TRV-200S048ST
TRV-200S048ST
    THOMASRESEARCHPRODUCTS
    LED DRIVER CV AC/DC 48V
TRV-200S048ST 数据手册
200W TRV-200 Series Switch Mode LED Drivers Constant Voltage Aluminum Housing Electrical Specifications Input Voltage Range: 100 - 277 Nom. Vac (90 - 305 V Min/Max) Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: >0.90 @ full load, 100V through 277V Inrush Current: 65 Amps max @ 230 Vac, cold start 25ºC Input Current: 2.3 A max 100Vac, 1.1 A max 220Vac Maximum Power: 200W Line Regulation: ± 1% Load Regulation: ± 2% THD: < _ 20% @ full load Leakage Current: 0.75 mA 277 Vac 60Hz Typical Efficiency 92.5%-93.5% at 220Vac Turn-on Delay: 0.9S typical 110Vac, 0.5S typical 220Vac Ripple and Noise: 2% Vo Protection: Over-Voltage (latch mode), Over-Temperature (120°C), Over-Current (hiccup mode), Lightning, and Short Circuit Protection with Self Recovery Environmental Specifications Max Case Temperature: 88.2ºC Storage Temperature: -40ºC to +85ºC Humidity: 5% to 100% Cooling: Convection Sound Rating: Class A MTBF: 276,000 Hours @ 110VAC input, 80% load and 25ºC ambient conditions per MIL-HDBK-217F Lifetime: 92,500 Hours @ 220Vac, 80% load and Tc = 60ºC Weight: 2.2 lbs. (1.0 kg) • Total Power: 200 Watts • Input Voltage: 100-277 Vac Nom. • UL Dry & Damp Location Rated • IP67 • Ultra-high Efficiency • High Power Factor • UL8750 Constant Voltage - Product Specifications Model Name Output Voltage (Vdc ±5%) Output Current Range (A) Max. Output Power (W) Typical Efficiency TRV-200S012ST 12 0–15.0 180 91.0% TRV-200S024ST 24 0–8.33 200 92.0% TRV-200S036ST 36 0–5.56 200 92.5% TRV-200S048ST 48 0–4.17 200 92.5% TRV-200S054ST 54 0–3.70 200 92.5% E332160 Note: LED drivers are designed and intended to operate LED loads only. Non-LED loading may be outside the specified design limits of our LED drivers, and therefore cannot be covered by any warranty. If you desire to use our LED drivers to operate non-LED loads please contact us to discuss compatibility. Specifications subject to change without notice. Rev 8-28-15 Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com TRV-200 Series SSL Solutions Faster Than The Speed Of Light® Pg 2 of 2 Dimensions - mm WHITE (ACN) BLACK (ACL) GREEN (GND) AC INPUT (3*AWG #18) Tc = 88.2°C max Derating Curve Derating Curve 80 80 Load(%) 100 Load(%) 100 60 40 60 40 100Vac 277Vac 20 0 -35 DC OUTPUT (2*AWG #18) RED (V+) BLACK (V-) -20 -5 10 25 40 55 20 70 0 90 120 150 Ambient Temperature(°C) 180 210 240 270 300 330 Input Voltage(V) Safety and EMC Compliance UL/CUL UL8750, Compliance to UL1012, UL935, CAN/CSA-C22.2 No. 0, CSA-C22.2 No. 107.1-01, CSA-C22.2 No. 250.0 CE EN 55015 EN 61000-3-2 EN 61000-3-3 EN 61000-4-2 EN 61000-4-3 EN 61000-4-4 EN 61000-4-5 EN 61000-4-6 EN 61000-4-8 EN 61000-4-11 EN 61547 EN 61347-1, EN61347-2-13 Conducted emission Test & Radiated emission Test Harmonic current emissions Voltage fluctuations & flicker Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge Radio-Frequency Electromagnetic Field Susceptibility Test-RS Electrical Fast Transient / Burst-EFT Surge Immunity Test: AC Power Line: line to line 2 kV, line to earth 4 kV Conducted Radio Frequency Disturbances Test-CS Power Frequency Magnetic Field Test Voltage Dips Electromagnetic Immunity Requirements Applies to Lighting Equipment Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com
TRV-200S048ST 价格&库存
很抱歉,暂时无法提供与“TRV-200S048ST”相匹配的价格&库存,您可以联系我们找货
