RF Superflex Cable Technical Data Sheet
Connecter Type
Cable Type
Description
N/N
1/2” super cable
N Male/N Female for YD9
Cable Assembly
All dimensions are in mm
Jumper
Length (mm)
Tolerances
(mm)
Part Number
Insertion Loss
VSWR
1000
± 10
T0005196
≤0.34dB(@900MHz)
≤1.2(DC to 3000MHz)
2000
± 20
T0005315
≤0.44dB(@900MHz)
≤1.2(DC to 3000MHz)
3000
± 30
T0005316
≤0.54dB(@900MHz)
≤1.2(DC to 3000MHz)
4000
± 40
Custom Order Only
≤0.64dB(@900MHz)
≤1.2(DC to 3000MHz)
5000
± 50
Custom Order Only
≤0.74dB(@900MHz)
≤1.2(DC to 3000MHz)
Parts
Connector 1
N Male Connector
Center contact
Brass (Ag plating)
Outer contact
Brass (CuSnZn plating)
Fastener
Brass (Ni plating)
Dielectric
PTFE
Gasket
Silicon Rubber
Release Date
Version 1.0
Center contact
Bronze (Ag plating)
Outer contact
Release Date: Dec. 17, 2019
Version: 1.0
Dielectric
PTFE
Cable
1/2” super cable
Molding
Black PE
Marking label
Wrap stick type
Documents
Connector specification
IEC 61169-16
Electrical data
Impedance
50 Ω
Frequency
DC to 3 GHz
Insulation resistance
≥ 5000 MΩ
Dielectric Strength
2000 V AC,1Min
PIM (@900MHz、1800MHz; 2×20W)
≤-150 dBc (2 x 43 dBm)
Mechanical data
Max. tensile strength
300N
Environmental data
Temperature range
-45 °C to +85 °C
Change of temperature
IEC 60068-2-14/GB/T 2423.22
Salt mist
IEC 60068-2-11/GB/T 2423.17(48h)
Vibration
IEC 60068-2-6/GB/T 2423.10
Shock
IEC 60068-2-27/GB/T 2423.5
Damp heat, steady state
IEC 60068-2-3/GB/T 2423.3
Protection class
IEC 60529/GB 4208
Suitable cables
1/2 super cable (YD9 cable)
Version: 1.0
很抱歉,暂时无法提供与“T0005316”相匹配的价格&库存,您可以联系我们找货
