16 EDGE LED TINYSHIELD
ASD2411-R-LR
DESCRIPTION
The 16 Edge LED TinyShield allows some cool and easy LED indications using only five I/O
signals. The 16 LEDs are mounted around the outside of the board, and can easily be seen
even when the LED board is in the middle of a TinyShield stackup. The LEDs are arranged
using Charlieplexing, which is a technique to allow for control of multiple LEDs using fewer
I/O signals. Available with Red, Green and Amber LED color options.
To learn more about the TinyDuino Platform, click here
https://tinycircuits.com/pages/tinyduino-overview
TECHNICAL DETAILS
To see what other TinyShields this will work with or conflict with, check out
the TinyShield Compatibility Matrix
LED Specs
o
16 Side Mounted LEDs around the edge of the board
o
Charlieplexed IO on 5 signals
o
Available in Green, Amber or Red
TinyDuino Power Requirements
o
Voltage: 3.0V - 5.5V
o
Current:
o
1.5mA per LED (3.0V)
o
5.0mA per LED (5.0V)
o
Due to the low current, this board can be run using the TinyDuino coin cell option
Pins Used
o
Pins 5, 6, 7, 8, and 9 are used, see schematic or sample code for connections
Dimensions
o
20mm x 20mm (.787 inches x .787 inches)
o
Max Height (from lower bottom TinyShield Connector to upper top TinyShield
Connector): 5.11mm (0.201 inches)
o
Weight: 1 gram (.04 ounces)
NOTES
o
If the top connector is not needed, there is also the Circle LED TinyShield which has
LEDs that circle the entire board.
o
The LEDs are hooked up using Charlieplexing, a technique for driving
https://tinycircuits.com/products/16‐edge‐led‐tinyshield?variant=15098343239 7‐14‐17
很抱歉,暂时无法提供与“ASD2411-R-LR”相匹配的价格&库存,您可以联系我们找货
