TL-SM3X1-HD Technical Specifications v181025
TL-SM3X1-HD
Features at a Glance
• Three HDMI inputs & one HDMI output
• HDMI video resolution up to 4K@30
4:4:4
• HDMI 1.4 & HDCP 1.4 compliant
• MHL support on HDMI input channel 1
• IR remote control & front panel control
• Integration with TechLogix table inserts
for signal pass-through & remote control
• Micro USB firmware port
• EDID pass-through
• CEC pass-through with display control
• Hot-plug support
The TL-SM3X1-HD is a 3x1 video switcher with three HDMI inputs and one HDMI output. The unit supports
HDMI video resolutions up to 4K@30, as well as multichannel audio.
The TL-SM3X1-HD supports two operating modes: auto-switch mode and manual switch mode. When in autoswitch mode, the unit will automatically switch to a signal input as soon as a new source is connected. When
the active source is removed, the unit will select the first source on the lowest numbered input.
In manual switch mode, the TL-SM3X1-HD will switch between connected inputs when a control command is
sent to the unit via IR or through a command sent by compatible table inserts, or by using buttons on the front
panel of the unit.
In addition to controlling the switching of the source inputs, the TL-SM3X1-HD also controls a display
connected via an HDMI cable via CEC commands. This allows for automatic power on/off commands to be
transmitted from the unit (as well as connected table inserts) to the display, thereby providing a complete room
connectivity and control solution.
Specifications
Input/output
Video Input
Video Input Connector
Input Video Signal
Video Output
Video Output Connector
Output Video Signal
Output Resolution
1 HDMI/MHL
2 HDMI
3 female HDMI
HDMI
1 HDMI
1 female HDMI
HDMI
HDMI output video support HDMI 1.4 & HDCP 1.4; maximum resolution of 4K@30
www.tlnetworx.com | +1-608-960-7242
Control Part
3 Dry Contact (C1~C3)
1 FIRMWARE
3 3.5mm mini jack
1 Micro-USB
HDMI 1, HDMI 2, HDMI 3, AUTO
Control Port
Control Connector
Control Buttons
General
Temperature
Humidity
Power Supply
Max Power
Consumption
Dimension (W*H*D)
Weight
Compatible TechLogix
Table Inserts
Warranty
0 ~ +50°C
10% ~ 90%
DC12V 1A
2W
201.5mm x 22.0mm x 84.0mm
246g
TL-SMG-HD (HDMI)
TL-SMG-DP (DisplayPort)
3 years
Dimensional Drawings
HDMI IN 2
HDMI IN 3
HDMI OUT
C1
C2
C3
DC12V
22.0 mm
84.0 mm
HDMI/MHL IN 1
3x1 Video Switcher
TL-SM3X1-HD
201.5 mm
IR
HDMI 1
HDMI 2
HDMI 3
AUTO
FIRMWARE
很抱歉,暂时无法提供与“TL-SMKIT-06”相匹配的价格&库存,您可以联系我们找货
