TLK2701IRCPG4
TLK2701IRCPG4
    ROCHESTER(罗切斯特)
    VFQFP64_EP
    TELECOM CIRCUIT, 1-FUNC, PQFP64
TLK2701IRCPG4 数据手册
TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 D 1.6 to 2.7 Gigabits Per Second (Gbps) D D D D D D Serializer/Deserializer Hot-Plug Protection High-Performance 64-Pin VQFP Thermally Enhanced Package (PowerPAD) 2.5-V Power Supply for Low Power Operation Programmable Voltage Output Swing on Serial Output Interfaces to Backplane, Copper Cables, or Optical Converters On-Chip 8-Bit/10-Bit Encoding/Decoding, Comma Detect D On-Chip PLL Provides Clock Synthesis From Low-Speed Reference D Receiver Differential Input Thresholds D D D D D D 200 mV Minimum Low Power: < 500 mW 3 V Tolerance on Parallel Data Input Signals 16-Bit Parallel TTL Compatible Data Interface Ideal for High-Speed Backplane Interconnect and Point-to-Point Data Link Industrial Temperature Range (−40°C to 85°C) Loss of Signal (LOS) Detection description The TLK2701 is a member of the transceiver family of multigigabit transceivers, intended for use in ultrahigh-speed bidirectional point-to-point data transmission systems. The TLK2701 supports an effective serial interface speed of 1.6 Gbps to 2.7 Gbps, providing up to 2.16 Gbps of data bandwidth. The primary application of this chip is to provide very high-speed I/O data channels for point-to-point baseband data transmission over controlled impedance media of approximately 50 Ω. The transmission media can be printed-circuit board, copper cables, or fiber-optic cable. The maximum rate and distance of data transfer is dependent upon the attenuation characteristics of the media and the noise coupling to the environment. This device can also be used to replace parallel data transmission architectures by providing a reduction in the number of traces, connector terminals, and transmit/receive terminals. Parallel data loaded into the transmitter is delivered to the receiver over a serial channel, which can be a coaxial copper cable, a controlled impedance backplane, or an optical link. It is then reconstructed into its original parallel format. It offers significant power and cost savings over current solutions, as well as scalability for higher data rate in the future. The TLK2701 performs data conversion parallel-to-serial and serial-to-parallel. The clock extraction functions as a physical layer interface device. The serial transceiver interface operates at a maximum speed of 2.7 Gbps. The transmitter latches 16-bit parallel data at a rate based on the supplied reference clock (GTX_CLK). The 16-bit parallel data is internally encoded into 20 bits using an 8-bit/10-bit (8B/10B) encoding format. The resulting 20-bit word is then transmitted differentially at 20 times the reference clock (GTX_CLK) rate. The receiver section performs the serial-to-parallel conversion on the input data, synchronizing the resulting 20-bit wide parallel data to the extracted reference clock (RX_CLK). It then decodes the 20 bit wide data using 8-bit/10-bit decoding format resulting in 16 bits of parallel data at the receive data terminals (RXD0-15). The outcome is an effective data payload of 1.28 Gbps to 2.16 Gbps (16 bits data x the GTX_CLK frequency). The TLK2701 is housed in a high performance, thermally enhanced, 64-pin VQFP PowerPAD package. Use of the PowerPAD package does not require any special considerations except to note that the PowerPAD, which is an exposed die pad on the bottom of the device, is a metallic thermal and electrical conductor. It is recommended that the TLK2701 PowerPAD be soldered to the thermal land on the board. All ac performance specifications in this data sheet are measured with the PowerPAD soldered to the test board. The TLK2701 provides an internal loopback capability for self-test purposes. Serial data from the serializer is passed directly to the deserializer, allowing the protocol device a functional self-check of the physical interface. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. PowerPAD is a trademark of Texas Instruments. Copyright  2000 − 2008, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 description (continued) The TLK2701 has a loss of signal detection circuit for conditions where the incoming signal no longer has a sufficient voltage amplitude to keep the clock recovery circuit in lock. The TLK2701 allows users to implement redundant ports by connecting receive data bus terminals from two TLK2701 devices together. Asserting the LCKREFN to a low state will cause the receive data bus terminals, RXD[0:15], RX_CLK, and RKLSB, RKMSB/PRBS_PASS to go to a high-impedance state. This places the device in a transmit-only mode since the receiver is not tracking the data. The TLK2701 uses a 2.5 V supply. The I/O section is 3 V compatible. With the 2.5-V supply the chipset is very power efficient consuming less than 350 mW typically. The TLK2701 is characterized for operation from −40°C to 85°C. The TLK2701 is designed to be hot plug capable. An on-chip power-on reset circuit holds the RX_CLK low and goes to high impedance to the parallel side output signal terminals during power up as well as goes to DOUTTXP and DOUTTXN. AVAILABLE OPTIONS PACKAGE TA PowerPAD QUAD FLATPACK (VQFP) −40°C to 85°C TLK2701IRCP 1 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 2 47 3 46 4 45 5 44 6 43 7 42 8 41 9 40 10 39 11 38 12 37 13 36 14 35 15 34 33 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 TXD14 GND TXD15 TKMSB LOOPEN TKLSB V DD ENABLE LCKREFN PRBSEN TESTEN GND RKLSB/PRBS_PASS RKMSB RXD15 RXD14 VDD TXD3 TXD4 TXD5 GND TXD6 TXD7 GTX_CLK VDD TXD8 TXD9 TXD10 GND TXD11 TXD12 TXD13 RXD1 RXD2 TXD2 TXD1 TXD0 GNDA DOUTTXP DOUTTXN GNDA VDDA RREF VDDA DINRXP DINRXN GNDA RXD0 RCP PACKAGE (TOP VIEW) 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 VDD RXD3 RXD4 RXD5 RXD6 GND RXD7 RX_CLK RXD8 RXD9 VDD RXD10 RXD11 RXD12 RXD13 GND TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 block diagram LOOPEN PRBSEN PRBSEN PRBS Generator DOUTTXP 10 DOUTTXN 10 Parallel to Serial BIAS 10 RREF MUX TKLSB 9 TKMSB 8B/10B Encoder TD0−TD15 18 Bit Register 9 8B/10B Encoder 2:1 10 MUX 10 Clock Synthesizer GTX_CLK TESTEN Controls: PLL,Bias,Rx, Tx ENABLE PRBSEN 2:1 MUX RKLSB/ PRBS_PASS 18 Bit Register 9 RKMSB PRBS Verification PRBSEN RX_CLK RDO−RD15 Interpolator and Clock Recovery 9 Comma Detect and 8B/10B Decoding Comma Detect and 8B/10B Decoding Clock 2:1 MUX Recovered Clock 10 1:2 MUX 10 Serial to Parallel 2:1 MUX Data DINRXP DINRXN 10 Signal Detect (LOS) Figure 1. TLK2701 Block Diagram POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 3 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 Terminal Functions TERMINAL NAME NO. I/O DESCRIPTION DINRXN DINRXP 53 54 I Serial receive inputs. DINRXP and DINRXN together are the differential serial input interface from a copper or an optical I/F module. DOUTTXN DOUTTXP 59 60 O Serial transmit outputs. DOUTTXP and DOUTTXN are differential serial outputs that interface to copper or an optical I/F module. These terminals transmit NRZ data at a rate of 20 times the GTX_CLK value. DOUTTXP and DOUTTXN are put in a high-impedance state when LOOPEN is high and are active when LOOPEN is low. During power-on reset these terminals are high impedance. ENABLE 24 I Device enable. When this terminal is held low, the device is placed in power-down mode. Only the signal detect circuit on the serial receive pair is active. When asserted high while the device is in power-down mode, the transceiver will go into power-on reset before beginning normal operation. GND 5, 13, 18, 28, 33, 43 GNDA 52, 58, 61 Digital logic ground. Provides a ground for the logic circuits and digital I/O buffers. Analog ground. GNDA provides a ground reference for the high-speed analog circuits, RX and TX. GTX_CLK 8 I Reference clock. GTX_CLK is a continuous external input clock that synchronizes the transmitter interface signals TKMSB, TKLSB and TXD. The frequency range of GTX_CLK is 80 MHz to 135 MHz. The transmitter uses the rising edge of this clock to register the 16-bit input data (TXD) for serialization. LCKREFN 25 I Lock to reference. When LCKREFN is low, the receiver clock is frequency locked to GTX_CLK. This places the device in a transmit only mode since the receiver is not tracking the data. When LCKREFN is asserted low, the receive data bus terminals, RXD[0:15], RX_CLK and RKLSB, RKMSB/LOS are in a high-impedance state. When LCKREFN is deasserted high, the receiver is locked to the received data stream. LOOPEN 21 I Loop enable. When LOOPEN is active high, the internal loop-back path is activated. The transmitted serial data is directly routed internally to the inputs of the receiver. This provides a self-test capability in conjunction with the protocol device. The DOUTTXP and DOUTTXN outputs are held in a high-impedance state during the loop-back test. LOOPEN is held low during standard operational state with external serial outputs and inputs active. PRBSEN 26 I PRBS test enable. When asserted high results of pseudo random bit stream (PRBS) tests can be monitored on the RKLSB/PRBS_PASS terminal. A high on PRBS_PASS indicates that valid PRBS is being received. RREF 56 I Reference resistor. The RREF terminal is used to connect to an external reference resistor. The other side of the resistor is connected to analog VDD. The resistor is used to provide an accurate current reference to the transmitter circuitry. RXD0 RXD1 RXD2 RXD3 RXD4 RXD5 RXD6 RXD7 RXD8 RXD9 RXD10 RXD11 RXD12 RXD13 RXD14 RXD15 51 50 49 47 46 45 44 42 40 39 37 36 35 34 32 31 O Receive data bus. These outputs carry 16-bit parallel data output from the transceiver to the protocol device, synchronized to RX_CLK. The data is valid on the rising edge of RX_CLK as shown in Figure 11. These terminals are in high-impedance state during power-on reset. 4 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 Terminal Functions (Continued) TERMINAL NAME NO. I/O DESCRIPTION RX_CLK 41 O Recovered clock. Output clock that is synchronized to RXD, RKLSB, RKMSB/LOS. RX_CLK is the recovered serial data rate clock divided by 20. RX_CLK is held low during power-on reset. RKLSB/ PRBS_PASS 29 O K-Code indicator/PRBS test results. When RKLSB is active, an 8-bit/10-bit K code was received and is indicated by data bits RXD0 −RXD7. When RKLSB is inactive an 8-bit/10-bit D code is received and is presented on data bits RXD0 − RXD7. When PRBSEN is asserted high then this pin is used to indicate status of the PRBS test results (high = pass). RKMSB 30 O K-code indicator. When RKMSB is active an 8-bit/10-bit K code was received and is indicated by data bits RXD8 −RXD15. When RKMSB is inactive an 8-bit/10-bit D code was received and is presented on data bits RXD8 − RXD15. TESTEN 27 I Test mode enable. This terminal should be left unconnected or tied low. TXD0 TXD1 TXD2 TXD3 TXD4 TXD5 TXD6 TXD7 TXD8 TXD9 TXD10 TXD11 TXD12 TXD13 TXD14 TXD15 62 63 64 2 3 4 6 7 10 11 12 14 15 16 17 19 I Transmit data bus. These inputs carry the 16-bit parallel data output from a protocol device to the transceiver for encoding, serialization, and transmission. This 16-bit parallel data is clocked into the transceiver on the rising edge of GTX_CLK as shown in Figure 10. TKMSB 20 I K-code generator (MSB). When TKMSB is active an 8-bit/10-bit K code is transmitted as controlled by data bits TXD8 −TXD15. When TKMSB is inactive an 8-bit/10-bit D code is transmitted as controlled by data bits TXD8 − TXD15. TKLSB 22 I K-code generator (LSB). When TKLSB is active an 8-bit/10-bit K code is transmitted as controlled by data bits TXD0 −TXD7. When TKLSB is inactive an8-bit/10-bit D code is transmitted as controlled by data bits TXD0 − TXD7. VDD 1, 9, 23, 38, 48 VDDA 55, 57 Digital logic power. Provides power for all digital circuitry and digital I/O buffers. Analog power. VDDA provides a supply reference for the high-speed analog circuits, receiver and transmitter detailed description transmit interface The transmitter portion registers valid incoming 16-bit wide data (TXD[0:15]) on the rising edge of the GTX_CLK. The data is then 8-bit/10-bit encoded, serialized, and transmitted sequentially over the differential high-speed I/O channel. The clock multiplier multiplies the reference clock (GTX_CLK) by a factor of 10 times, creating a bit clock. This internal bit clock is fed to the parallel-to-serial shift register which transmits data on both the rising and falling edges of the bit clock, providing a serial data rate that is 20 times the reference clock. Data is transmitted LSB (D0) first. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 5 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 detailed description (continued) transmit data bus The transmit bus interface accepts 16-bit single-ended TTL parallel data at the TXD[0:15] terminals. Data and k-code control is valid on the rising edge of the GTX_CLK. The GTX_CLK is used as the word clock. The data, k-code, and clock signals must be properly aligned as shown in Figure 2. Detailed timing information can be found in the electrical characteristics table. GTX_CLK TXD[0−15] tsu th TXLSB, TXMSB Figure 2. Transmit Timing Waveform transmission latency The data transmission latency of the TLK2701 is defined as the delay from the initial 16-bit word load to the serial transmission of bit 0. The transmit latency is fixed once the link is established. However, due to silicon process variations and implementation variables such as supply voltage and temperature, the exact delay will vary slightly. The minimum transmit latency (Tlatency ) is 34 bit times; the maximum is 38 bit times. Figure 3 illustrates the timing relationship between the transmit data bus, the GTX_CLK and serial transmit terminals. Transmitted 20 bit Word DOUTTXP, DOUTTXN (Tlatency)† TXD[0−15] 16 bit Word to Transmit GTX_CLK Figure 3. Transmitter Latency 8-bit/10-bit encoder All true serial interfaces require a method of encoding to insure minimum transition density so that the receiving PLL has a minimal number of transitions to stay locked on. The encoding scheme maintains the signal dc balance by keeping the number of ones and zeros the same. This provides good transition density for clock recovery and improves error checking. The TLK2701 uses the 8-bit/10-bit encoding algorithm that is used by fibre channel and gigabit ethernet. This is transparent to the user, as the TLK2701 internally encodes and decodes the data such that the user reads and writes actual 16-bit data. 6 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 8-bit/10-bit encoder (continued) The 8-bit/10-bit encoder converts 8-bit wide data to a 10-bit wide encoded data character to improve its transmission characteristics. Since the TLK2701 is a 16-bit wide interface, the data is split into two 8-bit wide bytes for encoding. Each byte is fed into a separate encoder. The encoding is dependant upon two additional input signals, the TKMSB and TKLSB. Table 1. Transmit Data Controls TKLSB TKMSB 0 0 Valid data on TXD(0−7), DECODED 20 BIT OUTPUT 0 1 Valid data on TXD(0−7), K code on TXD(8−15) 1 0 K code on TXD(0−7), Valid data on TXD(8−15) 1 1 K code on TXD(0−7), K code on TXD(8−15) Valid data TXD(8−15) PRBS generator The TLK2701 has a built-in 27-1 PRBS (pseudorandom bit stream) function. When the PRBSEN terminal is forced high, the PRBS test is enabled. A PRBS is generated and fed into the 10-bit parallel-to-serial converter input register. Data from the normal input source is ignored during the PRBS mode. The PRBS pattern is then fed through the transmit circuitry as if it were normal data and sent out to the transmitter. The output can be sent to a BERT (bit error rate tester), the receiver of another TLK2701, or can be looped back to the receive input. Since the PRBS is not really random but a predetermined sequence of ones and zeroes, the data can be captured and checked for errors by a BERT. parallel-to-serial The parallel-to-serial shift register takes in the 20-bit wide data word multiplexed from the two parallel 8-bit/10-bit encoders and converts it to a serial stream. The shift register is clocked on both the rising and falling edge of the internally generated bit clock, which is 10 times the GTX_CLK input frequency. The LSB (D0) is transmitted first. high-speed data output The high-speed data output driver consists of a current-mode logic (CML) differential pair that can be optimized for a particular transmission line impedance and length. The line can be directly-coupled or ac-coupled. Refer to Figure 15 and Figure 16 for termination details. receive interface The receiver portion of the TLK2701 accepts 8-bit/10-bit encoded differential serial data. The interpolator and clock recovery circuit will lock to the data stream and extract the bit rate clock. This recovered clock is used to retime the input data stream. The serial data is then aligned to two separate 10-bit word boundaries, 8-bit/10-bit decoded and output on a 16-bit wide parallel bus synchronized to the extracted receive clock. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 7 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 detailed description (continued) receive data bus The receive bus interface drives 16-bit wide single-ended TTL parallel data at the RXD[0:15] terminals. Data is valid on the rising edge of the RX_CLK The RX_CLK is used as the recovered word clock. The data, enable, and clock signals are aligned as shown in Figure 4. Detailed timing information can be found in the switching characteristics table. RX_CLK RXD[0−15] tsu th RXLSB, RXMSB Figure 4. Receive Timing Waveform data reception latency The serial-to-parallel data receive latency is the time from when the first bit arrives at the receiver until it is output in the aligned parallel word with RXD0 received as first bit. The receive latency is fixed once the link is established. However, due to silicon process variations and implementation variables such as supply voltage and temperature, the exact delay will vary slightly. The minimum receive latency (Rlatency) is 76 bit times; the maximum is 107 bit times. Figure 5 illustrates the timing relationship between the serial receive terminals, the recovered word clock (RX_CLK), and the receive data bus. 20-Bit Encoded Word DINTXP, DINTXN (Rlatency)† RXD[0−15] 16-Bit Decoded Word RX_CLK Figure 5. Receiver Latency serial-to-parallel Serial data is received on the DINRXP and DINRXN terminals. The interpolator and clock recovery circuit will lock to the data stream if the clock to be recovered is within 200 PPM of the internally generated bit rate clock. The recovered clock is used to retime the input data stream. The serial data is then clocked into the serial-to-parallel shift registers. The 10-bit wide parallel data is then multiplexed and fed into two separate 8-bit/10-bit decoders where the data is then synchronized to the incoming data steam word boundary by detection of the comma 8-bit/10-bit synchronization pattern. 8 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 detailed description (continued) comma detect and 8-bit/10-bit decoding The TLK2701 has two parallel 8-bit/10-bit decode circuits. Each 8-bit/10-bit decoder converts 10 bit encoded data (half of the 20 bit received word) back into 8-bits. The comma detect circuit is designed to provide for byte synchronization to an 8-bit/10-bit transmission code. When parallel data is clocked into a parallel to serial converter, the byte boundary that was associated with the parallel data is now lost in the serialization of the data. When the serial data is received and converted to parallel format again, a way is needed to recognize the byte boundary. Generally this is accomplished through the use of a synchronization pattern. This is generally a unique pattern of 1s and 0s that either cannot occur as part of valid data or is a pattern that repeats at defined intervals. The 8-bit/10-bit encoding contains a character called the comma (b0011111 or b1100000), which is used by the comma detect circuit on the TLK2701 to align the received serial data back to its original byte boundary. The decoder detects the comma, generating a synchronization signal aligning the data to their 10-bit boundaries for decoding; the comma is mapped into the LSB. It then converts the data back into 8-bit data. The output from the two decoders is latched into the 16-bit register synchronized to the recovered parallel data clock (RX_CLK) and output valid on the rising edge of the RX_CLK. NOTE: The TLK2701 only achieves byte alignment on the 0011111 comma. Decoding provides two additional status signals, RKLSB and RKMSB. When RKLSB is asserted , an 8-bit/10-bit K code was received and the specific K code is presented on the data bits RXD0 − RXD7, else an 8-bit/10-bit D code was received. When TKMSB is asserted, an 8-bit/10-bit K code was received and the specific K code is presented on data bits RXD8 − RXD15, else an 8-bit/10-bit D code was received. The valid K codes the TLK2701 will decode are provided in Table 3. An error detected on either byte, including K codes not in Table 3, will cause that byte only to indicate a K0.0 code on the RK×SB and associated data pins, where K0.0 is known to be an invalid 8-bit/10-bit code. A loss of input signal will cause a K31.7 code to be presented on both bytes, where K31.7 is also known to be an invalid 8-bit/10-bit code. Table 2. Receive Status Signals RKLSB RKMSB 0 0 Valid data on RXD(0−7), DECODED 20 BIT OUTPUT Valid data RXD(8−15) 0 1 Valid data on RXD(0−7), K code on RXD(8−15) 1 0 K code on RXD(0−7), Valid data on RXD(8−15) 1 1 K code on RXD(0−7), K code on RXD(8−15) Table 3. Valid K Characters K CHARACTER RECEIVE DATA BUS (RXD[7−0]) OR (RXD[15−8]) K28.0 000 11100 K28.1 001 11100 K28.2 010 11100 K28.3 011 11100 K28.4 100 11100 K28.5 101 11100 K28.6 110 11100 K28.7 111 11100 K23.7 111 10111 K27.7 111 11011 K29.7 111 11101 K30.7 111 11110 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 9 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 detailed description (continued) power down mode When the ENABLE pin is deasserted low, the TLK2701 will go into a power down mode. In the power down mode, the serial transmit pins (DOUTTXP, DOUTTXN), the receive data bus pins (RXD[0:15]), and RKLSB will go into a high-impedance state. In the power down condition, the signal detection circuit draws less than 15 mW. When the TLK2701 is in the power-down mode, the clock signal on the GTX_CLK terminal must be provided. loss of signal detection The TLK2701 has a loss of signal detection circuit for conditions where the incoming signal no longer has a sufficient voltage level to keep the clock recovery circuit in lock. The signal detection circuit is intended to be an indication of gross signal error conditions, such as a detached cable or no signal being transmitted, and not an indication of signal coding health. The TLK2701 reports this condition by asserting, the RKMSB/LOS, RKLSB and RXD[0:15] all to a high state. As long as the signal is above 200 mV in differential magnitude, the LOS circuit will not signal an error condition. PRBS verification The TLK2701 also has a built-in BERT function in the receiver side that is enabled by the PRBSEN. It can check for errors and report the errors by forcing the RKLSB/PRBSPASS terminal low. reference clock input The reference clock (GTX_CLK) is an external input clock that synchronizes the transmitter interface. The reference clock is then multiplied in frequency 10 times to produce the internal serialization bit clock. The internal serialization bit clock is frequency-locked to the reference clock and used to clock out the serial transmit data on both its rising and falling edge clock, providing a serial data rate that is 20 times the reference clock. operating frequency range The TLK2701 may operate at a serial data rate between 1.6 Gbps to 2.7 Gbps. The GTX_CLK must be within ±100 PPM of the desired parallel data rate clock. testability The TLK2701 has a comprehensive suite of built-in self-tests. The loopback function provides for at-speed testing of the transmit/receive portions of the circuitry. The enable terminal allows for all circuitry to be disabled so that an IDDQ test can be performed. The PRBS function allows for a BIST (built-in self-test). loopback testing The transceiver can provide a self-test function by enabling (LOOPEN) the internal loop-back path. Enabling this terminal will cause serial-transmitted data to be routed internally to the receiver. The parallel data output can be compared to the parallel input data for functional verification. (The external differential output is held in a high-impedance state during the loopback testing.) built-in self-test (BIST) The TLK2701 has a BIST function. By combining PRBS with loopback, an effective self-test of all the circuitry running at full speed can be realized. The successful completion of the BIST is reported on the RKLSB/ PRBS_PASS terminal. power-on reset Upon application of minimum valid power, the TLK2701 generates a power-on reset. During the power-on reset the RXD, RKLSB, and RKMSB/LOS signal terminals go to a high-impedance state. The RX_CLK is held low. The length of the power-on reset cycle is dependent upon the REFCLK frequency, but is less than 1 ms. 10 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 absolute maximum ratings over operating free-air temperature (unless otherwise noted)† Supply voltage, VDD (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.3 to 3 V Voltage range at TXD, ENABLE, GTX_CLK, TKLMSB, TKLLSB, LOOPEN, PRBS_PASS . . . . . . . . −0.3 to 4 V Voltage range at any other terminal except above . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.3 to VDD+0.3 V Package power dissipation, PD . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . See Dissipation Rating Table Storage temperature, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −65°C to 150°C Electrostatic discharge . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . HBM:2 kV, CDM:1 kV Characterized free-air operating temperature range, TA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −40°C to 85°C Lead temperature 1,6 mm (1/16 inch) from case for 10 seconds . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260°C † Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTE 1: All voltage values, except differential I/O bus voltages, are with respect to network ground. DISSIPATION RATING TABLE PACKAGE TA ≤ 2 5_C POWER RATING DERATING FACTOR‡ ABOVE TA = 25_C TA = 70_C POWER RATING RCP64§ 5.25 W 46.58 mW/_C 2.89 W RCP64¶ 3.17 W 23.70 mW/_C 1.74 W RCP64# 2.01 W 13.19 mW/_C 1.11 W ‡ This is the inverse of the traditional junction-to-ambient thermal resistance (RθJA). § 2 oz. Trace and copper pad with solder. ¶ 2 oz. Trace and copper pad without solder. # Standard JEDEC High-K board. For more information, refer to TI application note PowerPAD Thermally Enhanced Package, TI literature number SLMA002. electrical characteristics over recommended operating conditions PARAMETER TEST CONDITIONS Supply voltage, VDD Supply current, ICC Power dissipation, PD NOM MAX 2.3 2.5 2.7 UNIT V Frequency = 1.6 Gbps, PRBS pattern 105 Frequency = 2.7 Gbps, PRBS pattern 156 Frequency = 1.6 Gbps, PRBS pattern 262 mW Frequency = 2.7 Gbps, PRBS pattern 390 mW Frequency = 2.7 Gbps, worst case mA pattern|| Shutdown current Enable = 0, VDDA, VDD terminals, VDD = MAX PLL startup lock time VDD,VDDC = 2.3V 500 3 mW mA 0.1 Operating free-air temperature, TA || MIN −40 0.4 ms 85 °C Worst case pattern is a pattern that creates a maximum transition density on the serial transceiver. reference clock (GTX_CLK) timing requirements over recommended operating conditions (unless otherwise noted) MAX UNIT Frequency PARAMETER Minimum data rate TEST CONDITIONS Typ −0.01% 80 Typ+0.01% MHz Frequency Maximum data rate Typ −0.01% 135 Typ+0.01% MHz 100 ppm Frequency tolerance TYP −100 Duty cycle Jitter MIN 40% Peak-to-peak POST OFFICE BOX 655303 50% 60% 40 • DALLAS, TEXAS 75265 ps 11 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 TTL input electrical characteristics over recommended operating conditions (unless otherwise noted), TTL signals: TXDO−TXD15, GTX_CLK, LOOPEN, LCKREFN, PRBS_PASS, TKLSB, TKMSB PARAMETER TEST CONDITIONS MIN NOM 2 MAX UNIT VIH High-level input voltage See Figure 10 3.6 VIL Low-level input voltage See Figure 10 IIL Input high current VDD = MAX, VIN = 2 V IIH Input low current VDD = MAX, VIN = 0.4 V CI Receiver input capacitance tr Rise time, GTX_CLK, TKMSB, TKLSB, TXD 0.7 V to 1.9 V, C = 5 pF, See Figure 10 tf Fall time, GTX_CLK, TKMSB, TKLSB, TXD 1.9 V to 0.7 V, C = 5 pF, See Figure 10 tsu TXD, TKMSB, TKLSB setup to ↑ GTX_CLK See Figure 10 1.5 ns th TXD, TKMSB, TKLSB hold to ↑ GTX_CLK See Figure 10 0.4 ns 0.80 V 40 µA µA −40 4 ns 1 ns GTX_CLK 0.8 V 0V tf 3.6 V 2.0 V TXLSB, TXMSB, TXD[0−15] 0.8 V 0V tr tsu tf th Figure 6. TTL Data Input Valid Levels for AC Measurements 12 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 pF 1 3.6 V 2.0 V tr V TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 TTL output switching characteristics over recommended operating conditions (unless otherwise noted) PARAMETER TEST CONDITIONS MIN NOM 1.7 2.3 GND 0.25 MAX UNIT VOH High-level output voltage IOH = −1 mA, VDD = MIN VOL Low-level output voltage IOL = 1 mA, VDD = MIN tr(slew) Slew rate (rising), magnitude of RX_CLK, RKLSB, RKMSB/LOS, RXD 0.8 V to 2 V, C = 5 pF, See Figure 11 0.5 V/ns tf(slew) Slew rate (falling), magnitude of RX_CLK, RKLSB, RKMSB/LOS, RXD 0.8 V to 2 V, C = 5 pF, See Figure 11 0.5 V/ns 50% voltage swing, GTX_CLK = 80 MHz, See Figure 11, 5.4 ns 50% voltage swing, GTX_CLK = 135 MHz, See Figure 11, 2.7 ns 50% voltage swing, GTX_CLK = 80 MHz, See Figure 11, 5.4 ns 50% voltage swing, GTX_CLK = 135 MHz, See Figure 11, 2.7 ns tsu th RXD, RKMSB/LOS, RKLSB setup to ↑ RX_CLK RXD, RKMSB/LOS, RKLSB hold to ↑ RX_CLK V 0.5 V 2.7 V 2.0 V RX_CLK 0.8 V 0V tr(slew) tf(slew) 2.7 V 2.0 V RKLSB, RKMSB, RXD[0−15] 0.8 V 0V tr(slew) tsu tf(slew) th Figure 7. TTL Data Output Valid Levels for AC Measurements POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 13 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 transmitter/receiver characteristics MIN NOM MAX UNIT V(odp) V(odp) = |VTXP−VTXN|, Preemphasis VOD, direct PARAMETER Rt = 50 Ω, RREF = 200 Ω, dc-coupled, See Figure 8 TEST CONDITIONS 840 1050 1260 mV V(odd) V(odd) = |VTXP−VTXN|, De-emphasis VOD, direct Rt = 50 Ω, RREF= 200 Ω, dc-coupled, See Figure 8 760 950 1140 mV V(term) Transmit termination voltage range V(ID) Receiver input voltage requirement, VID=|RXP – RXN| V(cmv) Receiver common mode voltage range, (VRXP + VRXN)/2 Ilkg(R) Receiver input leakage CI Receiver input capacitance Rt = 50 Ω, dc-coupled, See Figure 11 VDD Rt = 50 Ω, ac-coupled, See Figure 12 1500 VDD−VID/2 200 mV mV 1500 VDD−VID/2 mV −10 10 µA 2 pF tTJ Serial data total jitter (peak-to-peak) Differential output jitter at 2.7 Gbps, random + deterministic, PRBS pattern tTJ Serial data total jitter (peak-to-peak) Differential output jitter at 1.6 Gbps, random + deterministic, PRBS pattern tr, tf Differential output signal rise, fall time (20% to 80%) RL = 50 Ω, CL = 5 pF, See Figure 12 100 Jitter tolerance Differential input jitter, random + determinisitc, PRBS pattern at zero crossing 0.60 0.15 UI 0.15 UI 150 ps UI T(latency) Tx latency 34 38 bits R(latency) Rx latency 76 107 bits MAX UNIT VOD(p) VOD(d) V(TERM) tf VOD(d) tr Bit Time Bit Time VOD(p) Figure 8. Differential and Common-Mode Output Voltage Definitions THERMAL INFORMATION PARAMETER RθJA Junction-to-free-air thermal resistance RθJC Junction-to-case-thermal resistance RθJA Junction-to-free-air thermal resistance RθJC Junction-to-case-thermal resistance RθJA Junction-to-free-air thermal resistance RθJC Junction-to-case-thermal resistance 14 TEST CONDITION MIN TYP Board-mounted, no air flow, high conductivity TI recommended test board, chip soldered or greased to thermal land 21.47 Board-mounted, no air flow, high conductivity TI recommended test board with thermal land but no solder or grease thermal connection to thermal land 42.20 Board-mounted, no air flow, JEDEC test board POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 0.38 0.38 75.83 7.8 ° °C/W ° °C/W ° °C/W TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 APPLICATION INFORMATION VDDA Vt 1 nF − 10 nF 1 nF − 10 nF 1 nF − 10 nF Rt Recommended use of 0.01 µF Capacitor per VDD terminal Rt 0.01 µF 5 Ω at 100 MHz RXD0 RREF 810 Ω TXD0 TXD2 TXD1 Vt RXD1 RXD2 0.01 µF 200 Ω 45 5 44 RXD6 TXD6 6 43 GND TXD7 7 42 RXD7 GTX_CLK 8 41 RX_CLK VDD 9 40 RXD8 TXD8 10 39 RXD9 TXD9 11 38 VDD TXD10 12 37 RXD10 GND 13 36 RXD11 TXD11 14 35 RXD12 TXD12 15 34 RXD13 TXD13 33 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 GND RXD14 RXD15 46 RKMSB/LOS KLSB/PRBS_PASS GND TESTEN LCKREFN TKLSB V DD ENABLE LOOPEN GND TXD15 TKMSB GNDA 4 GND DINRXP 3 TXD5 DINRXN TXD4 VDD RXD3 RXD4 RXD5 RREF V DDA 47 GNDA V DDA 2 DOUTTXP 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 DOUTTXN 1 GNDA VDD TXD3 TXD14 0.01 µF 0.01 µF 0.01 µF Rt 1 nF − 10 nF PRBSEN VDD Rt Figure 9. External Component Interconnection POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 15 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 APPLICATION INFORMATION recommended values of external resistors (1% tolerance) PARAMETER R(t), Termination resistor R(REF), Reference resistor TEST CONDITIONS RECOMMENDED 50 Ω environment 50 75 Ω environment 75 50 Ω environment 200 75 Ω environment 300 UNIT Ω Ω VOLTAGE vs RESISTOR REFERENCE 2.0 1.8 VODD at 75 Ω VODP or VODD − V 1.6 VODP at 75 Ω 1.4 1.2 1.0 0.8 0.6 100 VODD at 50 Ω VODP at 50 Ω 150 200 250 300 RREF − Resistor Reference − Ω Figure 10. Differential Transmitter Voltage choosing RREF resistor values TLK2701 offers the flexibility to customize the voltage swing and transmission line termination by adjusting the reference resistor, RREF, and termination resistor, Rt. By choosing particular resistor values, the system can be optimized for a particular transmission line impedance, length, and controlling the output swing for EMI and attenuation concerns. Refer to Figure 10 to determine the nominal voltage swing and driver current as a function of resistor values. It is recommended that 1% tolerance resistors be used. Refer to Figure 11 for high-speed I/O directly coupled mode and Figure 12 for high-speed I/O ac-coupled mode. 16 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 APPLICATION INFORMATION VTERM Rt TXP RXP + _ VTERM Rt TXN Data RXN Data VTERM = VDD Preemphasis = 21 mA (See Note A) De-Emphasis = 19 mA TRANSMITTER MEDIA RECEIVER NOTE A: This assumes RREF = 200 Ω and termination resistance = 50 Ω. See Figure 10 and section choosing RREF resistor values for more information. Figure 11. High-Speed I/O Directly-Coupled Mode POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 17 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 APPLICATION INFORMATION VDD VTERM Rt Rt RXP TXP VDD Rt TXN Data 0.01 µF 0.01 µF + _ VTERM RXN Rt VDD Data 200 Ω VTERM 820 Ω Preemphasis = 21 mA (See Note A) De-Emphasis = 19 mA TRANSMITTER MEDIA RECEIVER NOTE A: This assumes RREF = 200 Ω and termination resistance = 50 Ω. See Figure 10 and section choosing RREF resistor values for more information. Figure 12. High-Speed I/O AC-Coupled Mode 18 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 TLK2701 1.6 TO 2.7 GBPS TRANSCEIVER SLLS429D − AUGUST 2000 − REVISED MARCH 2008 APPLICATION INFORMATION designing with PowerPAD The TLK2701 is housed in a high-performance, thermally enhanced, 64-pin VQFP (RCP64) PowerPAD package. Use of the PowerPAD package does not require any special considerations except to note that the PowerPAD, which is an exposed die pad on the bottom of the device, is a metallic thermal and electrical conductor. Therefore, if not implementing PowerPAD PCB features, the use of solder masks (or other assembly techniques) may be required to prevent any inadvertent shorting by the exposed PowerPAD of connection etches or vias under the package. It is strongly recommended that the PowerPAD be soldered to the thermal land. The recommended convention, however, is to not run any etches or signal vias under the device, but to have only a grounded thermal land as explained below. Although the actual size of the exposed die pad may vary, the minimum size required for the keep-out area for the 64-pin PFP PowerPAD package is 8 mm X 8 mm. It is recommended that there be a thermal land, which is an area of solder-tinned-copper, underneath the PowerPAD package. The thermal land will vary in size depending on the PowerPAD package being used, the PCB construction, and the amount of heat that needs to be removed. In addition, the thermal land may or may not contain numerous thermal vias depending on PCB construction. Other requirements for thermal lands and thermal vias are detailed in the TI application note PowerPAD Thermally Enhanced Package Application Report, TI literature number SLMA002, available via the TI Web pages beginning at URL: http://www.ti.com. Figure 13. Example of a Thermal Land For the TLK2701, this thermal land should be grounded to the low-impedance ground plane of the device. This improves not only thermal performance but also the electrical grounding of the device. It is also recommended that the device ground terminal landing pads be connected directly to the grounded thermal land. The land size should be as large as possible without shorting device signal terminals. The thermal land may be soldered to the exposed PowerPAD using standard reflow soldering techniques. While the thermal land may be electrically floated and configured to remove heat to an external heat sink, it is recommended that the thermal land be connected to the low impedance ground plane for the device. More information may be obtained from the TI application note PHY Layout, TI literature number SLLA020. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 19 PACKAGE OPTION ADDENDUM www.ti.com 12-Aug-2016 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) TLK2701IRCP LIFEBUY HVQFP RCP 64 160 Green (RoHS & no Sb/Br) CU NIPDAU Level-3-260C-168 HR -40 to 85 TLK2701 TLK2701IRCPG4 LIFEBUY HVQFP RCP 64 160 Green (RoHS & no Sb/Br) CU NIPDAU Level-3-260C-168 HR -40 to 85 TLK2701 TLK2701IRCPR LIFEBUY HVQFP RCP 64 1000 Green (RoHS & no Sb/Br) CU NIPDAU Level-3-260C-168 HR -40 to 85 TLK2701 TLK2701IRCPRG4 LIFEBUY HVQFP RCP 64 1000 Green (RoHS & no Sb/Br) CU NIPDAU Level-3-260C-168 HR -40 to 85 TLK2701 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. (4) There may be additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. (5) Multiple Device Markings will be inside parentheses. Only one Device Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation of the previous line and the two combined represent the entire Device Marking for that device. (6) Lead/Ball Finish - Orderable Devices may have multiple material finish options. Finish options are separated by a vertical ruled line. Lead/Ball Finish values may wrap to two lines if the finish value exceeds the maximum column width. Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com 12-Aug-2016 Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. Addendum-Page 2 PACKAGE MATERIALS INFORMATION www.ti.com 14-Jul-2012 TAPE AND REEL INFORMATION *All dimensions are nominal Device TLK2701IRCPR Package Package Pins Type Drawing HVQFP RCP 64 SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) 1000 330.0 24.4 Pack Materials-Page 1 13.0 B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant 13.0 1.5 16.0 24.0 Q2 PACKAGE MATERIALS INFORMATION www.ti.com 14-Jul-2012 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) TLK2701IRCPR HVQFP RCP 64 1000 367.0 367.0 45.0 Pack Materials-Page 2 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use of any TI components in safety-critical applications. In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and requirements. Nonetheless, such components are subject to these terms. No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties have executed a special agreement specifically governing such use. Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of non-designated products, TI will not be responsible for any failure to meet ISO/TS16949. Products Applications Audio www.ti.com/audio Automotive and Transportation www.ti.com/automotive Amplifiers amplifier.ti.com Communications and Telecom www.ti.com/communications Data Converters dataconverter.ti.com Computers and Peripherals www.ti.com/computers DLP® Products www.dlp.com Consumer Electronics www.ti.com/consumer-apps DSP dsp.ti.com Energy and Lighting www.ti.com/energy Clocks and Timers www.ti.com/clocks Industrial www.ti.com/industrial Interface interface.ti.com Medical www.ti.com/medical Logic logic.ti.com Security www.ti.com/security Power Mgmt power.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com OMAP Applications Processors www.ti.com/omap TI E2E Community e2e.ti.com Wireless Connectivity www.ti.com/wirelessconnectivity Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2016, Texas Instruments Incorporated
TLK2701IRCPG4 价格&库存
很抱歉,暂时无法提供与“TLK2701IRCPG4”相匹配的价格&库存,您可以联系我们找货
