LITHIUM ION POLYMER BATTERY - 3.7V
500MAH
ASR00035
DESCRIPTION
This is a rechargeable Lithium ion polymer battery that works perfectly with the TinyDuino
Processor board to power your projects. The battery has a capacity of 500mAh at 3.7V, the
voltage can range from 4.2V when fully charged to 3.0V when completely discharged. The
battery includes protection circuitry to protect the battery from over charging or completely
discharging.
This battery includes a micro JST-SH connector, which is used on TinyCircuits products that
support Lithium ion batteries.
Note: As the 500mAH battery is much larger in capacity than our other battery sizes, charge
time will be longer.
TECHNICAL DETAILS
o
Dimensions: 31.0mm x 20.0mm x 9.5mm (1.22" x 0.79" x 0.37")
o
Wire Length: 23mm (0.91")
o
Weight: 17.1 grams
o
3.7V, 500mAh
https://tinycircuits.com/products/lithium‐ion‐polymer‐battery‐3‐7v‐500ma/12/11/2018
很抱歉,暂时无法提供与“ASR00035”相匹配的价格&库存,您可以联系我们找货
