MIM-3231-DSL
MIM-3231-DSL
    TERASIC(友晶科技)
    204-SODIMM
    MODULE DDR3 SDRAM 1GB 204SODIMM
MIM-3231-DSL 数据手册
DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC Specifications Density: 1GB Data Rate: 1066 Mbps Pin Count: 204-pin CAS Latency: 7 Version: Unbuffered Voltage: 1.5V Type: SO-DIMM PCB Layers: 6 Speed: PC3-8500 ECC : Non-ECC Component Config: 128Meg x 8 Module Ranks : Single Rank Features ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ ‧ Data rate:1066Mbps Power supply: VDD= 1.5V + 0.075V Interface: SSTL_15 /CAS Latency(CL):5,6,7,8,9 /CAS write latency(CWL):5,6,7 Fully differential clock inputs (CK, /CK) operation Differential Data Strobe (DQS, /DQS) DM masks write data-in at the both rising and falling edges of the data strobe BL switch on the fly 8banks 8K refresh cycles /64ms Dynamic On Die Termination supported Asynchronous RESET pin supported ZQ calibration supported TDQS (Termination Data Strobe) supported (x8 only) Write Levelization supported Refresh: Auto-Refresh, Self-Refresh On Die Thermal Sensor supported(JEDEC optional) 8 bit pre-fetch Lead-Free Products are RoHS compliant Average Refresh Period 7.8us at 0℃≦TC≦85℃ 3.9us at 85℃<TC≦95℃ 1 REV 3.0 DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC Description The D3SP28081XH18AC is 128M words X 64 bits, 1 ranks . Unbuffered Small Outline Dual In-Line Memory Module (SO-DIMM) .DDR3 SDRAMs in Fine Ball Grid Array(FBGA) packages on a 204pin glass-epoxy substrate. Provide a high performance 8 byte interface in 67.60mm width form factor of industry standard. It is suitable for easy interchange and addition. Speed Grade & Key Parameters Speed DDR3-800 DDR3-1066 DDR3-1333 CL-tRCD-tRP 6-6-6 7-7-7 9-9-9 tCK(min) 2.5 1.875 1.5 ns CAS Latency 6 7 9 tCK tRCD(min) 15 13.13 13.5 ns tRP(min) 15 13.13 13.5 ns tRAS(min) 37.5 37.5 36 ns tRC(min) 52.5 50.625 49.5 ns tRCF(min) 110 110 110 ns tRRD(min) 10 7.5 6.0 ns tFAW(min) 40 37.5 30 ns Unit Address Configuration 512MB 1GB 1GB 2GB 2GB Organization 64M X 64 128M X 64 128M X 72 256M X 64 256M X 72 Refresh Method 8K/64ms 8K/64ms 8K/64ms 8K/64ms 8K/64ms Row Address A0-A12 A0-A13 A0-A13 A0-A13 A0-A13 Column address A0-A9 A0-A9 A0-A9 A0-A9 A0-A9 Bank Address BA0-BA2 BA0-BA2 BA0-BA2 BA0-BA2 BA0-BA2 Auto Precharge A10 A10 A10 A10 A10 # of Rank 1 1 1 2 2 # of DRAMs 4 8 9 16 18 2 REV 3.0 DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC Absolute Maximum ratings Parameter Symbol Rating Units VDD -0.4V ~ +1.975V V VDDQ -0.4V ~ +1.975V V Vin -0.4V ~ +1.975V V Output voltage VOUT -0.4V ~ +1.975V V Storage Temperature TSTG -55 to +100 ℃ 1 Operating case temperature Toper 0 to 95 ℃ 2,3 Storage Humidity HSTG 5 to 95 % Power dissipation PD 9 W IOUT 50 mA Voltage on VDD pin relative to Vss Voltage on VDDQ pin relative to Vss Input voltage Short circuit output current Notes Note: 1. Storage Temperature is the case surface temperature on the center/top side of the DRAM. For the measurement conditions, please refer to JESD51-2 standard. 2. The Normal Temperature Range specifies the temperatures where all DRAM specifications will be supported. During operation, the DRAM case temperature must be maintained between 0-85℃ under all operating conditions. 3. Some applications require operation of the Extended Temperature Range between 85℃ and 95℃ case temperature. Full specifications are guaranteed in this range, but the following additional conditions apply: a) Refresh commands must be doubled in frequency, therefore reducing the refresh interval tREFI to 3.9us. It is also possible to specify a component with 1X refresh(tREFI to 7.8us) in the Extended Temperature Range. b) If Self-Refresh operation is required in the Extended Temperature Range, then it is mandatory to either use the Manual Self-Refresh mode with Extended Temperature Range capability(MR2A6=0b and MR2A7=1b) or enable the optional Auto Self-Refresh mode(MR2A6=1b and MR2A7=0b) 3 REV 3.0 DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC Recommended DC Operating Conditions(SSTL-15) Symbol Parameter VDD Rating Units Notes 1.575 V 1,2 1.5 1.575 V 1,2 0 0 0 V 1 Supply Voltage 3.0 3.3 3.6 V VREFCA(DC) Input reference voltage 0.49xVDDQ 0.50xVDDQ 0.51xVDDQ V 1 VREFDQ(DC) Input reference voltage for DQ 0.49xVDDQ 0.50xVDDQ 0.51xVDDQ V 1 Min. Typ. Max Supply Voltage 1.425 1.5 VDDQ Supply Voltage for Output 1.425 VSS Supply Voltage VDDSPD Note: 1. DDR3 SDRAM component specification. 2. Under all conditions VDDQ must be less than or equal to VDD. Pin Description Pin Name A0~A9,A11 A13-A15 Description Address intput Pin Name VREFCA VREFDQ Description Input/Output voltage reference A10(AP) Auto precharge /CK0,/CK1 SDRAM differential clock input A12(/BC) Bust chop CK0,CK1 SDRAM clocks input /RAS SDRAM Row address strobe SCL Clock input for serial PD /CAS SDRAM Column address strobe SDA Data intput/output for serial PD /WE SDRAM write enable /CS0-/CS1 Chip select CKE0,CKE1 SDRAM clock enable ODT0,ODT1 On-die termination control DQ0-DQ63 BA0-BA2 Data input/output SDRAM bank addresses DQS0-DQS7 Input and output data strobe DM0-DM7 SDRAM data mask /high data strobe /DQS0-/DQS7 Input and output data strobe VTT SDRAM I/O termination supply SA0-SA1 Serial address select intput VDD* SDRAM core power supply VDDQ* VREF VSS VDDSPD NC /RESET TEST /EVENT 4 SDRAM I/O Driver power supply SDRAM I/O reference supply Ground Serial EEPROM positive power supply No connection Set DRAM to known state Used by memory bus analysis tools(unused on memory DIMMs) Temperature event pin REV 3.0 DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC Pin Configuration Pin Front Pin Front Pin Front Pin Front Pin Front Pin Front 1 VREFD 2 Vss 71 Vss 72 Vss 139 Vss 140 DQ38 3 Vss 4 DQ4 141 DQ34 142 DQ39 5 DQ0 6 DQ5 73 CKE0 74 CKE1 143 DQ35 144 Vss 7 DQ1 8 Vss 75 VDD 76 VDD 145 Vss 146 DQ44 9 Vss 10 /DQS0 77 NC 78 A15 147 DQ40 148 DQ45 11 DM0 12 DQS0 79 BA2 80 A14 149 DQ41 150 Vss 13 Vss 14 Vss 81 VDD 82 VDD 151 Vss 152 /DQS5 15 DQ2 16 DQ6 83 A12/BC 84 A11 153 DM5 154 DQS5 17 DQ3 18 DQ7 85 A9 86 A7 155 Vss 156 Vss 19 Vss 20 Vss 87 VDD 88 VDD 157 DQ42 158 DQ46 21 DQ8 22 DQ12 89 A8 90 A6 159 DQ43 160 DQ47 23 DQ9 24 DQ13 91 A5 92 A4 161 Vss 162 Vss 25 Vss 26 Vss 93 VDD 94 VDD 163 DQ48 164 DQ52 27 /DQS1 28 DM1 95 A3 96 A2 165 DQ49 166 DQ53 29 DQS1 30 /RESE 97 A1 98 A0 167 Vss 168 Vss 31 Vss 32 Vss 99 VDD 100 VDD 169 /DQS6 170 DM6 33 DQ10 34 DQ14 101 CK0 102 CK1 171 DQS6 172 Vss 35 DQ11 36 DQ15 103 /CK0 104 /CK1 173 Vss 174 DQ54 37 Vss 38 Vss 105 VDD 106 VDD 175 DQ50 176 DQ55 39 DQ16 40 DQ20 107 A10/AP 108 BA1 177 DQ51 178 Vss 41 DQ17 42 DQ21 109 BA0 110 /RAS 179 Vss 180 DQ60 43 Vss 44 Vss 111 VDD 112 VDD 181 DQ56 182 DQ61 45 /DQS2 46 DM2 113 /WE 114 /S 0 183 DQ57 184 Vss 47 DQS2 48 Vss 115 /CAS 116 ODT0 185 Vss 186 /DQS7 49 Vss 50 DQ22 117 VDD 118 VDD 187 DM7 188 DQS7 51 DQ18 52 DQ23 119 A13 120 ODT1 189 Vss 190 Vss 53 DQ19 54 Vss 121 /S 1 122 NC 191 DQ58 192 DQ62 55 Vss 56 DQ28 123 VDD 124 VDD 193 DQ59 194 DQ63 57 DQ24 58 DQ29 125 TEST 126 VREFCA 195 Vss 196 Vss 59 DQ25 60 Vss 127 Vss 128 Vss 197 SA0 198 NC 61 Vss 62 /DQS3 129 DQ32 130 DQ36 199 VDDSPD 200 SDA 63 DM3 64 DQS3 131 DQ33 132 DQ37 201 SA1 202 SCL 65 Vss 66 Vss 133 Vss 134 Vss 203 VTT 204 VTT 67 DQ26 68 DQ30 135 /DQS4 136 DM4 69 DQ27 70 DQ31 137 DQS4 138 Vss KEY 5 REV 3.0 DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC Input/Output Functional Description Symbol Type Function CK0-CK1 /CK0-/CK1 Intput The system clock inputs. All adrress and command lines are sampled on the cross point of the rising edge of CK and falling edge of CK. A Delay Locked Loop (DLL) circuit is driven from the clock inputs and output timing for read operartion is synchronized to the input clock. CKE0,CKE1 Intput Activates the SDRAM CK signal when high and deactivates the CK Signal When low. By deactivating the clock, CKE low initiates the Power Down mode, or the Self-Refresh mode. /S0,/S1 Intput Enables the associated SDRAM command decoder when low and disables the command decoder when high. When the command decoder is disabled, new command are ignored but previous operations continue. Rank0 is selected by /S0;Rank1 is selected by /S1 /RAS,/CAS,/WE Intput ODT0-ODT1 Intput RAS, CAS, and WE(ALONG WITH /S) define the command being entered. When high, termination resistance is enabled for all DQ, DQ and DM pins, assuming the function is enabled in the Extended Mode Register Set (EMRS). VREFDQ Supply Reference voltage for SSTL 15 I/O Inputs. VREFCA Supply Reference voltage for SSTL 15 command/address inputs. VDDQ Supply BA0-BA2 A0-A9 A10(AP) A11 A12(/BC) A13-A15 DQ0-DQ63 Power supply for the DDR3 SDRAM output buffers to provide improved noise immunity. For all current DDR3 unbuffered DIMM designs, VDDQ shares the same power plane as VDD pins. Intput Selects which SDRAM bank of eight is activated. Intput During a Bank Activate command cycle, Address input defines the row address(RA0-RA13) During a Read or Write command cycle. Address input defines the column address. In addition to the column address. AP is used to invoke autoprecharge operation at the end of the burst read or write cycle. If AP is high, autoprecharge is selected and BA0, BA1,BA2 defines the bank to be precharged. If AP is low, autoprecharge is disbled. During a precharge command cycle, AP is used in conjunction with BA0,BA1,BA2 to control which bank(s) to precharge. If AP is high, all banks will be precharged regardless of the state of BA0,BA1,BA2. If AP is low, BA0, BA1 are used to define which bank to precharge. I/O Data input/Output pins. DM is and input mask signal for write data. Input data is masked when DM is sampled High coincident DM0-DM8 Intput with that input data during a write access. DM is sampled on both edges of DQS. Although DM pins are input only, the DM loading matches the DQ and DQS loading. VDD, Vss DQS0-DQS8 /DQS0-/DQS8 SA0-SA2 Supply I/O Input SDA I/O- SCL Input VDD/VDDQ planes on these modules. Data strobe for input and output data. These signals and tied at the system planar to either VSS or VDD to configure the serial SPD EERPOM address range. This bi-directional pin is used to transfer data into or out of the SPD EEPROM. A resistor must be connected from the SDA bus line to VDD to act as a pullup on the system board. This signal is used to clock data into and out of the SPD EEPROM. An external resistor may be connected from the SCL bus time to VDDSPD to act as a pullup on the system board. This signal indicates that a thermal event has been detected in the thermal sensing device. The system /EVENT VDD SPD Power and ground for DDR3 SDRAM input buffers, and core logic. VDD and VDDQ pins are tied to Should guarantee the electrical level requirement is met for /EVENT pin on TS/SPD part Supply Power supply for SPD EEPROM. This supply is separate from the VDD/VDDQ power plane. EEPROM supply is operable from 3.0V to 3.6V. 6 REV 3.0 DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC FUNCTIONAL BLOCK DIAGRAM 7 REV 3.0 DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC PACKAGE DIMENSIONS Unit :mm Tolerances : + 0.15mm unless otherwise specified The used device is 128Mx8 PROMOS, DDR3,FBGA DDR3 SDRAM Part No.: V73CBG01808RBJ11 *8EA 8 REV 3.0 DDR3-1066 1GB SO-DIMM 204PIN With PROMOS 128Mx8 DRAM D3SP28081XH18AC Declaration of Compliance with the RoHS Directive DATA SPECIALTIES CO.,LTD Hereby declares that the products compliant with the European Union Directive 2002/95/EC for Restriction of the use of certain Hazardous Substances in Electrical and Electronic Equipment(RoHS Directive). Below list of DSL(DATA SPECIALTIES CO.,LTD.) products are Compliance. No. Substance Max. Conc. 1 Cd (Cadmium)
MIM-3231-DSL 价格&库存
很抱歉,暂时无法提供与“MIM-3231-DSL”相匹配的价格&库存,您可以联系我们找货
