L6R120D-240
L6R120D-240
    TRI-MAG
    24V 120 W AC/DC 外部 台式(类 I) 适配器 缆线(单独出售) 输入
L6R120D-240 数据手册
GR EEN POW ER Power Supplies L6R120D Series 120W Desktop Power Supply • DOE Level VI Efficiency Rating • Universal Input: 90 ~ 264Vac, 47/63 Hz • UL/cUL/IEC 62368-1 Approved • Corded Output Connection • IEC 60320 C6 and C14 AC input connectors • Light Weight and Compact • RoHS Compliant Class II Design Model No.1 Application Output Connector Output Current (A) Output Voltage Min Rated Peak Voltage Accuracy Ripple Noise Line Reg. Load Reg. L6R120D-120 ITE +12.0V 0 9.00 — ±5% < ± 2% ± 1% ± 5% L6R120D-150 ITE +15.0V 0 8.00 — ±5% < ± 2% ± 1% ± 5% L6R120D-160 ITE +16.0V 0 7.50 — ±5% < ± 2% ± 1% ± 5% L6R120D-180 ITE +18.0V 0 6.60 — ±5% < ± 2% ± 1% ± 5% L6R120D-190 ITE +19.0V 0 6.30 — ±5% < ± 2% ± 1% ± 5% L6R120D-200 ITE +20.0V 0 6.00 — ±5% < ± 2% ± 1% ± 5% L6R120D-240 ITE +24.0V 0 5.00 — ±5% < ± 2% ± 1% ± 5% L6R120D-300 ITE +30.0V 0 4.00 — ±5% < ± 2% ± 1% ± 5% L6R120D-480 ITE +48.0V 0 2.50 — ±5% < ± 2% ± 1% ± 5% L6R120D-560 ITE +56.0V 0 2.14 — ±5% < ± 2% ± 1% ± 5% 4-Pin Circular DIN 2.5mm I.D. x 5.5mm O.D. x 9.5mm Barrel 1. Add “C6” or “C14” for the required AC input connector configuration. • • • • • The output voltage is verified to specs at 60 percent rated load condition. The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load. The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load. The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load and nominal line. The efficiency is measured at rated load and nominal line. 2400 S. 43rd Street • Milwaukee, WI 53219 • (800) 657-0853 • (414) 649-4200 • FAX (414) 649-4279 • sales@tri-mag.com • tri-mag.com Power Supplies L6R120D Series Innovative, reliable, and inexpensive. This Class II number table) to match your needs. Rated up to design is an economical, DOE Level VI compliant 120W when powering either stationary or charging power supply/charger is available in a variety of portable devices. voltage levels, 12.0 to 56.0Vdc (per the model Specifications Input Input Voltage Input Frequency No Load Input Power Input Current Inrush Current Leakage Current Input Connection Environmental • • • • • • • 90 Vac ~ 264 Vac 47 Hz to 63 Hz < 0.21W 1.6A Max. 60A Max. / 230Vac 3.5mA Max. IEC 60320 C6 or C14 Output Voltage Range Output Current Range Minimum Load Line Regulation • • • • Load Regulation Ripple & Noise Overvoltage Protection Overload Protection Short Circuit Protection • • • • • 12.0 to 56.0Vdc 2.14 to 9.00A No min. load required. ± 1% at rated load across input voltage range ± 5% (typical) 2% Vp-p Max. @ full load Auto recovery Auto recovery Auto recovery Output General Dielectric Withstand Efficiency MTBF • 3,000Vac Primary to Secondary • Level VI, ErP Stage 2, CoC Tier 2 compliant • 300,000 hrs. @ 25ºC per Telcordia SR-332 Operating Temperature Operating Humidity Storage Temperature Storage Humidity • • • • 0°C to 40°C 20 to 80% RH, Non-Condensing -20°C to +80°C 10 to 90%, Non-Condensing EMC & Safety Safety Approvals EMC Approvals • UL/cUL: UL/cUL 62368-1, 60950-1 • CE: IEC 62368-1, 60950-1 • FCC Warranty Warranty Period • 1 year Dimensions and Notes Dimensions in mm Tolerance • ± 0.2mm Size • L 168 x W 66 x H 39 (mm) • L 6.61” x W 2.60” x H 1.54” Weight • Approx. 600g (1.3 lb.) (Ref.) Connectors • AC input; IEC 60320 C6 or C14 connector • DC output; -120 thru -200: 4-pin circular DIN -240 thru -560: 2.5mm I.D. x 5.5mm O.D. x 9.5mm barrel or per customer specification. Output Cord length • -120 thru -200: 1200 ±30mm (47.3 ±1.2”) • -240 thru -560: 1500 ±30mm (59.1 ±1.2”) Mechanical Drawing 2021-01 2400 S. 43rd Street • Milwaukee, WI 53219 • (800) 657-0853 • (414) 649-4200 • FAX (414) 649-4279 • sales@tri-mag.com • tri-mag.com
L6R120D-240 价格&库存
很抱歉,暂时无法提供与“L6R120D-240”相匹配的价格&库存,您可以联系我们找货
