GR EEN POW ER
Power Supplies
L6R300D Series
300W Desktop Power Supply
DOE Level VI Efficiency Rating
Universal Input: 90 ~ 264Vac, 47/63 Hz
UL/cUL/IEC 62368-1 Approved
Corded Output Connection
IEC 60320 C6 and C14 AC input connectors
Light Weight and Compact
RoHS Compliant Class II Design
Output Current (A)
Application
Output
Connector
Output
Voltage
Min
Rated
L6R300D-120
ITE
6-Pin rectangular
+12.0V
L6R300D-190
ITE
6-Pin rectangular
+19.0V
L6R300D-240
ITE
6-Pin rectangular
L6R300D-480
ITE
L6R300D-560
ITE
Model No.1
Peak
Voltage
Accuracy
Ripple
Noise
Line
Reg.
Load
Reg.
24.00
±5%
< ± 2%
± 1%
± 5%
±5%
< ± 2%
± 1%
± 5%
+24.0V
±5%
< ± 2%
± 1%
± 5%
6-Pin rectangular
+48.0V
±5%
< ± 2%
± 1%
± 5%
6-Pin rectangular
+56.0V
±5%
< ± 2%
± 1%
± 5%
1. Add “C6” or “C14” for the required AC input connector configuration.
The output voltage is verified to specs at 60 percent rated load condition.
The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load.
The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load.
The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load
and nominal line.
The efficiency is measured at rated load and nominal line.
2400 S. 43rd Street • Milwaukee, WI 53219 • (800) 657-0853 • (414) 649-4200 • FAX (414) 649-4279 • sales@tri-mag.com • tri-mag.com
Power Supplies
L6R300D Series
Innovative, reliable, and inexpensive. This
model number table) to match your needs. Rated up
economical, Class II design is a DOE Level VI
to 300W when powering either stationary or charging
compliant power supply/charger is available in a
portable devices.
variety of voltage levels, 12.0 to 56.0Vdc (per the
Specifications
Input
Input Voltage
Input Frequency
No Load Input Power
Input Current
Inrush Current
Leakage Current
Input Connection
Environmental
90 Vac ~ 264 Vac
47 Hz to 63 Hz
< 0.5W
3.9A Max.
60A Max. / 230Vac
3.5mA Max.
IEC 60320 C6 or C14
Output Voltage Range
Output Current Range
Minimum Load
Line Regulation
Load Regulation
Ripple & Noise
Overvoltage Protection
Overload Protection
Short Circuit Protection
12.0 to 56.0Vdc
24.0 to 5.36A
No min. load required.
± 1% at rated load across input
voltage range
± 5% (typical)
2% Vp-p Max. @ full load
Auto recovery
Auto recovery
Auto recovery
Output
General
Dielectric Withstand
Efficiency
MTBF
• 3,000Vac Primary to Secondary
• Level VI, ErP Stage 2, CoC Tier 2 compliant
• 300,000 hrs. @ 25ºC per Telcordia SR-332
Operating Temperature
Operating Humidity
Storage Temperature
Storage Humidity
0°C to 40°C
20 to 80% RH, Non-Condensing
-20°C to +80°C
10 to 90%, Non-Condensing
EMC & Safety
Safety Approvals
EMC Approvals
• UL/cUL: UL/cUL 62368-1, 60950-1
• CE: IEC 62368-1, 60950-1
• FCC
Warranty
Warranty Period
• 1 year
Dimensions and Notes
Dimensions in mm
Tolerance
Size
Weight
Connectors
± 0.2mm
L 254 x W 116 x H 47 (mm)
L 10.00” x W 4.57” x H 1.85”
Approx. 1600g (3.52 lb.) (Ref.)
AC input; IEC 60320 C6 or
C14 connector
• DC output; 6-pin (2x3) rectangular output
connector or per customer specification.
Output Cord length
• L6R300D-120: 1000 ±30 mm (39.4 ±1.2”)
All other P/Ns: 1200 ±30 mm (47.2 ±1.2”)
Mechanical Drawing
2021-01
很抱歉,暂时无法提供与“L6R300D-480”相匹配的价格&库存,您可以联系我们找货
