L6R300D-240
L6R300D-240
    TRI-MAG
    24V 300 W AC/DC 外部 台式(类 I) 适配器 缆线(单独出售) 输入
L6R300D-240 数据手册
GR EEN POW ER Power Supplies L6R300D Series 300W Desktop Power Supply • DOE Level VI Efficiency Rating • Universal Input: 90 ~ 264Vac, 47/63 Hz • UL/cUL/IEC 62368-1 Approved • Corded Output Connection • IEC 60320 C6 and C14 AC input connectors • Light Weight and Compact • RoHS Compliant Class II Design Output Current (A) Application Output Connector Output Voltage Min Rated L6R300D-120 ITE 6-Pin rectangular +12.0V 0 L6R300D-190 ITE 6-Pin rectangular +19.0V L6R300D-240 ITE 6-Pin rectangular L6R300D-480 ITE L6R300D-560 ITE Model No.1 Peak Voltage Accuracy Ripple Noise Line Reg. Load Reg. 24.00 — ±5% < ± 2% ± 1% ± 5% 0 15.78 — ±5% < ± 2% ± 1% ± 5% +24.0V 0 12.50 — ±5% < ± 2% ± 1% ± 5% 6-Pin rectangular +48.0V 0 6.25 — ±5% < ± 2% ± 1% ± 5% 6-Pin rectangular +56.0V 0 5.36 — ±5% < ± 2% ± 1% ± 5% 1. Add “C6” or “C14” for the required AC input connector configuration. • • • • • The output voltage is verified to specs at 60 percent rated load condition. The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load. The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load. The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load and nominal line. The efficiency is measured at rated load and nominal line. 2400 S. 43rd Street • Milwaukee, WI 53219 • (800) 657-0853 • (414) 649-4200 • FAX (414) 649-4279 • sales@tri-mag.com • tri-mag.com Power Supplies L6R300D Series Innovative, reliable, and inexpensive. This model number table) to match your needs. Rated up economical, Class II design is a DOE Level VI to 300W when powering either stationary or charging compliant power supply/charger is available in a portable devices. variety of voltage levels, 12.0 to 56.0Vdc (per the Specifications Input Input Voltage Input Frequency No Load Input Power Input Current Inrush Current Leakage Current Input Connection Environmental • • • • • • • 90 Vac ~ 264 Vac 47 Hz to 63 Hz < 0.5W 3.9A Max. 60A Max. / 230Vac 3.5mA Max. IEC 60320 C6 or C14 Output Voltage Range Output Current Range Minimum Load Line Regulation • • • • Load Regulation Ripple & Noise Overvoltage Protection Overload Protection Short Circuit Protection • • • • • 12.0 to 56.0Vdc 24.0 to 5.36A No min. load required. ± 1% at rated load across input voltage range ± 5% (typical) 2% Vp-p Max. @ full load Auto recovery Auto recovery Auto recovery Output General Dielectric Withstand Efficiency MTBF • 3,000Vac Primary to Secondary • Level VI, ErP Stage 2, CoC Tier 2 compliant • 300,000 hrs. @ 25ºC per Telcordia SR-332 Operating Temperature Operating Humidity Storage Temperature Storage Humidity • • • • 0°C to 40°C 20 to 80% RH, Non-Condensing -20°C to +80°C 10 to 90%, Non-Condensing EMC & Safety Safety Approvals EMC Approvals • UL/cUL: UL/cUL 62368-1, 60950-1 • CE: IEC 62368-1, 60950-1 • FCC Warranty Warranty Period • 1 year Dimensions and Notes Dimensions in mm Tolerance • Size • Weight • Connectors • ± 0.2mm L 254 x W 116 x H 47 (mm) L 10.00” x W 4.57” x H 1.85” Approx. 1600g (3.52 lb.) (Ref.) AC input; IEC 60320 C6 or C14 connector • DC output; 6-pin (2x3) rectangular output connector or per customer specification. Output Cord length • L6R300D-120: 1000 ±30 mm (39.4 ±1.2”) All other P/Ns: 1200 ±30 mm (47.2 ±1.2”) Mechanical Drawing 2021-01 2400 S. 43rd Street • Milwaukee, WI 53219 • (800) 657-0853 • (414) 649-4200 • FAX (414) 649-4279 • sales@tri-mag.com • tri-mag.com
L6R300D-240 价格&库存
很抱歉,暂时无法提供与“L6R300D-240”相匹配的价格&库存,您可以联系我们找货
