Type BLR-I-310-G
Fuse Block - Indicating
10 Pole – Regular Auto Blade
With 12 Position Grounding Block
www.optifuse.com
(619) 593-5050
Specifications:
Max Voltage: 32VDC
Max Current Rating: 30A per Circuit - 100A Max Input
Fuse Type: Regular Auto Blade – APR, APN Series
Base: PBT
Cover: PC (Transparent)
Indicating LED – Red
Load-side Connection: 0.250” Quick Connect Terminals - Copper, Tin plated
Line-side Connection: 2 each, M5 (SUS304) stud terminal with 2 hex nuts, flat washer, lock-washer
Mounting: 4 mounting holes for #10 screws (not provided)
Temperature Rating: -20° C ~ +85° C
Mechanical Dimensions: Inches [mm]
Warning:
-Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical
arcing and/or flame.
-Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance.
Note: All specifications subject to change without notice.
Rev A 04/2018 - Page: 1/1
Code S02-01H
很抱歉,暂时无法提供与“BLR-I-310-G”相匹配的价格&库存,您可以联系我们找货
