KONA Micro IoT Gateway
Enterprise LoRaWAN® Gateway for Mission Critical Deployments
The KONA Micro IoT Gateway is designed for
enterprise and lightweight industrial applications
that require “Always On” connectivity. Configured
with an internal 3G/4G modem and a built-in battery
backup, the KONA Micro IoT gateway continues to
operate and transmits sensor data to the network
even when the main site has lost power.
Simple to configure and cost effective, it is an ideal
hub for deployment of enterprise-level applications
in areas where LoRaWAN® coverage is not yet
readily available or for private networks where the
operator requires unfettered access to the gateways
regardless of their deployment location.
Key Features
Key Product Differentiators
Enable critical enterprise IoT applications with
‘Always On’ connectivity. Battery backup and an
integrated 3G/4G modem.
NA 915, EU868, AUS923, JP920 ISM Bands
Reduce set up costs with plug-n-play installation
using a custom provisioned factory image.
Time Duplex 8 Rx / 1 Tx
Four Hour Battery Backup
Integrated Cellular 3G/4G Modem
Improve coverage and service resulting in increased
IoT application adoption and customer satisfaction.
External LoRa Antenna
Simplify management with the KonaFT OAM tool.
Operational Status LED
Operational status indicated with multi-function LED.
27 dBM Tx Power
Fully integrated with the broader eco-system of
LoRa™ network servers and sensors.
Plug - n - Play Operation
Factory Image for Mass Deployment
In-Service Updates
INFO@TEKTELIC.COM
+1.403.338.6900
WWW.TEKTELIC.COM
Technical and Functional System Specifications
Mechanical Parameters
LoRa Radio Parameters
MTBF
830,000 hours
ISM Bands
NA915, EU868, AS923, JP920, CH779
DC Power Consumption
很抱歉,暂时无法提供与“T0005127”相匹配的价格&库存,您可以联系我们找货
