EDM1CFIMX6D10R1GBNI4GBWLS2C 数据手册
EDM1-CF-IMX6
Main Features
ARM Cortex-A9 NXP i.MX6 scalable single/dual/
quad core EDM type 1 compact System-on-Module
Gigabit LAN, WiFi 802.11 b/g/n and Bluetooth v. 4.0
communication interface
Targeting multimedia applications with LVDS, TTL,
HDMI, S/PDIF, I2S, MIPI camera and display
1
TTL
Power
I2S
2nd
GPMC
SPDIF
CANBus
x2
LAN
LVDS
HDMI
PCIe
x1
SATA
1st
USB
OTG
USB
Host
SD
I2S
1st
SPI
x2
UART
x2
RSVD
Buttons
+ GPIO
I2C
x2
RTC
Specifications
Core System
Signalling
CPU
System Memory
Storage
Debug Interface
FPC Connector
Video
EDM Type 1 compliant
NXP i.MX6Solo @ 1GHz
NXP i.MX6Duallite @ 1GHz
NXP i.MX6Dual @ 1GHz
NXP i.MX6Quad @ 1GHz
up to 2GB DDR3
eMMC (default 4GB)
optional NAND Flash (MOQ apply)
JTAG Interface by Through-hole
MIPI Interface Camera
MIPI Interface Display
Connectivity
Network
WiFi
Bluetooth
Atheros AR8031 Gigabit LAN
Broadcom BCM4330 802.11bgn
Broadcom BCM4330 BT 4.0
I/O Interfaces
Storage
Expansion
Display
USB
CAN Bus
Serial Port
Other
1x SATA 2.0 (Dual/Quad only)
1x SDIO/MMC
1x PCIe 2.0
HDMI v1.4
1 channel LVDS 18/24 bit
24 bit RGB TTL
USB Host 2.0
USB OTG 2.0
2x Flex CAN version 2.0B compliant
2x UART
SPI, I2C, I2S, GPIO, Local Bus (GPMC)
Solo/Duallite
Vivante GC880
35Mtri/s 266Mpxl/s
Open GL ES 2.0
Dual/Quad
Vivante GC2000
200Mtri/s 1000Mpxl/s
OpenGL ES 2.0
& Halti, CL EP
GPU 2D
(Vector Graphics)
emulated on GPU 3D
Vivante GC355
300Mpxl/s
OpenVG 1.1
GPU 2D
(Composition)
Vivante GC320
600Mpxl/s, BLIT
Vivante GC320
600Mpxl/s, BLIT
Video Decode
Video Encode
1080p30 + D1
1080p30 H.264
BP/Dual 720p
1080p60 H.264
1080p30 H.264
BP/Dual 720p
GPU 3D
Audio
Interface
Audio Codec
I2S (2 channel), S/PDIF
on EDM Carrier Board
Power Specifications
Input power
5V DC +/- 5%
Operation Systems
Standard Support
Extended Support
Linux
Yocto
Android
Commercial Linux
Windows Embedded Compact
Real Time OS
EDM1-CF-IMX6
Block Diagram
Up to 2GB
DDR3
NAND
Flash
MIPI Camera
& Display
eMMC
OR
u.FL
NXP i.MX6
Cortex A9
Power
SDIO
WiFi
Bluetooth
UART
LAN
PHY
1
314 Pin EDM Connector
Environmental and Mechanical
Ordering Information
Temperature
EDM1-CF-IMX6x-10-Rxxx-NIxG-xx-x-x-xx-xxx-xxxx
Humidity
Module Connector
Form Factor
Dimensions
MTBF
Weight
Shock
Vibration
Commercial : 0° to 60° C
Extended : -20° to 70° C
Industrial : -40° to 85° C (no WiFi )
10 to 90%
314 pins MXM3
EDM Compact Form Factor
82 x 60 mm
(3⅝x 2⅜ inch)
>100,000 hours
20 grams
50G/25ms
20G/0-600 Hz
Dimensions
M3
45
82
11.5
60
(units in mm)
Description
i.MX6 Solo
i.MX6 Duallite
i.MX6 Dual
i.MX6 Quad
Processor speed
1 GHz (Default)
512 MB DDR3
Memory
1GB DDR3
2GB DDR3
Storage
eMMC capacity in Gigabyte
NI4G = 4GB : NI8G = 8GB : NI16G = 16GB
NI32G = 32GB : NI64G = 64GB
Wireless Networking No
BW
802.11bgn + Bluetooth 4.0
No
Network
L
Gigabit LAN(Default)
No
SATA
S
SATA(Dual/Quad)
No
CAN Bus
2C
2 CAN(Default)
Temperature Range Commercial Temperature range
(0~60° C)(Default)
Extended Temperature range
TE
(-20~70° C)
Industrial Temperature range
TI
(-40~85° C)
TEC Certified Extended Temperature range
(-20~70° C)
Certified Industrial Temperature range
TIC
(-40~85° C)
Custom ID
XXXX Custom Part number ID for customized
software loader and special
component (BOM)
Processor
Code
IMX6S
IMX6U
IMX6D
IMX6Q
10
R512
R1GB
R2GB
NI4G
75
* Feel free to contact us for custom tailored Carrier Board request for
your projects.
2016-09. All specifications are subject to change without notice.
EDM1CFIMX6D10R1GBNI4GBWLS2C 价格&库存
很抱歉,暂时无法提供与“EDM1CFIMX6D10R1GBNI4GBWLS2C”相匹配的价格&库存,您可以联系我们找货
