BLR-I-912-G
BLR-I-912-G
    OPTIFUSE
    REG FUSE BLOCK,12POLE LED&GROUND
BLR-I-912-G 数据手册
Type BLR-I-912-G Fuse Block - Indicating 12 Pole - Regular, ATC/ATO Auto Blade With 12-Position Grounding Block Specifications: Max Voltage: 32VDC Max Current Rating: 30A per Circuit - 100A Max Fuse Type: Regular, ATO / ATC, Auto Blade (APR / ANR series) (Fuses or Circuit Breakers) Mounting: 4 mounting holes, 4.5mm diameter Indicating LED – Red Temperature Rating: -20° C ~ +85° C www.optifuse.com (619) 593-5050 Material: Housing & Base: PBT, Black Cover: PC, Clear Terminals: Copper Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact may damage the device performance. Note: All specifications subject to change without notice. Rev A 08/2018 - Page: 1/1 Code S02-01H
BLR-I-912-G 价格&库存
很抱歉,暂时无法提供与“BLR-I-912-G”相匹配的价格&库存,您可以联系我们找货
