Type BLR-406-G
Fuse Block
6 Pole - Regular, ATC/ATO Auto Blade
With 6-Position Grounding Block
Specifications:
Max Voltage: 32VDC
Max Current Rating: 30A per Circuit - 100A Max
Fuse Type: Regular Auto Blade (APR / ANR series)
(Fuses or Circuit Breakers)
Mounting: 4 mounting holes, 4.5mm diameter
Temperature Rating: -20° C ~ +85° C
www.optifuse.com
(619) 593-5050
Material:
Housing & Base: PBT, Black
Cover: PC, Clear
Terminals: Tinned Copper
Button: PA, Red
Note: Push down Button to open/close
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev A 08/2018 - Page: 1/1
Code S02-01H
很抱歉,暂时无法提供与“BLR-406-G”相匹配的价格&库存,您可以联系我们找货
