ASD2123-R
ASD2123-R
    TINYCIRCUITS
    TINYSHIELDWIFI
ASD2123-R 数据手册
  WIFI TINYSHIELD (ATWINC1500) ASD2123-R DESCRIPTION Connect your projects to the internet with the WiFi TinyShield! Based on the Atmel ATWINC1500 WiFi module, this module supports 802.11 b/g/n, SSL, different security modes (WEP, WPA, WPA2, and unsecured connections) and has a built-in TCP/IP Stack that offloads network processing from your TinyDuino. The easy to use Arduino/Atmel supplied software library shows numerous examples on how to scan for WiFi access points, connect to an access point, run DHCP, ping IP addresses, do DNS lookups, connect as a client to a webserver and download web pages, or even act as your own webserver and access point. This TinyShield includes an integrated antenna on the module itself with FCC/CE approval as well as built-in LEDs that indicate connection state and active data transfer. This TinyShield also includes level shifters and a local power supply to ensure proper and safe operation over the entire TinyDuino operating voltage range up to 5V, and uses an SPI interface to allow for fast data transfers. Note: This module can act as an access point! To learn more about the TinyDuino Platform, click here https://tinycircuits.com/pages/tinyduino-overview TECHNICAL DETAILS To see what other TinyShields this will work with or conflict with, check out the TinyShield Compatibility Matrix Atmel ATWINC1500 WiFi Specs o IEEE 802.11 b/g/n (2.4GHz) o Embedded IPv4 TCP/IP stack o Up to 72 Mbps PHY throughput o TX power: +19.5 dBm at 11 Mbps, CCK o RX sensitivity: –88 dBm, 11 Mbps TinyDuino Power Requirements o Voltage: 3.3V - 5.5V o Current: o Active Mode, highest speed: 311mA TX at +18 dBm, 80.5mA RX o Shutdown Mode:
ASD2123-R 价格&库存
很抱歉,暂时无法提供与“ASD2123-R”相匹配的价格&库存,您可以联系我们找货
