CompactPCI Serial Card with Xilinx Zynq
UltraScale+ ZU15, 3U form factor
Order number: TEC0850-03-15EG1E
Product information "CompactPCI Serial Card with Xilinx
Zynq UltraScale+ ZU15, 3U form factor"
The Trenz Electronic TEC0850 board is a CompactPCI Serial card (3U form factor) integrating a Xilinx
Zynq UltraScale+ MPSoC, one DDR4 SDRAM SODIMM socket with 64bit wide data bus, max. dual
512 MByte Flash memory for configuration and operation, 24 Gigabit transceivers on PL side and 4
on PS side, powerful switch-mode power supplies for all onboard voltages, USB2 and USB3 FIFO
bridges and a large number of configurable I/Os available on the CompactPCI Serial backplane
connectors.
Key Features
Xilinx Zynq UltraScale+ XCZU15EG-1FFVB1156E
ZU15EG, 1156 Pin Packages
Dimensions: 3U, 8HP CompactPCI-Serial
Rugged for shock and high vibration.
8 GByte (up to 32 GByte possible configuration) DDR4 SODIMM, 64-bit width, support DDR4
SODIMM with ECC
128 MByte QSPI Boot Flash dual parallel
Rear I/O: 32 x differential pairs; 24 x GTH Lanes; 4 x PS GTR Lanes; 2 x USB 2.0 (depends from
assembly variant)
System Controller (Altera MAX10 FPGA SoC)
Programmable 10-channel PLL clock generator (Si5345)
1 x USB 3.0
1 x 1 Gigabit Ethernet
MicroSD Card Slot
JTAG ,UART via Micro USB
2 x EEPROM
Real Time Clock
4 x status LEDs
2 x 4 bit DIP switches
1 x User Button
Zynq MPSoC cooling FAN connector
High performance DC-DC converters
Evenly spread supply pins for good signal integrity.
Other assembly options for cost or performance optimization plus high volume prices available on
request.
Scope of Delivery
1 x CompactPCI Serial Card with Xilinx Zynq UltraScale+ ZU15, TEC0850-03-15EG1E
Additional Information
Manufacturer's article number: TEC0850-03-15EG1E
Trenz Electronic TEC850 Wiki
Support Forum
All modules produced by Trenz Electronic are developed and manufactured in Germany.
https://shop.trenz‐electronic.de/en/TEC0850‐03‐15EG1E‐CompactPCI‐Serial‐Card‐with‐Xilinx‐Zynq‐UltraScale‐ZU15‐3U‐form‐factor?path=Trenz_Electronic/CPCIS_Cards/TEC0850/Reference_Design/12‐14‐18
很抱歉,暂时无法提供与“TEC0850-03-15EG1E”相匹配的价格&库存,您可以联系我们找货
