GR EEN POW ER
Power Supplies
L6R90D Series
90W Desktop Power Supply
DOE Level VI Efficiency Rating
Universal Input: 90 ~ 264Vac, 47/63 Hz
UL/cUL/IEC 62368-1 Approved
Corded Output Connection
IEC 60320 C6 and C14 AC input connectors
Light Weight and Compact
Peak
Voltage
Accuracy
Ripple
Noise
Line
Reg.
Load
Reg.
Min
Rated
ITE
+12.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-150
ITE
+15.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-160
ITE
+16.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-180
ITE
+18.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-190
ITE
+19.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-200
ITE
+20.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-240
ITE
+24.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-300
ITE
+30.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-480
ITE
+48.0V
±5%
< ± 2%
± 1%
± 5%
L6R90D-560
ITE
+56.0V
±5%
< ± 2%
± 1%
± 5%
Application
L6R90D-120
Output
Connector
Output Current (A)
Output
Voltage
Model No.1
2.5mm I.D. x
5.5mm O.D. x
9.5mm Barrel
1. Add “C6” or “C14” for the required AC input connector configuration.
The output voltage is verified to specs at 60 percent rated load condition.
The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load.
The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load.
The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load
and nominal line.
The efficiency is measured at rated load and nominal line.
1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
Power Supplies
L6R90D Series
Innovative, reliable, and inexpensive. This
12.0 to 56.0Vdc (per the model number table) to
economical DOE Level VI compliant power supply/
match your needs. Rated up to 90W when powering
charger is available in a variety of voltage levels,
either stationary or charging portable devices.
Specifications
Input
Input Voltage
Input Frequency
No Load Input Power
Input Current
Inrush Current
Leakage Current
Input Connection
Environmental
90 Vac ~ 264 Vac
47 Hz to 63 Hz
< 0.21W
1.2A Max.
60A Max. / 230Vac
3.5mA Max.
IEC 60320 C6 or C14
Output Voltage Range
Output Current Range
Minimum Load
Line Regulation
Load Regulation
Ripple & Noise
Overvoltage Protection
Overload Protection
Short Circuit Protection
12.0 to 56.0Vdc
1.6 to 7.0A
No min. load required.
± 1% at rated load across input
voltage range
± 5% (typical)
2% Vp-p Max. @ full load
Auto recovery
Auto recovery
Auto recovery
Output
General
Dielectric Withstand
Efficiency
MTBF
• 3,000Vac Primary to Secondary
• Level VI, ErP Stage 2, CoC Tier 2 compliant
• 300,000 hrs. @ 25ºC per Telcordia SR-332
Operating Temperature
Operating Humidity
Storage Temperature
Storage Humidity
0°C to 40°C
20 to 80% RH, Non-Condensing
-20°C to +80°C
10 to 90%, Non-Condensing
EMC & Safety
Safety Approvals
EMC Approvals
• UL/cUL: UL/cUL 62368-1, 60950-1
• CE: IEC 62368-1, 60950-1
• FCC
Warranty
Warranty Period
• 1 year
Dimensions and Notes
Dimensions in mm
Tolerance
• ± 0.2mm
Size
• C6: L 139 x W 61 x H 36 (mm)
L 5.5” x W 2.4” x H 1.4”
• C14: L 151 x W 64 x H 36 (mm)
L 5.9” x W 2.5” x H 1.4”
Weight
• Approx. 460g (1.0 lb.)
Connectors
• AC input; IEC 60320 C6 or
C14 connector
• DC output; Standard 2.5mm x 5.5mm x
9.5mm barrel connector or per customer
specification.
Output Cord length
• 1500 ±30 mm (59 ±1.2”)
Mechanical Drawing
2020-12
很抱歉,暂时无法提供与“L6R90D-240-C6”相匹配的价格&库存,您可以联系我们找货
