TINY BATTERY CHARGER
ASL2112
DESCRIPTION
This is a standalone Lithium battery charger which lets you charge up your batteries from a
micro USB cable. The battery can connect to a JST SH connector (the battery connector
on the batteries that we sell at TinyCircuits). You can also use this without the JST
connector with two large through holes to connect to an battery pack.
Simply plug the USB side with a cable into a USB port, and plug a lithium polymer or lithium
ion rechargeable (3.7V / 4.2V) battery into the other side and it will start charging. A status
LED on the board will indicate when charging, and will turn off when fully charged.
Note: The battery and the microUSB cable are not included.
TECHNICAL DETAILS
o
2-Pin JST SH Connector for battery connection
o
Includes two solder tabs to connect directly to battery terminals if desired
o
100 mA charge current (can be set to 500mA with a resisitor change)
o
Status LED indicates when charging
o
Robust Gold Finish – makes soldering easy and is non-corrosive
Dimensions
o
Dimensions: 12mm x 7mm (0.472 inches x 0.276 inches)
o
Max Height: 3.7mm (0.146 inches)
o
Ultra-thin 0.61mm (0.024 inches) PCB
o
Weight: 0.32 grams (0.011 ounces)
NOTES
o
The charge current can be changed to 500mA by removing R3 and putting a 2K
resistor in the R2 position.
https://tinycircuits.com/products/tiny‐battery‐charger 7‐14‐17
很抱歉,暂时无法提供与“ASL2112”相匹配的价格&库存,您可以联系我们找货
