optical Output
IR Input/Output
RS232
12V DC
Control Selector
1 HDMI Receptacle
2 LC Ports via SFP+ Module
2 3.5mm TRS Ports
1 3-pin Removable Terminal Block
1 5.5mm OD/2.5mm ID Threaded Barrel Connector
1 2-position Switch
Receiver Input/Output
HDMI Output
Optical Input
IR Input/Output
RS232
12V DC
Control Selector
1 HDMI Receptacle
2 3.5mm TRS Ports
1 2-position Switch
Supported Audio, Video, and Control
Compatible Video Signals
All SD, HD, and other resolutions up to
- 4K/60 Hz / RGB and 4:4:4 8 bit (HDR)
- 4K/60 Hz / 4:2:2 10 bit (HDR)
- 4K/60 Hz / 4:2:0 10 bit (HDR)
HDMI 2.0, HDMI 1.4, DVI 2.0 (Pixel clock up to 594 MHz)
HDCP 1.2 / HDCP 2.2 Compatible
LPCM, Dolby Digital/Plus/EX, Dolby True HD, DTS, DTS-EX, DTS-96/24,
DTS High Res, DTS-HD Master Audio, DSD
2400, 4800, 9600, 19200, 38400, 57600, 115200
33 to 55 kHz
Video Compliance
Digital Content Protection
Embedded Audio
Supported RS232 Baud Rates
Supported IR Carrier
Fiber Optic Transmission Characteristics
Required Cable Type
Maximum Bandwidth
Maximum Distance with Stock SFP+ Modules
Signal Compression
Duplex OM3
10 Gbps
300m (984 ft)
1.8:1 Maximum; Compression starts when video signal >9 Gbps
Chassis and Environmental
Product Construction
Product Dimensions (W*H*D)
Product Operational Chassis Temperature
Environmental Operating Temperature
Environmental Operating Humidity
Environmental Storage Temperature
Environmental Storage Humidity
Painted aluminum
150 mm (5.91 in) x 20 mm (0.79 in) x 74.4 mm (2.93 in)
35 to + 44°C (95 to + 111 °F)
0 to + 45°C (32 to + 113 °F)
10% to 90%, non-condensing
-20 to +70°C (-4 to + 158 °F)
Power and Regulatory
Power Input
Power Supply Input
Power Supply Output
Maximum Power Consumption
ESD Protection
Regulatory Compliance
12V DC
100-240V AC at 50/60 Hz; 0.5A Max
12V DC at 1 A
6 watts
Human-body Model: ±8kV Air-gap discharge and ±4kV Contact discharge
FCC, CE, RoHS, WEEE
Other
Warranty
Diagnostic LEDs
Included Accessories
Three years
Link, Status, HDCP and Power
IR Receiver (2 ea), IR Transmitter (2 ea), Mounting Ears (4 ea), Rubber
Feet (8 ea), 12V 1A DC Power Supply (2 ea), 3-pin 3.5mm Terminal Block
(2 ea)
Transmitter Dimensional Drawings
Receiver Dimensional Drawings
很抱歉,暂时无法提供与“TL-FO2-VLC-SM”相匹配的价格&库存,您可以联系我们找货
