TE0808-04-9GI21-AS
TE0808-04-9GI21-AS
    TRENZELECTRONIC
    STARTER KIT ZYNQ USCALE+ ZU9 FPG
TE0808-04-9GI21-AS 数据手册
        TE0808-04-9GI21-AS Starter Kit with Zynq UltraScale+ ZU9 FPGA Module Order number: TE0808-04-9GI21-AS Product information "TE0808-04-9GI21-AS Starter Kit with Zynq UltraScale+ ZU9 FPGA Module" This article is the replacement for the TE0808-04-09-2IE-S. All changes caused by the new revision of the buildt-in module are included in the Product Change Notification (PCN). The Trenz Electronic Starter Kit TE0808-04-9GI21-AS consists of a TE0808-04-9GI21-A module with ZU9 on a TEBF0808-04A base board including a pre-assembled heatsink, in a black Core V1 Mini-ITX Enclosure. Supplied with a Be Quiet! 400 W power supply for the enclosure, 2 x XMOD FTDI JTAG Adapter, an 8 GB micro SD card, an USB cable, screws and bolts.     The Module: TE0808-04-9GI21-A The Trenz Electronic TE0808-04-9GI21-A is a MPSoC module with industrial temperature grade integrating a Xilinx Zynq UltraScale+, 4 GByte DDR4 SDRAM, 128 MByte Flash memory for configuration and operation, 20 high speed serial transceivers, and powerful switch-mode power supplies for all on-board voltages. A large number of configurable I/O's is provided via rugged highspeed stacking connections. Key Features               Xilinx Zynq UltraScale+ XCZU9EG-2FFVC900I ZU9EG 900 Pin Packages 3 mm mounting holes for skyline heat spreader Size: 52 x 76 mm B2B Connectors: 4 x 160 pin Rugged for shock and high vibration 4 GByte 64-Bit DDR4 SDRAM 128 MByte SPI Boot Flash (dual parallel) User I/Os o 65 x PS MIOs, 48 x PL HD GPIOs, 156 x PL HP GIPIOs (3 banks) o Serial transceivers: 4 x GTR + 16 x GTH o Transceiver clocks inputs and outputs o PLL clock generator inputs and outputs Si5345 - 10 output PLL All power supplies on board, single 3.3 V Power required o 14 on-board DC/DC regulators and 13 LDOs o LP, FP, PL separately controlled power domains Support for all boot modes (except NAND) and scenarios Support for any combination of PS connected peripherals Evenly spread supply pins for good signal integrity Other assembly options for cost or performance optimization plus high volume prices available on request. Recommended Software Vivado Design Suite - HLx Edition Download Vivado Design Suite HLx Editions include Partial Reconfiguration at no additional cost with the Vivado HL Design Edition and HL System Edition. In-warranty users can regenerate their licenses to gain access to this feature. Overview of all editions of Vivado Design Suite Xilinx Licensing FAQ The Base Board: TEBF0808-04A The Trenz Electronic TEBF0808 UltraITX+ base board has been developed individually for the TE0808 UltraSOM+ MPSoC.     All the latest information on the article can be found at http://trenz.org/tebf0808-info. Key Features                                  Mini-ITX form factor, PC enclosure compatible ATX-24 power supply connector Optional 12 V standard power plug Headers Intel 10-pin HDA Audio Intel 9-pin Power-/Reset-Button, Power-/HD-LED PC-BEEPER On-board Power- / Reset-Switches 2 x Configuration 4-bit DIP-switches 2 x Optional 4-wire PWM fan connectors PCIe Slot - one PCIe lane (16 lane connector) CAN FD Transceiver (10 Pin IDC connector and 6-pin header) 4 x On-board configuration EEPROMs (1x Microchip 24LC128-I/ST, 3x Microchip 24AA025E48T-I/OT) Dual SFP+ Connector (2x1 Cage) 1 x DisplayPort (single lane) 1 x SATA Connector 2 x USB 3.0 A Connector (Superspeed Host Port (Highspeed at USB 2.0)) 1 x USB 3.0 on-board connector with two ports FMC HPC Slot (FMC_VADJ max. VCCIO) FMC Fan Gigabit Ethernet RGMII PHY with RJ45 MagJack All carrier board peripherals' I²C interfaces muxed to MPSoC's I²C interface Quad programmable PLL clock generator SI5338A 2x SMA coaxial connectors for clock signals MicroSD- / MMC-Card Socket (bootable) 32 Gbit (4 GByte) on-board eMMC flash (8 banks a 4 Gbit) 2 x System Controller CPLDs Lattice MachXO2 1200 HC 1 x Samtec FireFly (4 GT lanes bidirectional) 1 x Samtec FireFly connector for reverse loopback 2 pre-assembled TE0790 JTAG/UART header ('XMOD FTDI JTAG Adapter'-compatible) for programming MPSoC and SC CPLDs 20-pin ARM JTAG Connector (PS JTAG0) 3 x Pmod connector (GPIO's and I²C interface to SC CPLDs and MPSoC module) On-board DC-DC PowerSoCs PC Enclosure Accessible I/O            PCIe FMC Dual SFP+ RJ45 Gigabit Ethernet 2x USB3 Host Displayport microSD Two LEDs CAN FD (using DB9 to IDC10 Cable)   Core V1 Mini-ITX Enclosure - Technical Features           Dimensions: 260 x 276 x 316 mm (B x H x T) Material: Steel Colour: Black Drive Slots: 2 x 3.5 inch (intern, 3.5 inch) and 2 x 2.5 inch (intern, 2.5 inch) Expansion slots: 2 I/O-Panel: 2 x USB 3.0 and 1 x Audio In/Out each Maximum graphic card lenght: 255 mm (inner enclosure) Maximum graphic card lenght: 285 mm (outer enclosure) Maximum CPU cooler height: 140 mm Maximum lenght power supply: 200 mm Scope of Delivery - Starter Kit            1 x Core V1 Mini-ITX Enclosure- black with viewing window and removable sled walls 1 x Power supply Be quiet! BN142 System Power 7, 400 Watt, 12 V, ATX 2.3 with fan 1 x TE0808-04-9GI21-A MPSoC module with ZU9 (industrial temperature range) 1 x TEBF0808-04A carrier board 1 x Heatsink MBH31001-15W/2.6, pre-assembled 1 x TE0790-03 XMOD FTDI JTAG adapter (compatible with Xilinx-Tools), pre-assembled 1 x TE0790-03L XMOD FTDI JTAG adapter (independent from Xilinx-Tools), pre-assembled 1 x 8 GB Class 4 microSDHC card 1 x USB cable, Type A to Type B Mini, 2 meter length 2 x Phillips screws, M3 x 6, pan head, zinc coated 2 x Spacer bolts, M3, 10 mm Additional Information    Manufacturer's article number: TE0808-04-9GI21-AS Trenz Electronic TE0808 Starter Kit Wiki Support Forum All modules produced by Trenz Electronic are developed and manufactured in Germany.      Starter Kit 808 Created by John Hartfiel, last modified on 07 05, 2019   This Trenz Electronic Starter Kit consists of a TE0808 module on a TEBF0808 base board in Mini-ITX Enclosure. See shop link for detailed content. Wiki Links         TE0808 - UltraSoM+ - Wiki with TRM, reference projects, application notes and more TE0808 Resources - Links to all TE0808 Resources TEBF0808 - Wiki with TRM, application notes and more TEBF0808 Resources - Links to all TEBF0808 Resources TE0790 - XMOD - Wiki with TRM, application notes and more TE0790 Resources - Links to all TE0790 Resources Vivado/SDK/SDSoC - Short instructions for Vivado, SDK, SDSoC Project Delivery - Xilinx devices - General descriptions of reference designs and content Download Links     TE0808 Download Area - contains various reference designs, schematics, hardware designs, 3D models and more TEBF0808 Download Area - contains schematics, hardware designs, 3D models and more TE0790-XMOD Download Area - contains firmware with projects, schematics, hardware designs, 3D models and more TE Master Pinout - Excel Sheet as Pinout-Viewer and XDC-Generator Shop Links  Shop TE0808-Starter-Kit - contains prices, available stock, disposability, scope of delivery and more Xilinx Software and Driver   Vivado Design Suite - Xilinx Design Software with JTAG drivers and documentation Xilinx Download Area - All Xilinx Software, Device Models and Libraries     Additional Documentation                      Wiki Links Download Links Shop Links Xilinx Software and Driver Additional Documentation Important Notes Getting Started Starter Kit Basic Main Power Enclosure Location Power Button , Reset Button, HDD LED and Power LED Enclosure Location Default DIP Switch Settings SI5345 NVM Programming Starter Kit Cable Connection ATX Power Module FMC FAN XMODs Enclosure USB Enclosure FAN1 and HDAUDIO Enclosure Power Button , Reset Button, HDD LED and Power LED Support Important Notes Do not change XMOD DIP-Switch settings on TEBF0808. Do not swap the XMOD adapters the one marked with green dot must be closer to the SoM ES devices are not included in all Vivado versions, for ES1 only: activate beta device see: FAQ - How can I activate beta devices? For all Starter Kit's shipped before 2017-06-21: Enclosure Power and HD LED was swapped on connector. See "Enclosure Power Button, Reset Button, HDD LED and Power LED" section for correct connection. Getting Started  TEBF0808 Getting Started - Basic note to start up Carrier with TE080x modules     Starter Kit Basic Main Power Enclosure Location Power Button , Reset Button, HDD LED and Power LED Enclosure Location     Default DIP Switch Settings Do not change XMOD DIP-Switch settings on TEBF0808. Do not swap the XMOD adapters the one marked with green dot must be closer to the SoM TE0790-02 TEBF0808 TE0790‐02L  (with green dot)   DIP‐ Schalter  S4  DIP‐ Schalter  S5   DIP‐ Schalter  S1   DIP‐ Schalter  S1  S4.1  OFF  S5.1  ON  S1.1  ON  S1.1  ON  S4.2  OFF  S5.2  ON  S1.2  OFF  S1.2  OFF  S4.3  OFF  S5.3  OFF  S1.3  OFF  S1.3  OFF  S4.4  ON  S5.4  OFF  S1.4  OFF  S1.4  OFF      Note: with CPLD Firmware REV06 or newer, S4.4 can be set to OFF, to save power, if Starter Kit is powered off with Power Button. For more information, see:TEBF0808 SI5345 NVM Programming SI5345 NVM on the module is not programmed on factory, so modified FSBL is needed to get running output CLKS. It is possible to program NVM of the SI5345 2 times, see Si5345 Starter Kit Cable Connection Starter Kit will be shipped with all cable connected.     ATX Power Module     FMC FAN XMODs     Enclosure USB Enclosure FAN1 and HDAUDIO     Enclosure Power Button , Reset Button, HDD LED and Power LED Support  For support, please go to http://forum.trenz-electronic.de/ or contact support@trenz-electronic.de   https://shop.trenz‐electronic.de/en/TE0808‐04‐9GI21‐AS‐TE0808‐04‐9GI21‐AS‐Starter‐Kit‐with‐Zynq‐UltraScale‐ZU9‐FPGA‐Module?path=Trenz_Electronic/Modules_and_Module_Carriers/5.2x7.6/TE0808/Reference_Design/12‐4‐19
TE0808-04-9GI21-AS 价格&库存
很抱歉,暂时无法提供与“TE0808-04-9GI21-AS”相匹配的价格&库存,您可以联系我们找货
