7 SEGMENT DISPLAY TINYSHIELD
ASD2421-R
DESCRIPTION
The TinyShield 7 Segment Display Board contains two seven segment LEDs (Red LEDs)
that can be set over the I2C (thus saving signals to do other tasks) by using a Semtech
SX1506 I/O expander. Each of the segments including the decimal indicator can be
individually selected, and a library is provided to make it extremely easy to use.
To learn more about the TinyDuino Platform, click here
https://tinycircuits.com/pages/tinyduino-overview
TECHNICAL DETAILS
To see what other TinyShields this will work with or conflict with, check out
the TinyShield Compatibility Matrix
Display Specs
o
Two Seven Segment LEDs, Color Red
o
Displays include decimal indicator
o
I2C Semtech SX1506 I/O Expander
TinyDuino Power Requirements
o
Voltage: 3.0V - 5.5V
o
Current:
o
4mA per segment (3.0V)
o
10mA per segment (5.0V)
o
Due to the current, this board can run for a very short time on the TinyDuino with coin cell,
however a Lithium battery should be used for longer life.
Pins Used
o
A5/SCL - I2C Serial Clock line
o
A4/SDA - I2C Serial Data line
Dimensions
o
20mm x 20mm (.787 inches x .787 inches)
o
Max Height (from lower bottom TinyShield Connector to upper top of LED displays):
6.6mm (.26 inches)
o
Weight: 1.36 grams (.05 ounces)
NOTES
o
This board has no top TinyShield connector, so no additional TinyShields can be stack
on top of this. This board is meant to be on the top of a TinyDuino stack.
https://tinycircuits.com/products/7‐segment‐display‐tinyshield 7‐14‐17
很抱歉,暂时无法提供与“ASD2421-R”相匹配的价格&库存,您可以联系我们找货
